Question about Casio Cassiopeia E-105 Pocket PC
I have a cassiopeia E105 that has been in storage for a while, but when I try to power up I get nothing. When I plug it in, I get a green light led on the top of the unit, but it only comes on for a second then turns off. Leaving it plugged in over night still not difference.
2 Suggested Answers
  • 4 Answers
SOURCE: Casio Cassiopeia E-125 Pocket: Problem
low batteries.
Posted on Jan 01, 2008
The led on the front won't light, and I have power connected, but nothing. Is there a reset somewere?
I am assuming you are trying to power up an installed motherboard, based on the category selection. You say that you have power connected. That means that you have connected the 20 (24) pin main connector and the 4 or 8 pin CPU power connector to the motherboard. Have you connected the front panels controls to the motherboard header? There are connections for the power switch, power LED, HDD LED, reset switch (optional). They must be connected in order for the motherboard to start. THe HDD and Power LED connections are polarity-based, so if you hook them upo backwards, their respective LED will not light. The HDD LED plug is usually red and white with the red being on the positive (+) terminal. The Power LED plug is usually green and white with the green wire going to the positive terminal. The power switch and reset switch wires can be connected either way as they are not polarized.
Jul 14, 2015 | Computers & Internet
No power to hp envy
I suggest you step by step follow check it your Desktop issue.
A> All power plug proper connect or not, if possible change another port.
B> Have your ups get power or not, If ups on then nest step follow.
C> Check it SMPS on or off position. If your power ok and come to smps or smps not start then you SMPS damage position, you check it smps ok conduction or not..
Checking method:
SMPS more wire available you see it one more bulk wire available and black wire and green wire cross check, if not start smps then damge. But my friend if you smps ok or your are wrong wire attach then may be your smps damage. So better contact good Computer Hardware Technician.
Thanks.
Computer Support
Feb 19, 2014 | HP ENVY 23-d065 TouchSmart All-in-One...
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
No Power, Cannot open
contact ur dealer..its hardware problem!
Dec 27, 2008 | Compaq Presario 700 470024-192 Notebook
Battery won't charge/no power to unit
Charger seams defective. get new charger and try.
May 29, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Monitor not getting power
could you describe how you got it apart? i've got the same problem, and i feel like i'm going to crack it just to get it open...i've mostly tried pulling the back off from the bottom after removing the 2 screws
thanks
Nov 28, 2007 | Computers & Internet
WYSE S10 Power up problem
Replacing C38 will fix the problem. It's a Lytics SMD Capacitor 47uF/10.3V.
Oct 26, 2007 | WYSE Winterm S30 Network Terminal
E-100 AC adaptor faulty??
It may be your main battery is dead. I had the same problems and had to replace the main battery and everything worked fine!
Sep 05, 2005 | Casio Cassiopeia E-100 Pocket PC
Casio Cassiopeia E-105 Pocket PC Logo
Top Casio Computers & Internet Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
