Question about Samsung SyncMaster 245BW Monitor
I have this same SyncMaster model 225BW. I have the power cord, but need the Audio Power cable. I just was online with Samsung and THEY COULDN'T HELP ME??? All I want to know is what input/output specs I need to know so I can buy the proper one. Amps and Volts...they said they did not have this info. Any ideas? Mike
  • 11,361 Answers
It is just an audio cable with mini stereo phone plugs at both ends. You can get it at the RadioShack. One end goes into the Audio line in at the monitor, and another end goes to the audion line out (Green jack) on the PC SOUND card.
Posted on Sep 13, 2010
  • jylp Mar 04, 2011
    No, you should have done some research before you assumed.. This monitor doesn't have the audio input jack you're thinking about, it does have a audio POWER input I think it is an input at lease.. it may be an output but I doubt it..
Samsung Syncmaster 225BW startup problem
reinstall the driver. what was the last update that you applied in general. revert back to LKGC last known good configuration.
Mar 07, 2014 | Samsung SyncMaster 225BW 22-Inch LCD...
Power cable for sumsung syncmaster 960bf dc14v
http://www.ebay.co.uk/itm/14V-AC-power-adapter-Samsung-syncmaster-960BF-19in-LCD-CORD-supply-charger-DC-NE-/250897192700?pt=LH_DefaultDomain_0&hash=item3a6aa356fc
Or open it and replace the end capacitors.
Apr 07, 2012 | Samsung Computers & Internet
ALWAYS SHOW " 1024 X 768" HERZT. CAN'T SHOW
Hi, Same problem as mine! Are u suing the original Samsung CX511n cable? If not, video will not appear! Buy the original cable!
Jun 15, 2011 | Samsung SyncMaster 510N/512N,SyncMaster...
My SyncMaster 225BW 22 inch does unpredictable displays when my PC is first started up, or awakes from sleep mode. (display is shifted to the right, or brightness is stuck on very low, etc.). Before, I...
The brightness issues with this model are usually caused by a power supply that is starting to fail. There are parts called capacitors that start to fail, when this happens the power supply can not get to the correct voltage outputs that it needs to properly run the back light bulbs. This type of problem causes either the dim display that you have or a wavy display until the unit can stabilize the output voltage. It is repairable if you can do a little soldering. You will need to replace the 5 capacitors on the power supply board. Here is a link to a repair guide for that unit that shows what needs to be replaced.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-225bw-22-monitor/
This is an easy fix, about 15 minutes once you have the parts.
Feb 04, 2011 | Samsung 225BW LCD Monitor
Need to know if this monitor is hdcp compatible. Can it support hdcp?
here is the List of compatible monitors with their brand names :
Sony
Sony MFM-HT205
Viewsonic
Viewsonic VP2330wb
Viewsonic VP231WB
Viewsonic N3250W
Dell
Dell 2007WFP
Dell 2407WFP
Dell 2707WFP
Dell 3007WFP
Dell E228WFP
Dell E207WFP
Acer
Acer Al2423W
Asus
Asus MW221U
Asus MW201U
Gateway
Gateway FPD1975W
Gateway FPD2185W
Gateway FPD2485W
Gateway FPD2275W
HP
HP LP3065
HP f2105
Samsung
Samsung 205BW
Samsung 214T
Samsung 215TW
Samsung 242MP
Samsung 244T(US version)
Samsung SyncMaster 244T
Samsung 320P-Black
Samsung 930MP
Samsung 940MW
Samsung 940BW
Samsung Syncmaster 931BW
Samsung syncmaster 226BW
BenQ
BenQ FP241W
BenQ FP241WZ (Includes 1:1 pixel mapping)
BenQ FP241VW (Includes 1:1 pixel mapping)
BenQ FP222WH (Unconfirmed)
BenQ FP94VW (Unconfirmed)
LG
LG L245WP
LG L226WTX
NEC
NEC Multisync 20WMGX2
If you can tell your monitor manufacturers name and model no i can let you know about it. Anyhow the above information will help you.
Mar 11, 2010 | Polyview MNTR |17'LCD V17D Monitor
Samsung syncmaster 225bw 22'' when turned on has a white screen after about3 min i sut it off in the back of the screen for about a min it came back on like nothing was wrong. what is the problem.
This is a symptom indicating the power supply is about to fail. We have a step by step repair guide posted on our web site at: www.ccl-la.com Th repair will require replacing 5 small parts that will need to be soldered on the board. If you don't want to do the repair yourself we do offer a repair service for this model for $30 plus return shipping. If you have any questions contact us at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 08, 2010 | Samsung 225BW LCD Monitor
Prior to this past week my Samsung SyncMaster 225BW monitor's display came on almost instantly when turned on. Now it takes at least 30 seconds to reach full brightness. What is the most likely cause ...
kmzwolski, NO, NO, NO!!!! Do NOT wait. Use your warranty NOW!!! Do not let them off the hook. Could be any of the things you mentioned, plus "cold", intermittant solder joint, thermally/vibration fracture of solder joint on printed circuit board (SMPS/inverter circuit) Let me know how you fair with SAMSUNG. lmistyrel on aim.com or 12fixlouie on fixya.
Dec 16, 2009 | Samsung Computers & Internet
Hi, i have Samsung SyncMaster 225BW monitor and while using Microsoft word it stop working. On off button blinking with blue light.. However when i plug/unplug the video cable nothing happens. Regards...
There r problem with your CPU not from Monitor might be any hardware failure at that moment.Pls restart the system after that if display is coming or not if display is not coming might be RAM chip is faulty replace it with goods one.If display still not coming then problem with your Motherboard.pls get it repair by vendor.
Nov 17, 2009 | Samsung SyncMaster 203B LCD Monitor
Samsung SyncMaster 245BW Monitor Logo
352 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
