Question about Samsung 6345 Copier SCX6345 Printer
Printer says to install staple cartridge when the staple cartridge is properly installed. What causes this?
  • pls_rputman Sep 13, 2010
    None of these is the problem. I have properly inserted a new staple cartridge and I know it is inserted into the machine properly. Any other suggestions?
    President:
  • 2,777 Answers
This is caused by something being tripped up in the sensor on the unit. It is usually indicative of failed sensor actually. Try unplugging the power from the wall on this printer, waiting at least 90 seconds, then replugging it in. Does it still get the error? You can try taking the staple cartridge out while it is on, turning the system off, then unplugging it again with the staple cartridge removed. Then plug it back in, power it back up and put in the new staple cartridge again. If it still has the error, the last resort would be to try another staple cartridge altogether, but rather than make that investment, at that point I'd call Samsung and set up a service appointment, because it will either need a new staple cartridge or replacement of that sensor that detects it. Either one can be done by the technician and that way you don't waste time and money trying yet another cartridge when it may just have the same error. Since this is a business class product you need to call them at 1-866-SAM4BIZ(726-4249)
Posted on Sep 13, 2010
  • 182 Answers
The problem could be possibly due 2-3 reason
A) the plastic locking tab is not closed properly while you inserted the new staple cartridge
B)The staple cartrdge is not fitted properly
C)The Used staple cartridge was not replace properly
To solve this
Remove the cartridge and re-insert it while making sure that after fitting it you lock the lockin tab
Tun off the printer and re-start it
Hope this would help...if not please reply...we can perform further troubleshooting
My hp m3035 stapler is not working
Sounds like the cartridge is not feeding properly. I have seen a few of them fail. Remove the staple cartridge and tap it a few times on a table, you might be able to loosen up the staples, if not, purchase a new staple cartridge.
Oct 09, 2015 | HP Office Equipment & Supplies
Konica monolta c650 wont fold
Saddel stich (Church program and staples in the middle)? or corner? Or booklet with two staple on the on left hand side? Saddel stick requires paper in landscape.. Check the staple cartridge. ensure both cartridge are securely installed.
Aug 29, 2014 | Konica Minolta bizhub Office Equipment &...
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
HOW TO INSTALL STAPLES
Canon Image Runners have staple cartridges that can easily be installed. Just look at the area indicated on the lcd screen for location of where the staple cartridge is to be installed. Simply pull the used cartridge out with a gentle tug, then replace with the new one by simply pushing the cartridge in at a slight angle.
Hope this helps. :)
Sep 29, 2010 | Canon imageRUNNER 4570 Copier
My 84 year-old mother has an Officejet 6300 printer. She is too old to figure out tech support, so she as asked me to write you. Recently, one of her cartridges was shown as empty. I instructed her...
You need to remove the cartridges, remove the print head (it might drip ink on you so be prepared), thoroughly clean and dry the electrical contacts on the print head, and return the print head then the cartridges to the machine. This has worked for us before.
Sep 28, 2010 | HP Photosmart C6380 All-In-One InkJet...
My ip90 says that cartriges are not installed properly. I have tried replace them, but get the same error. What could cause this?
mcdevito75 here, Don"t know too much about printers but the printer could have just gotton a wrong electrical message during change of Cartridges. Try to remove electric to the printer shut it down and re--start do this a;so with the vartridges out of the printer. Also check with Radio Shack, Staples for advice.
Jun 23, 2010 | Canon PIXMA iP90 Mobile Printer
MFX-2830 Black and White Copier: How do you replace a staple cartridge on a Muratec...
Open front door of the Finisher Unit. Over to the left beside the 2 green knobs you will see the Staple Cartridge. Pull slightly down and out and the cartridge will come out. A new cartridge has to be installed...they cannot be re-filled.
May 17, 2010 | Muratec MFX-2830 Black and White Copier
Ink cart error
Is there a metal wire (clip) hooked on black plastic in the ink carriage? If not, these are notorious for breaking the small plastic hook....when broken, the cartridge is not held in proper postion so printer won't recognize that the ink cartridge is installed......no replacement parts are available for this series of printers.
Jun 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
924 says that black ink cartridge not installed
Hmmm....that sounds to be an issue with the ink cartridges...
You might be using ink cartridges purchased other than Dell or Staples...since these are the two who sell Dell Ink.
If thats not true, then take out both the cartridges in the printer.
Lets isolate the issue
1. Try only Black cartridge on Color slot(right). If you get Install both ink cartridges error, then its an issue with the Black ink cartridges and if you get message that install Black ink cartridge then its an issue with the prrinter.
2. Now install only color cartridge on Black cartridges slot(left), If you get color cartridge missing then its an issue with the Black cartridges which you are using and if you get install both ink cartridges then its an issue with the black slot on printer.
3. If issue found to be with Black ink cartridge then wipe the Nozzles(bottom) of the ink cartridge with lint free cotton cloth from back to front 5-6 times.
4. Also try replacing the ink cartridges purchased only from Dell or from Staples. Purchased from somewhere else or refilled might not work.
5. If issue found to be with printer, then i would suggest you to purchase new printer then.
Hope this fix the issue
Aug 14, 2008 | Dell 924 All-in-One InkJet Printer
Samsung 6345 Copier SCX6345 Printer Logo
53 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
