Question about Ovens
Thermador oven clock display went dimm 486752 and no parts.
Rotu
  • 175 Answers
SOURCE: Oven timer and temperature display dim
You need a new display/relay board package they have come up with to solve this problem. The parts generally run about $250, and if you have it repalced by a service company, the total will be a little less than $500. The display is really easy to change by itself, but you must change the realy board with it, and it has about 40 different wires going to it. If you draw a diagram as you take the wires off, and label them carefully, it isn't that hard to do the whole job..just take your time. This is a problem thermadore/dacor ovens have had for some time. If it isn't too old you may try calling thermadore and see if they are willing to at least buy you the parts, as this is a known problem. Good Luck!
Posted on Nov 24, 2006
  • 213 Answers
SOURCE: thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Posted on Nov 19, 2007
SOURCE: Thermador sm272zs microwave/oven combo
Woke up this morning and heard my smw272 built-in oven beeping. Oh no! First the display (but at least the oven worked) now the oven is beeping (fault signal according to manual) and the thing is dead except for the microwave and warming bin. The only way to turn off the incessant beeping--which was driving me crazy--was to go outside to the fuse box and turn off the circuit to the oven. Yeah, I stopped the beeping but now I'm at the mercy of the unscrupulous service repairman--was quoted a flat fee to drive out and a hefty hourly rate (i.e., "value added" service charge). OUCH! Hey folks, please follow my simple advice if you want to avoid making a big mistake: NO MORE THERMADORS. RUN--DON'T WALK AWAY FROM THIS BRAND!!!
Pruneau
Posted on Dec 30, 2007
SOURCE: Thermador SC301T oven
First, I want to thank everyone with your information to repair the Thermador SC301. If you want to spend the $171.99 and send the part to CG Industries, that is an easier way out.
I chose the cheap route and ordered up a few capacitors, 68 micro farad 50 V, 470 micro farad 35 V and 22 micro farad 35 V. The originals rated 105 degrees would have cost under $3.00 from Mouser Electronics but I spent under $7.00 for the capacitors to get an extra set and I bought the 135 C degrees for the two 470 mf and the 68 mf but decided not to use that one due to the larger size--a couple of mm larger in diameter. I spent $15 for UPS for 2 days delivery and $10 for a Radio Shack 15 Walt soldering iron. I had some electronic rosin solder from before. It was pretty easy to remove the 4 capacitors trying not to overheat and trying to get the excess solder away from the board so you could mount the new capacitor terminal throug the holes on the printed circuit board. It took over 5 hours to research all of this information but I was able to repair the board and assemble back in less than an hour. I have had 4 years of basic electronics in high school 35 years ago. Most important is to label all the parts such as harnesses and other wiring and know that the capacitors have a polarity indicator printed on the jacket and be sure to mount this correctly.
Posted on Oct 19, 2009
  • 19 Answers
SOURCE: Jenn-air expressions wall oven clock went dim, now out completely
If you haven't already, replace the capacitors on the clock module. I had the same problem with a similar oven. See this link for more info:
http://www.badcaps.net/forum/showthread.php?t=7902
Posted on Feb 04, 2010
Thermadore oven won't heat
Have you set the clock?
warmest regards
Richard The Repairman
Mar 27, 2014 | Thermador Ovens
Set clock on an old thermador double convection oven
Turn the main knob counter clock wise until the display reads "clock", then turn the same knob clockwise to set the time. When done, push the select button.
Feb 25, 2012 | Thermador SMW272 Electric Double Oven
Thermador oven display fc
Try turning off your circuit breaker for a few minutes. Then, after you reset it, push clear, then set your clock.
Sep 11, 2009 | Thermador SMW272 Electric Double Oven
Thermador SC302 double oven the top oven is not getting hot
We've had the same problem. I contacted a local sales room and they contacted their rep who promptly mailed the replacement parts I requested (I'd looked up the part numbers already). Now I'm waiting to find someone who will reasonably do the work.
Aug 10, 2009 | Thermador SMW272 Electric Double Oven
Dim LED on SC301 Thermador
local part whare house can sell you a "dim clock" kit for your machine i believe it contains a new display board as well new wire harness
Mar 14, 2009 | Thermador SC302T Electric Double Oven
Temp/clock display faided
its the display theat is fading away. I've haad meter's do the same thing after awhile and there's nothing you or I can do. Thanks for using Fixya
Dec 23, 2008 | Thermador SC302T Electric Double Oven
Thermador SCD272 Panel Dimm Problem
a phone call to thermadore is definatly an option open to you, im sure they will handle you situation as do all manufactures on a case by case basis, at only 2 yrs old you may even fall under a part warr from them,not to mention as you explain to them how you see the amount of others with hte same issue, is quite possible they offer you a concession, worth the 800 number call and the 20min time to do it
Nov 03, 2008 | Thermador SMW272 Electric Double Oven
Thermador oven problems
Greetings, this JUST happened to me.
The solution was to break the circuit at the breaker panel for 1 minute, reset the clock, and the unit seems to work now.
Nov 20, 2007 | Thermador Ovens
Thermador model sc272t oven 2 doors have dim display
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Pruneau
Aug 18, 2007 | Thermador SMW272 Electric Double Oven
Ovens Logo
302 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
