Question about HP Photosmart C3180 All-In-One InkJet Printer
C3180 feeding paper but not printing
The drivers are up to date. It worked fine until I changed the black ink cartlidge. I've gone thru all the troubleshooting avenues I can find, yet it keeps feeding paper through without printing. Any ideas?
Thanks
  • 5 more comments
  • ma jackson May 20, 2008
    printer does not print and lifts up more than one sheet at a time and it feeds without printing
  • marysphi Sep 09, 2008
    Same here. Feeding but not printing.
  • patrik b Sep 27, 2008
    The printer is feeding with standard A4 paper just until have way. Then printer stops and the power button starts to blink If I try to turn of the printer it spit out the paper and takes a new sheet. Power button stays blinking until power supply is disconnected.
  • schuylerwitt Nov 12, 2008
    I have just about the same problem, mine did that and then every job went on que and while trying to print says error, pstopdffilter stopped unexpectedly with a status 1.  What the hell does that mean, and how do I fix it?  HP customer service sucks.  Hopefully you guys will be of some help.   :)
    Witt
  • shamaria Mar 02, 2009
    I have the same problem the other guy did. The paper feeds through until halfway, and then the light starts to blink and nothing comes out. The check paper light doesn't even come on anymore. It won't print or copy; I haven't tried to scan.
  • Ben Johnson May 11, 2010
    Is there anything on this page that looks like what you're seeing?
    http://h10025.www1.hp.com/ewfrf/wc/docum...
  • Anonymous Mar 28, 2014
    will feed paper and papers in correct way no ink showing
I ended up unplugging the unit for a few minutes. It fixed the problem...
Posted on Oct 01, 2008
HP 3n1 keeps printing out a
This happens regularly in some models when the alignment of paper is not done correctly. If the cartridge does not have a good print quality, the scanner can not correctly read the alignment and alignment repeated several times until you get it right.
Check the alignment with cartridges in excellent condition.
Feb 28, 2012 | HP Photosmart C3180 All-In-One InkJet...
Hp photosmart c3180 will not feed paper to print
Might be paper pick up roller warn out, clean or replace it.. For tech guys only: check for separation pad acting while service station performing? if not remove service station check separation pad leaver notch not in proper position in service station, position it. remove total mechanism up to pick up assm.. check pick up roller spring.. tension the spring. fix it back.. verify the print ...
Jan 09, 2012 | HP Photosmart C3180 All-In-One InkJet...
My printer has the blue light on the lightbult and low toner (but ink is fine) - it will not print anything. The stuff sits in the print queue and i have to eventually delete it. The report will print...
My work-around for this problem is to feed paper in manually through the front. I turn the printer off and make sure all paper is out of the printer. When you turn the printer on - and the blue light stays lit (if it doesn't turn it off and wait - I've had to wait quite some time sometimes).. then manually feed 1 sheet of paper in the manual feed tray at the front. When the paper is inserted... you should be fine to print - and keep feeding paper in until you get your job. If you miss - you might need to hit the "continue" (triangle button)..
I've been trying to find out why mine locks up - and why it keeps jamming - but this is a tried and proven menthod - althought it is annoying it might help you for now.. Good luck
Sep 02, 2011 | Lexmark E250dn Laser Printer
Changing the black cartridge also require change of color
The printer is very good.I ve been using it for approx 1 year now.The printer works on a combination of both black as well as colour ink cartridges.If any of the cartridge is empty,printer will not print.Kindly call Kodak with your problems at 1800 421 6699 and they will take care of the issue for you.
Oct 04, 2009 | Kodak ESP 5 Printer
Mac OS 10.5.8 HP Photosmart C3180 does not print
Exactly what I'm experiencing, it goes though all the motions, but no ink is on the paper. I just installed 10.5.8 last night on my Mac Pro. The drivers are up to date, but no ink hits the paper.
Sep 22, 2009 | HP Photosmart C3180 All-In-One InkJet...
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
Paper Jam Photosmart C3180
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | HP Photosmart C3180 All-In-One InkJet...
After changing the ink cartridge, my printer wouldn't print.
change cartridge from 60 to 60l and printer wouldn't recognize cartridges
Dec 21, 2008 | HP Photosmart C3180 All-In-One InkJet...
Nothing comes out when I print
Epson 777 will not print. No paper jam. Power light flashing; red error light on steady. Paper does not feed; if paper supply is placed deeper in feed, entire paper supply (about 12 sheets) feeds thru as one sheet normally would , without printing.
Feb 27, 2008 | Epson Stylus Color 777i InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
980 people viewed this question
Ben Johnson
