Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Pioneer SD-P40 Hello all,With all the power outages and so forth my Pioneer SD-P40 has decided not to power up completely. I have the green power light but no sound or picture. I have done the easy stuff like check fuses and a the TP's with given voltages, all read good on my DVM but it is almost impossible to find any schematics or photofacts for this TV. Any suggestions? Thanks, Bryan 1986 unit has been sitting for 10 years since failed. Kept blowing 1.25 A fuse on flyback transformer board. Recently cleaned and reseated all connectors and now powers up giving audio, tunes channels, but still blows same fuse, no video. No wires appear shorted, no components appear over heates or burned out... pulled flyback board and see no cold solder joints. Is there a common problem fix for this unit that could fix this problem? What should I look for and are there any module/board replacements available?
    Genius:
  • 2,035 Answers
There may be high current in the board as one of the component may be weak or out of order , please check the voltage out of the at the fuse holder , Please change the board ASAP..... or call
For Service & Support Please Contact Us At: Pioneer SD-P40 - 310397382support-icon_small.jpg 1925 E. Dominguez St.
Long Beach, CA 90810
Call (800) 421-1404
Or contact us by e-mail.
Hours of operation:
24 hours a day for most services. Hours for product service, product operation and parts inquires:
Mon. - Fri. 9:00 a.m. - 7:30 p.m. Eastern (all product inquiries).
Sat. - Sun. 11:00 a.m. - 7:30 p.m. Eastern (plasma, DVD recorder, navigation inquiries only).
Posted on May 15, 2008
    Genius:
  • 1,226 Answers
Pioneer SD-P40 , got a shorted power from the input regulator. Please do a continuity test from the input power to the vertical and horizontal projection board.
the 1986 units. there is still problem on that since it always blow the the fuse u inserted. means theres a part that is not function properly better that only the fuse always blown out to protect some circuit. do also the continuity test on that ..speifically on the voltage regulator . this only the mean cause of fuse blown out.
melnavz
  • 2,296 Answers
I wouldn't think there are any boards available for this model.
Try to install a 60W light instead of the 1.25A fuse, that will allow you to check for some components overheating and shorting out.
It could have a shorted flyback transformer.
2 Suggested Answers
SOURCE: Pioneer SD-P40
My Pioner SD-P40 goes off after a few minutes of playing. Unplug and plug back in then it comes on with remote and goes out again What should I Do.
Posted on May 17, 2008
Hello, my HP Pavilion desktop PC m9177c went dead after a power outage. Right before the outage, it was on and connected to a surge protector. After the outage, it is completely dead as if there is no...
You may have to change its power supply however, try this first
1. change your UPS coz the old one may have been damaged.
if that still didn't work, change your power supply
Nov 28, 2010 | HP Pavilion a710n (PJ508AA) PC Desktop
THE TV STAYS OFF
If the sound keeps working your probably just need a new lamp, if the sound does not stay on, you probably to get someone to fix the power supply.
Sep 02, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer sd-533hd5, STKs changed, getting blue screen but not pict
Did you have double image before changing the stk's ? If not then there was no need to change them.. Pioneers are known for bad solder connections especially in the power supply section.. suggest checking that when you changed the stk's that there are no solder bridges between the pins of either stk ICs
Dec 22, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
When tv is turned on green light comes on then goes to standby
had the same problem on mine.
Found loose solder terminals on the main power transformer, resoldered fixed it up about 5 min.
Nov 01, 2008 | Pioneer SD-532HD5 53" Rear Projection...
Sd-p40
Have you tried to do set the convergence with a pattern on the screen? Some tv's have the pattern built right into the setup. Others do it auto just by pushing a button. Adjusting the pattern on one side of the screen may affect the other side, depending on how far out of whack it is.
Magnets (speakers) near by will play havoc with convergence.
Peter
Aug 04, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
High voltage
Why? Please give accurate symptoms and I probably can help...T.
Oct 24, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P40
Check your hori out put transistor if shorted replace NTE2973, this should be output number.if you need any more help let me know!
Oct 12, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P40
Check to see if Q118 is shorted on video/defl pc
Aug 21, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
46 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
