Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
Dryer thumps on every rotation of the drum - Maytag MDE9700AYW Neptune 174 Electric Dryer
Inspect the weld seam in the drum. Mine split in the front leaving a small hole. The thumping is the drum wheels running over the broken seam.
Posted on Dec 07, 2010
  • Timothy Healey
    Timothy Healey Feb 10, 2014
    anyway to fix small crack in drum and how to keep it from happing again
Maytag dryer
If this is the metal drum model of Maytag dryer, then the drum is likely out of round and will be evidenced by a broken spot weld on the seam where the drum is welded. I have had to replace mine for that very issue. Not cheap! Hope that is not the case for yours, but just rotate the drum by hand and you will see a high and low spot during the rotation. If the high and low spots are consistent, you know your drum is out of round and likely has busted spot welds. You can run it like that for a while if you can stand the thumping. If no out of round condition, then check the roller alignment and see if the bracket got tweaked not allowing it to rest on the drum. Again...if it touche s the drum and then leaves the drum as the drum is rotate by hand, the drum is out of round. Hope this helps
Feb 15, 2017 | Maytag Dryers
Creda simplicity TVU1 tumble dryer is making a thumping noise while drying
Hi dave hemming.
I do not believe it is a bearing that is causing your thumping noise
No...you do not need a new drum...all you need is new drum rollers
You probably have a flat spot on one of the rollers, it will make the thumping sound when the drum rotates.
Go to the following webpage and get your drum rollers and install them and that should take care of the noise you are hearing
Please take time to rate me
Bud
http://www.appliancepartspros.com/index.aspx
Oct 13, 2012 | Dryers
Maytag neptune dryer making banging noise on each rotation on the left side facing the front. its almost like a thumping noise what do i need to do please?
The drum baffle screw has unscrewed itself and the head is thumping against the inside top panel. Pull door, lift lid, rotate drum to find screw sticking out and tighten.
Aug 03, 2010 | Maytag MDE5500AYW Electric Dryer
Thumping/rubbing sound in drum
The belt tensioner roller has a flat spot caused by a worn bearing that catches and stops whilet the drum is turning. This causes the flat spot and the noise its making. You can purchase a new roller by itself and do change the belt the same time too
Apr 08, 2010 | Frigidaire Electric Dryer
Dryer makes a clunking noise while drying. Is it possible that the drum is "Out of balance"?
Most likely if it is a thump thump noise a drum roller has a flat spot and is causing the noise.
The dryer will operate ok but it will be loud.
A service call may be needed to replace all 4 drum rollers.
Jan 06, 2010 | LG DLE2532W Electric Dryer
Thumping sound from loose drum
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 10, 2009 | LG DLE5977 Electric Dryer
Electric Dryer Thumps
that gap in the drum is most likly hitting a roller in the back of dryer so my best guess is replace drum if you feel it's not that change the felt around door thank you for useing fixya rate me
Apr 01, 2009 | Dryers
Lg Gas dryer Dlg0332w drum making noise
The drum on my DLG0332W was also making noise at the back of the dryer...kind of a thump thump thump as the drum rotated. My dryer is only 4 years old. I got brave, downloaded the service manual and opened up the dryer. I found that the drum's welded seam was starting to separate where the roller wheels were coming into contact with the drum at the back of the dryer. Looks like a new drum is in order.
Mar 01, 2009 | LG DLE2532W Electric Dryer
ASKO t700 dryer thumping sound
usually whin you get one thump (or a quick double thump) you have a dent in the roller surface of the drum itself. Easiest way to check this is to unplug the unit and take the top off by removing the 3 torx screws in the rear, then lifting the top off. Once the top is off look at the very front edge of the drum as you rotate the whole thing by hand. If you see any irregularities on the surface, thats your problem. If you see nothing it could be a bad motor or roller, but its unlikely if its happening in the same place on the rotation evry time. What has usually happened with dents in the surface of the drum is that the unit was set down too hard (or dropped) and the wheels it rests on dented the metal they ride on. If thats the case the only solution is to replace the drum or live with it .Good Luck!
Feb 10, 2007 | Asko T700 Electric Commercial Dryer
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
397 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
