Question about Canon FAX-JX200
My fax machine is reading "auto print off" Rec in Memory? I have swiched the machine off and mucked around but no luck. Can i fix this myself. My nearest service technician is 2.5 hours away??
    Guru:
  • Canon Master
  • 452 Answers
To print fax in memory press the stop button (red triangel)
Posted on Oct 16, 2010
JX500 says "rec'd in memory" and "auto print
I can email you the user manual for future use. LBrown18062@hotmail.com Lawrence Brown
Printing All Unprinted Documents in Memory
1 Press [Menu].
2 Use [up] or [down] to select , then press [Start/Copy].
3 Use [up] or [down] to select .
4 Press [Start/Copy].
The fax prints the documents one at a time, after each the reception number is displayed on
the LCD.
5 After printing, the LCD displays .
6 Press [*] to delete the previous printed documents.
If you want to keep the documents in memory, press [#].
Sep 29, 2011 | Canon FAX-JX200
My canon jx210p fax receives all faxes into memory. how do i stop this and get it to print all recieved faxes straight away?
Hey!
If u briefly press the on/off button it will say auto print on and will print the faxes as soon as it comes in!
Good Luck!
Jan 12, 2011 | Office Equipment & Supplies
My fax machine is in auto print off mode how do i switch it to auto recieve mode
Hi; Receiving to Memory Temporarily You can enable memory receiving feature temporarily. Received faxes will not be printed automatically.
  1. Press [ON/OFF] to select <AUTO PRINT OFF>.
  2. ??? The fax starts receiving documents in memory.
  3. ??? To cancel, press [ON/OFF] again.
  4. ??? When <AUTO PRINT OFF> is cancelled, received faxes will be printed automatically.
good luck
Oct 15, 2010 | Canon FAX-JX200
My work canon jx 300 is storing faxes. Auto print
Press MENU and # - this is service mode.Find CLEAR, and OK, then select clear ALL. After that fax returns to factory sett.
You will need to reenter your settings, but it should work.
Jun 24, 2010 | Canon FAX-JX200
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Want to know how to turn off memory so that we receive fax right away; it keeps going into memory when it comes through instead of just printing.
Prior to your issue is due to on the machine panel there is auto receive and manual receive ,kindly select the auto .Good luck ,pls rate me for the good deed!!!!!!!
Sep 21, 2009 | Brother IntelliFAX 5750e Laser Fax
Incoming fax goes to memory and display panel Auto Print Off
If you press the on /off button once the machine will switch to auto print on,if you keep the on/off button in the machine will switch on or off.
Apr 08, 2009 | Canon FAX-JX200
Uf 7000 panasonic fax machine
try doing an all job clear on the machine and getting a dealer to update the firmware to the newest one.
Jul 07, 2008 | Panasonic Office Equipment & Supplies
Can not receive faxes
On the front of your machine, you will see a button that says "In/Out". I bet someone hit that by mistake, turning off auto-answer.
Nov 05, 2007 | Panasonic Panafax UF-595 Plain Paper Laser...
Canon FAX-JX200 Logo
163 people viewed this question
old marine
old marine
