Question about Brother MFC 210C All-In-One InkJet Printer
The back cover on printer
Can you please tell me how it goes on........boyfriend took off to get paperjam and dont know how to put it back on...........i need help
    Genius:
  • 2,035 Answers
Posted on May 15, 2008
My laser printer shows a paperjam after half of the paper has exited the printer. please help
1. Remove right,left & back covers, clean sensors & check flag spring b1a3ef63-09f0-401a-942c-d096aff6de2d.jpgposition as shown in fig..
Oct 12, 2013 | HP LaserJet 1020 Printer
I have a cannon mp150 printer and am getting a E3 alarm code. I do not have a paper jam and don't know how to fix this
Sometimes a printer may give the paperjam error massage. When this happens you must go thruogh the ritual of clearing paper jam before the printer will respond to the print command again.
So you do the following:
Put of printer and unplug its power cable.
Open all printer covers. (front, back, top as ti applies to your printer)
Close them back firmly
Plug back the power plug
Try printing again.
Good Luck & God bless!
Feb 11, 2011 | Canon PIXMA MP150 All-In-One InkJet...
We have hp color laserjet 2600n. paperjam at the top of printer dont know how to open to get jam out.
There should be a button or buttons on the left and right side of the front cover at the top of the cover or on the side of the printer. That door has to be opened to remove jammed paper, as you probably know. You might also try this website for additional instructions. http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?locale=en_US&prodTypeId=18972&prodSeriesId=446153
Oct 21, 2010 | Office Equipment & Supplies
The printer says back door open when its not
Open the front cover and remove the drum and toner(cartridge) There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
Jul 14, 2010 | Brother MFC-7220 All-In-One Laser Printer
Hiya my brother dcp 7010 printer keeps saying back cover open please shut cover but there is no cover open how can i fix it pls
This is happening because there is a paperjam in the machine and its covering the sensor for the back cover. Open the front cover of the machine and remove the drum and toner, then you can remove the paperjam.
May 06, 2010 | Brother DCP 7010 Multifunction Laser...
Paperjam in hp 1000 printer
two reason in paperjam 1200 series printer
one some senser not working so remove back sight cover and clean dust help with air blower.
and paper pick roller is not working
first you remove paper pick roller
and change direction of paper pick roller
means change direction means just opposite site use.
i think solve your problem.
Apr 10, 2010 | HP LaserJet 1200 Printer
A thin strip came out of my hp psc 2210 all-in-1 (printer)
This is a tough one! It's called the ENCODER strip. The covers must come off. It goes in back of the ink cartridges.
It has to be threaded in betwwen the ink carrier and the carriage ribbon cable assembly, then hooked to the frame.
Jan 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
Paperjam...dejammed
I think I have the Dell version of this dumb printer. There is a plastic spring loaded lever that tells the printer when paper is passing through and has left the feed rollers. You will have to remove some screws and deal with clever plastic tension grips and a few harnesses but once you break it down you will see the spring hanging there and the plastic lever blocking an infra sensor. Just look at it and you will figure out how it goes back into place. Move it a few times before putting it all back together. Here's a pic of mine.
Sep 28, 2008 | Lexmark X6150 All-In-One InkJet Printer
Cartridge Jam
The only thing you can do with this is make sure that there are no foreign objects that could be blocking the movement of the cartridge head. And when you insert the cartridge back, make sure you hear a clicking sound on both the cartridge and the cartridge cover when you insert it. Power down then power back up... make sure all covers are closed when you power back up. If it gives the same message, the printers sensors may be bad and it will require service or replacement. So, check with your manufacturer for warranty options.
Sep 05, 2008 | HP PSC 2175 All-In-One InkJet Printer
Paperjam then no power
unplug it..both cables..wait around 1 min..try it again. got backup?
Feb 10, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
35 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
