Question about White Sewing Sewing Machines
Myleshow to thread bobbin on a white 1202 it has stay in place bobbin
    Genius:
  • 1,788 Answers
Go to www.singerco.com and click on support, you will be able to download your manual for free. Singer is wonderful like that, I hope your questions on you machine. Good luck to you and happy sewing.
Mary
Posted on Sep 13, 2010
Using metallic thread, metallic needle. Bobbin case will not engage bobbin to bring up thread to needle. Bobbin is in correctly.
When using this slippery thread it is possible you need to change things a little. To change I mean you will have to stay with a straight stitch and place your needle at the left side of the plate. It may need to be placed on the right if the hook is rotating the opposite direction. Give it a try both ways to see which way works better. Anyway, you will need to stay with a straight stitch. When you first attempt to bring your bobbin thread up you need to hold on to the upper thread.
Dec 01, 2014 | Janome Janoe Deco Coputer 2011 DC2011
How to thread the bobbin
Remove the Bobbin carrier. Place the bobbin in the carrier so the thread dispenses in a counterclockwise direction. Pull about 8" of thread free. Now, pull the thread through the metal brackets (tension) and place the assembly back in the sewing machine. Before you put it back, now is a good time to put a drop of oil on the race track.
Oct 27, 2014 | Singer Sewing Machines
Tried to thread the bobbin but the machine just have the sound but not doing anything
are you sure you followed all steps? Make sure you followed the
threading diagram correctly. You must pull your thread through a hole in the bobbin,threading from the inside of the bobbin to the out side .hold the thread on the outside of the bobbin and wrap thread around the bobbin shank twice. Hold the thread in place and find the groove on the bobbins' outside then match that to the "wire" on the spindle of the winder. You will then disconnect the drive by turning the small knob inside the hand wheel. Next ,you will push the bobbin spindle against the small wheel to create traction to turn and fill the bobbin. My guess is that either the bobbin was not in place or you forgot to push the winder against the traction area. Happy sewing.
May 14, 2014 | White Sewing 1409 Mechanical Sewing...
HOW DO YOU CHANGE FROM ONE COLOUR BOBBIN TO THE PREFILLED NEXT COLOUR BOBBIN
hold thread end w/3" length and put the it in the bobbin case and make sure its unwinding clockwise..Feed thread thru the higher left metal notch and pull to lower left notch and make sure the thread stays behind the spring slot and leave about 4"tail...put bobbin in its place lining up the white dots close the case and turn the wheel to drive down needle holding the needle on the machine base losely and draw the bobbin thread up
Mar 22, 2013 | As Seen On TV Sewing Genie Mechanical...
How do I thread my white 765 top and bottom
The bobbin is held in a removable bobbin case. If the bobbin case is already out of the machine, place the bobbin in the bobbin case such that the thread will come off clockwise. Leave a couple of inches of thread loose. Then pull the end of the thread down into the cross slot and thread it through the tension spring and into the delivery eye.
Next make sure the presser foot is up and the needle is in the highest position. Push the slide plate up. Hold the latch in the center of the bobbin case and place it over the center stud with the finger opposite the notch in the shuttle race. Release the latch in the center and press down on the bobbin case until you hear a click when the latch catches the groove. Leave a 2-3" length of thread extending out of the bobbin case and push the slide plate down. (Reverse the steps to remove the bobbin case.)
To thread the needle, place a spool on the spool pin with the needle bar fully up. I try to place the spool on the pin so that the little catch is out of the way. (The catch holds the end of the thread when the spool isn't in use.) Bring the thread through the guide loop on the top of the machine and then down through the thread guide on the right side of the tension discs. Bring the thread back up on the left side of the tension discs through the check spring and through the thread guide. Bring the thread through the hole (eye) in the take up lever (from right to left). Then bring the thread down through all of the guides down the face of the machine to the needle. Finally thread the needle from left to right. Pull a few inches of thread through the needle. (I find the threading of the needle to be easiest if the thread has been cut at an angle after threading the machine.)
The manual for the White 765 is available from Singer's support site. The direct link to the manual is http://www.singerco.com/uploads/download/827_white-765-x.pdf . See page 6 of the manual and the subsequent pages for pictures.
I hope this helps.
Nov 18, 2011 | White Sewing Sewing Machines
How to wind bobbin on white 1418
1 Release the stop-motion knob on the right side of the sewing machine by turning it oward you.2 Place a spool of thread of your choice on the spool pin located toward the back of the sewing machine.3 Pull thread from the spool through the threading knob on the top of the machine.4 Pull 2 to 3 inches of thread through one of the holes on the bobbin. Hand-wrap thread around the bobbin in an anti-clockwise direction five or six times.5 Place the wrapped bobbin on the bobbin spindle.6 Push the winder spindle to the right, against the stopper, and depress the foot pedal to begin winding.7 Wind bobbin until completed, then return winder spindle to its original position.8 Tighten the stop-motion knob.
Oct 14, 2011 | White Sewing 1418 Mechanical Sewing...
I bought my daughter a White sew E-Z so she can have fun on her first sewing machine. However there is no manual and no instructions on how to thread the bobin. the bobin just sits on its flat side to go...
Check the model number of the machine. White sewing machine manuals are available from Singer at http://www.singerco.com/accessories/instruction-manuals . Enter the model number and click Search.
The White Sew E-Z model W338 manual is available here: http://www.singerco.com/uploads/download/705_white-338-x.pdf .
Unlike some machines this one doesn't really need the bobbin threaded. Place the bobbin in the bobbin holder and leave about 5" of thread extended out from the bobbin holder. With the bobbin compartment still open, lower the presser foot and turn the handwheel to move the threaded needle through the stitch cycle. (I find holding the threads helps; normally, you'll feel them pulling under your fingers.) When the needle has returned to the top of the path, lift the presser foot. Then pull both threads around to the front (the bobbin thread should wrap around the top thread). Then move the threads to the back of the presser foot.
If the needle isn't catching the bobbin thread, first try a new needle (bent or dull needles don't always function properly). Next check the bobbin holder for nicks or other damage. There is a small hook on the bobbin holder that should be where the top and bottom threads intertwine. Under rare circumstances, you will find that the bobbin tension of the bobbin holder is misadjusted. This can interfere with the bobbin thread twisting properly. There is a little set screw that allows you can tighten or loosen the bobbin tension as needed. Adjusting the screw is to be avoided when possible and done in small increments (1/8 turn) if needed. It's easy to strip the threads for the set screw and end up needing to replace the bobbin holder.
I hope this helps.
Jul 13, 2011 | White Sewing Sewing Machines
How to thread bobbin on a white 1202 it has stay in place bobbin
Go to www.singerco.com and download a free manual. Please rate me. Thank you Singer is a great site and are very generous to allow downloads for free.
Sep 13, 2010 | White Sewing Sewing Machines
Want pick up my bobbin
re-thread the top thread
when putting in the bobbin, make sure you put it in right,
hold the bobbin between you thumb and first finger of your right hand when you pull the thread with left hand it should rotate the bobbin counter clockwise.
If you run your machine all day you need to clean under the bobbin case,
Take the cover plate off, take out the bobbin case and clean under, i take a q-tip with machine oil and rub around the inside of the metal case and around the bobbin case,
replace the plastic bobbin case making sure it's in right, turn the hand wheel by hand, the case should stay still and the inside will move, the needle should not hit anything
put all back together and try again
if the bobbin turns clockwise you are going to have problems
if this helps please rate it
thanks,
good luck
moni
May 09, 2009 | White Sewing White 4400 Computerized...
Bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Aug 17, 2008 | Sewing Machines
Sewing Machines Logo
20 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
