Question about Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD - YELLOW light indicator of what problem?
Cyberhome CH-DVD 300 DVD does not turn on.... power is evident as the indicator light is YELLOW, turns to RED when attempting to power-on at button.
Thank you
  • 3 more comments
  • Danagood May 15, 2008
    I have the same problem with Cyberhome CH-DVD 300 DVD in that unit will not turn on with a green light. The light is yellow or red and because the unit will not 'turn on' as indicated by green light none of the buttons work . i cannot get the DVD that is inside of the unit to play (or opent the unit to release it) because of this .
  • fisherchick May 18, 2008
    same exact problem here. you can get your DVD back by opening the door with a screw driver via the 'EMERGENCY' slot on the bottom.
    BUT, it still does not power up. the indicator light just changes color when pressing buttons. How do we get it to turn on?.....
  • loracle Apr 12, 2009
    Could you please explain this fix again SLOWLY and in layman's terms :-). I've found the power supply you mentioned but have no idea what to do with it (or whether I should order it) since the dvd player does NOT come with its own power supply! Please help. Thanks.
  • kirstinQ Apr 17, 2009
    The power light remains yellow whether turned on or off (rather than being red for off and green for on.) No button will turn it on or get it to open the door. Anxious to see if these solutions will/might work!
  • kirstinQ May 11, 2010
    These solutions seem harder than I am up for... thinking this player may have seen it's lifetime and simply get a new one. Think I only spent about $40 on it 4 years ago anyway!
Marlin P Jones & Assoc. Inc.. has a 5V 2.2A /12V 1.5A cord power supply that will fit into the space where the original power supply was! Lists for $6.95 but online price was $2.95. Works great! Connect 12V supply to the yellow lead and the 5V to the red lead of the output connector, black is ground, common to both supplies. Use QC terminals to the power cord input terminals, remove the cable clamp and the power supply will nestle beautifully in the space without need for support. (Remove the old circuit board plastic (3) and rear brass standoffs and use the front brass standoff for the output cable shield ground connection. (Part No. is 15955-PS) I bought two because I have a 2nd Cyberhome CD-DVD 300 which hasn't crapped out yet.
Posted on Dec 16, 2008
Repaired my Cyberhome 300 DVD by replacing power supply board with small power supply used for external hard drive providing 1.5 amps at 5VDC and 1.5amps at 12VDC. The red wire from DVD is 5 VDC, yellow is 12 VDC. The two black wires are common negative for 5 and 12 volts. Thanks to MARVF55 for the tip!
Posted on Jul 06, 2009
  • 80 Answers
It's a power supply problem pls change the power supply capacitors like 1000mfd/16v
Posted on Jan 01, 2015
I have the same problem, but I know what the cause is. Mine stopped working right after we had a power failure, so I suspected a power problem. The +5V DC supply from the power supply pcb is only at 3V. I removed the wires for the +5V and patched in a USB cable to provide +5V and it is now working fine. I noticed that one of the capacitors on the power supply pcb is buldging on the top, so it's probably bad. I'm going to try to replace it and see if it fixes the problem. The simple answer is that your power supply pcb is not working correctly.
Posted on May 18, 2008
SOURCE:
Door won;t open
I have a yellow light .on the front, and the disc tray won't
open. I have a cyberhome DVD player,CH-DVD 300.
Oct 28, 2012 | Cyberhome CH-DVD 300 DVD Player
Tip
Cyberhome CH-DVD 300 Manual Have you lost your Cyberhome CH-DVD 300 DVD Player...
Have you lost your Cyberhome CH-DVD 300 DVD Player Owners Manual?
Would you like a digital, searchable version of the users guide?
The pdf version of the Cyberhome CH-DVD 300 DVD player is available here.
I hope that helps.
on Apr 10, 2010 | Cyberhome CH-DVD 300 DVD Player
My Cyberhome CH DVD-300 DVD player continually displays a yellow light. It will not turn on, eject the cd or do anything at all and I cannot find my manual. I have a library rental movie in it that needs...
The Power Supply is not working properly, . The 2200 microfarad capacitor close to the 5v,12v output is most likely the culprit... Easy to replace, just get a spare from radio shack for about 2 bucks and if you know how to solder then it shouldn't be a problem...
Nov 26, 2010 | Cyberhome CH-DVD 300 DVD Player
Power light is yellow and won't respond
Return or take to a tv repair, most fix dvd players.
Dec 23, 2009 | Cyberhome CH-DVD 300 DVD Player
Status light yellow, won't power on
Hey, I just unplugged my Cyberhome DVD for about 5 minutes and replugged it in. It is working fine. Try it with yours and let me know..
Lcamp518@zoominternet.net
Feb 08, 2009 | Cyberhome CH-DVD 300 DVD Player
Cyberhome dvd ch-300 dvd player
Not sure, but I believe the 2.75 volts you have should be 5.0 volts.
May want to check capacitors on power supply.
The output connector on the supply may also be labeled with
the correct volatges for reference. COnstant orange light may be
indicating the +5v is low.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
No light fuse is good unit (1) want power up and unit (2) red light but want do nothing both are connected to AC power source
The CH DVD300 is notorious for power supply problem. If this the case, you can send the power supply to be repaired for around $15.00 to:
Wired Communications
31211 N. 77th Way
Scottsdale, AZ, 85262
Tel. 480-209-1700
Contact them before sending anything.
Francis
Oct 04, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
7,395 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
