Can you reset a pc power supply - Computers & Internet
  • Computers & ... Master
  • 5,660 Answers
Is your question referring to resetting a Power Supply, as you would per se a surge protector?
In most cases No.
Most Power Supply's do not use a Circuit Breaker, nor a Fuse.
(May have to take that statement back, on some of the new Power Supply's though)
Once the Power Supply has gone bad, (Weak Voltage power rail, usually), it's time to buy a new one.
I find that Electrolytic Capacitors have failed, in most failed Power Supply's. However, that is just my general observation over the past 20 years.
Low quality Electrolytic Capacitors are used.
(Radial Aluminum Electrolytic Capacitor's)
These capacitors are used as Filters for the Power Supply. They filter the incoming AC electricity, and the outgoing DC electricity the Power Supply has converted.
(Input Stage, and Output Stage)
To wit:
The Power Supply used in a personal computer is an SMPS.
Switched-Mode Power Supply,
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Here on the above Wikipedia page for SMPS, you will see a photo to the top right, of a typical SMPS.
You can click on the photo to enlarge.
(You can enlarge twice)
You are looking at a top view of a typical SMPS, that has the cover removed.
The large Electrolytic Capacitors, indicated by the letter B, are for the Input Stage.
The smaller Electrolytic Capacitors, indicated by the letter E, are for the Output Stage.
NEVER open a Power Supply, (SMPS), and try to work on it.
Even when a capacitor is removed from power, (Power Supply unplugged from power), the capacitors hold a charge for a LONG time.
Weeks, Months, sometimes over a year!
If your fingers touch the terminals on the bottom of a capacitor, (Radial Aluminum Electrolytic Capacitor), the charge could be released to YOU!
If your fingers complete a circuit that one, or more capacitors are in, the charge could be released to YOU!
The released charge can be a BAD shock to FATAL!
There are also MOSFET's, and Rectifier Bridge's that can go bad in an SMPS.
There is a Proper way to discharge a capacitor. I will not detail it here because of the safety issue to you.
The best method is to replace the Power Supply.
Tell me the computer manufacturer name, and Model Number, and I will look up what Power Supply it uses, if the info is available.
(90 percent of the time it is)
For any questions please post in a Comment.
Regards,
joecoolvette
Posted on Sep 13, 2010
Will not start
smor4u,
There is no reset or fuse to reset. You may need to get replacement power supply. If the computer is plugged into a power strip or surge protector you can bypass it and plug the system directly into a wall outlet and power up.
Power Supply Light-on the back of the computer.
The light is a Green Light by the power supply.
Power Supply light is lit by a signal in the power supply called Power_Good (PG).
If the Power Supply Light Led is not light up, the power supply is defective.
If you need to replace the power supply you can contact the Dell Spare Parts Department at 1-877-717-3355bsat4ube4gblqiaaaaasuvork5cyii= or click the link below.
Dell Spare Parts
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 15, 2013 | Dell Vostro 420 Desktop Computer
Tower won't turn on. There is a green light on the back near the power cord that's flashing green.
Pull the power cord out and allow it to reset. If you still have issues you may need to replace your power supply.
Aug 05, 2010 | HP Compaq Presario Media Center SR1750NX...
My Philips IQON PC won't start up. There is power
Yes. Basically your power supply stops working. You really need to replace it.
Mar 09, 2010 | Computers & Internet
My power supply is blinking green light and my PC has no power
plug your pc directly to your wall outlet and see if it turns on. If it works, then the problem is your power supply. If power supply has a reset button, press it and try again. If pc does not turn on when plugged to wall outlet, then power supply for pc may be out.
Feb 16, 2010 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Power switching off randomly and requires date reset on PC
You are saying that after a power loss you have to set date again in BIOS? Probably you need to change the battery on the mainboard, disconnect the power cable and press the power on several times, so that not to drop the battery accidently and make a short circuit. You might have to reenter all the BIOS settings after that. And if the power is switching off, only for the PC, might be a defective PSU unit. Every unit after the power supply shouldn't reset the date.
Nov 10, 2009 | Fujitsu Siemens (B14L5105E035A) Power...
It is not coming on,the power botton appaers softer
There may be a problem with your power supply being either on the fritz, or underpowered. Try flipping a red switch on the power supply on and off, and that will reset the power supply, briefly. Otherwise, see about using a computer vacuum to clear any dust out, which could be making your power supply have to work harder, or possibly interfering with connections.
Oct 22, 2009 | E-Machines eMachines Desktop PC
Power problem
your power supply is possibly dead unplug it and smell the vents if you get a strange smell it has poped a capacitor or 2 try another psu from another pc loose before you buy a new one many a time a voltage spike may have done more damage depending where it got to
Jun 06, 2008 | HP Compaq Presario Media Center SR1750NX...
I have an ASRock AM2NF6G-VSTA motherboard that will not power up. I upgraded the system and powered it up and it ran fine, except I had not received the new upgrade power supply. I received and installed...
check the power supplies you have if it is working well. then reset cmos.
then if it would not power on, your motherboard maybe a deadset (meaning dead/unusable).
Mar 12, 2008 | Computers & Internet
How to reset my computer
Look in the manual and see which jumper resets the bios. That is all I can figure out from your descriptive and well written question.
Jan 28, 2008 | IBM FRU POWER/RESET CARD 73P6310 Power...
My pc problems
Maybe something is wrong with your power supply. If power supply get old, it will restart the computer by itself. Try to borrow a friend's power supply and test it out.
Nov 09, 2007 | PC Chips P23G Motherboard
Computers & Internet Logo
265 people viewed this question
David Payne
David Payne
