Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony Bravia Kdl-40V2500
I have two hdmi ports and both do not produce a picture. I called a service tech who said that the "Bez Board" was damaged/cracked when I wall mounted the tv. I see no crack on the back of the TV. They want $500 to fix it, which is 1/3 the price of the tv. Am I being ripped off?
    Problem Solver:
  • 61 Answers
No probably not The Brd he is talking about is the BU Brd does your component video work
Posted on May 15, 2008
  • Mark Hammonds May 15, 2008
    This set is a very easy set to troubleshoot if streaming component in works it is the same as HDMI even better i think because it is shielded better
My hdmi connections stopped working.Servive tech set up component only
Somewhere buried in the setup menu is a source selection. When you find it select the proper HDMI connection as the source.
Sep 29, 2014 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Lines vertically on lcd sony tv
2 possibilities for that kind of problem,
LCD panel is defective or T-Con board is bad.
Please replace T-Con board in TV and if problem still exist, LCD panel is bad.
It is qualified TV tech job to replace board in TV so call local TV tech.
Thanks.
Nov 02, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
HDMI socket board replacement- someone has squashed the pins in the socket. Lower Port and upper port - doesn't work at all. Suspect the circuit board....
you would have to get a exchange module that has the av ports as well as hdmi jacks you can either order a service manuel to obtain the part numbers or call sony have your model and serial at hand when you call
Oct 24, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
No digital picture for Sony KDL-40v2500
These tv's receive digital on the atsc 8vsb. Do you know what there broadcasting in New Zealand ? It could be that a Sony tech there can fix your problem. The TV can be set-up for a different digital broadcast and Sony is all over the world even in New Zealand .
May 04, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Have a new Sony Bravia KDL-40W500 keeps turning off into standby mode with 8 flashes.
There is some confusion on the model (KDL-40W500 vs. KDL-40V2500), so I will direct this toward the 40V2500.
On the KDL-40V2500, an 8X blink means the scan processer has gone bad, and the BU board needs to be replaced. If the problem is intermittent, the the AU board might be the problem, but if it all the time, bank on the BU.
A competent repair shop should be able to help you, or you can try calling Sony directly for assitance.
Hope this helps you...
Jan 05, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How to enable "Bravia Sync" on KDL-40V2500
I also have the same problem and was wondering if you ever found out the answer to this problem Peter?
Dec 18, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Repairing Sony LCD tv
Try getting the TV menu on the screen. If you can't, it's probably the LCD panel or backlighting issues. If you look very closely sometimes you can see a dark image if it's backlighting issues.
If you can bring up the menu, but all inputs are black, then the problem is more towards the electronics. Usually computer VGA and HDMI inputs bypass a lot of electronics and may point you to a video switching issue in the TV. If this is all Greek, consider a trained service company. Choose a platinum servicer since they are Sony trained, certified and held to much higher standards than other authorized servicers. Sony expects them to make first attempt fix within 5 days of contacting Sony. Usually the right part is sent to the tech prior to them setting the repair appointment. Compare that with the others and you will see a clear difference.
Jul 27, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia 40"
Do you have a cable or satellite box connected to the tv?
Dec 31, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
133 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
