Question about Kohler Cimarron Comfort Height elongated 1.6 gpf toilet with Class Six tech
I installed this toilet one year ago it has wooked fine untill today. now it flush.I pulled it up from the floor checked out the drain and toilet ,reinstalled, still will not flush properly. Water does not swirl in the bowl.Water in the tank is at right leavel.
  • 707 Answers
You may have a slight restriction stuck in the goosneck of the toilet or in the pipe elbow.........If you have little ones they seem to test our knowledge sometimes.Hope this helps.
Posted on Sep 14, 2010
How do you know if a toilet should be replaced?
Your toilet should be just fine,I have 2 toilets that run to a septic tank,the newer one gets clogged up cause of the new regulations that only 1.2 gallons is used per flush which means it needs to be flushed more often than the old type I have,the new one,they are problematic.On your case,are you using a lot of paper,if so,then flush more often.Your plunger may have a pin hole in it,not letting you unclogged,Flush toilet,then plunge quickly.You may need a new plugger,they have better types now,Walmart has them.
Aug 20, 2017 | Home
My toilet flushes, then the water in the bowl drains over 4-5 minutes resulting in sewer gas smells.
Look inside the tank under the lid, it sounds like the flapper that lets the water into the bowl is getting hung up on something when you flush. It could be the flushing lever. This would cause the flapper to stay open letting water to just pour into the open sewer line. It should be a simple fix. Just see what is binding the flapper & make an adjustment.
Dec 02, 2015 | Duravit Starck 2 One-Piece Toilet
I have a toto toilet , model MS604114CEFG , bought 2 years ago . Last night , when I flushed it , the water level in the toilet bowl did not come down . It stay high in the bowl . In the tank reservoi
If the toilet is the only fixture in the bathroom group that is having an issue, then there is a partial blockage in Strap of toilet or in drain pipe close to toilet. If other fixtures are showing sluggish drainage, then the main drainage line is clogged. If all is fine with tub lav shower etc., pull toilet from floor and carefully turn upside down, and look to see if anything is visable. if so remove it and reinstall with new seal(wax ring). Also, look into pipe and see if any water is standing in it. If water is standing in pipe, the drain line is clogged and must be rodded(snaked) out to cure problem
Nov 14, 2014 | Toto MS604114CEFG01 UltraMax II Toilet,...
How to change toilet bowl
Shut off water to tank and drain tank by flushing , then use a sponge to soak up any left. Disconnect water line, then 2 of 1/2" nuts at base of toilet ( floor ) . Lift toilet off, clean old wax off toilet and flange at floor, and install new wax gasket. Set toilet down straight and aligned with gasket and flange as well as studs. Make sure toilet is all way down on new wax gasket ( sit on it and move around a bit until toilet feels steady on floor ) then put nuts washers etc back on and snug it up. Don't tighten too much and snap base, just good and snug.
Aug 03, 2012 | Home
I have a jacuzzi espree (EZ36959) toilet which was installed in November of last year. It has worked fine until November of this year. It will not flush solid waste. I have to add hot water and wait...
did any one run camera threw? This usually means obstruction.If you have really hard water.holes around rim could be restricted.cure is muratic asid.be very careful.rarely,a pluged vent stack.once I found a big dip in a long drain line slowing flush.
Dec 18, 2010 | Jacuzzi BK37959 White Era?? Two-Piece...
My new K-4632 AA toilet flushes fine and refills the bowl. The tank equipment works as it should. Problem is, the bowl completely empties in about 5 minutes and stays empty until the next flush. The...
Hello. Your toilet is leaking through the flush valve. This is a serious issue as it will use a huge amount of water every day. Check to be sure there is not an obstruction in the tank and if you can not find one, call the plumber. J.
Oct 12, 2010 | Kohler Home
When you sit on the ring it veers off to the left and you are left sitting there crooked. How do we adjust it?
See if nuts on studs on bottom where it mounts to the floor & flange are loose. If they are loose tighten both of them evenly. If they are tight you will need to replace wax ring that is between toilet & floor.Turn off shutoff water valve to toilet. Flush once holding down handle to let tank drain. Remove both nuts & lift toilet off flange. Remove wax ring. Scrape all old wax off toilet & floor flange. Install new wax ring. Set down toilet on ring & snug nuts evenly. Sit on seat & apply your weight evenly to distribute wax & level. Retighten nuts. Turn water back on. Allow tank to refill. Flush toilet & check for leaks.
Sep 30, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
Toilet wont flush completely. it may take 4 times or more to flush solids. i at first thought this was related to heavy rains we had been receiving in the area over a period of about 4 months. 2 days...
there is no air release. the vent must be clogged somewhere. you can take a hose up there and see if it drains all the way or floods over. since the tub drain has a trap and the toilet itself is a trap, there has to bee a good amount of air pressure coming up without a release. i would say an obstruction. possibly at the junction of the main and the vent.
Nov 09, 2009 | Eljer 091-2190-43 Platinum Patriot...
My toilet only a few weeks old. It flushes fine
Sorry, but the only reasonable solution is to assume that the toilet was installed incorrectly and the wax seal misplaced. Or the sewer line is clogged. I would remove the toilet and take a look-see. A plumber could use a snake to check for obstructions.
Jun 19, 2009 | Home
Toilet flushng
it sounds to me like depending on the flapper installed that your flush arm chain is too long and the flapper is not flipping back far enough to do its job. Take the lid off the tank and rotate the flapper up and back to see if it flushes correctly. if it does then your chain is too long and should be shortened. Hope this helps please rate me
Jan 10, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Kohler Cimarron Comfort Height elongated 1.6 gpf toilet with Class Six tech Logo
129 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
