Question about Emerson EWF2004 20" TV
We can hear it but the picture is very narrow in the middle if the screen
  • Emerson Master
  • 1,229 Answers
If you are referring to a horizontal line or bar, you will have to resolder the vertical IC. You may also need to replace the electrolytic capacitors that are almost next to the same IC. Now if you have a black vertical bars on the left and to the right side of the screen, you have a horizontal problem. Bad electrolytic capacitors and bad resistors in the horizontal deflection area of the TV board! Thanks for asking and give me a few hands of support!
Posted on Sep 13, 2010
Black screen
Check its back-light inverter and back-light CCFL lamps.
Jul 12, 2013 | Sceptre X32BV-Naga 32 in. LCD TV
Hello! I bought a acer lcd monitor lcd S243HL! The whole time the screen worked really well! Then suddenly my screen picture remained narrower! Copper read-only text in the middle of the screen! As if a...
Disconnect the monitor from the computer, unplug and then replug it in. See if the entire screen lights, if only for a second. That will tell you whether it is the monitor itself that is bad, or the signal it gets from the computer. If the former, there is not much you can do but check the settings manually on the side or back of the monitor. If it is the latter, check the cable (s) and the plug connection. Check all pins on the connector. Do not know from your question, whether this is a vga, dvi or hdmi connection to computer. Good luck
Jan 10, 2018 | Acer S243HL 24 inch Monitor
Picture on screen is narrow and I cannot select normal view
use menue button on tv if this does not work change main board in tv
Jun 05, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Screen shrinks down to a narrow band of light in
You have bad grounds on the vertical IC. The grounds will need resoldering and check for weak caps near the ic.....they will overheat the ic...creating the bad grounds. Solder will expand and contract with heat and cooling of a tv. HMMMM you could also have a cold solder elsewhere on the board. Search and you shall find.
Aug 16, 2009 | Televison & Video
Screen on JVC TV distorted
There is an Aspect button on the Remote for the TV. This button will fix this problem.
Aspect function strectches the picture horizontally or vertically to get rid of black bars in some movies. Sometimes this is good....sometimes bad
May 19, 2009 | JVC Televison & Video
Distorted picture
On the middle circuit board towards rear is a metal wavy plate.On the back side(actually towards screen when looking from rear of unit),the middle screw has a ground wire(light brown) that is loose.
Apr 08, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Hitachi projection screen 98modle
bump...anybody? I am having trouble locating my convection boards that so many other people have replaced on other models to solve there problems.
Feb 05, 2008 | Hitachi 50FX48B 50" Rear Projection...
TV SCREEN PICTURE SMALLER
Yes you have a problem I'm afraid in the pincussion or horizontal width circuit. These circuits usually have alot of high voltage in them and is not a safe place to be experiementing around with. Most of the time, with a problem like this, there are bad capacitors or a correction transistor has failed. If the set is over a few years buy a new one. Good Luck
Jun 04, 2007 | Bush 5693D 24" TV
Emerson EWF2004 20" TV Logo
176 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
