Question about HP Compaq 2510p Notebook
BIOS failed to update - HP Compaq 2510p Notebook
Toshiba Satellite A200-FE008C bios update failed
You can't. The mother board is now dead. You will need a new bios chip.
Jan 22, 2014 | Toshiba Satellite Pro A200-EZ2204X...
Gateway 504gr bios update failed
You maybe using the wrong version, it's already updated, or simply can not be upgraded.
Unless there is a TRUE need to flash, and usually there is not, I would stay away from. So many people try and fail, only to wipe the CMOS, leaving the system useless. Here is some sound advice on the subject.
http://www.techrepublic.com/blog/10things/10-common-mistakes-you-should-avoid-when-flashing-your-bios/357
Oct 01, 2012 | Gateway 504GR PC Desktop
Changed out the motherboard reformatted a blank hardrive, No issues in the reformat.Installed drivers then updated the bios.Currently will only boot to bios briefly then shuts down.Tried resetting the bios...
Sounds like your BIOS update did not complete successfully. Head to the board manufacturers website and check if there is some way you can reload the BIOS and recover from this. Most boards now have dual bios which means that if one bios chip fails or an update fails, you can reload the stored BIOS through the other chip. If you are unable to recover from a failed BIOS update, you may need to purchase a replacement BIOS chip from the board manufacturer. You may even be able to reload the original BIOS onto the chip through your local PC repair store so give them a call and enquire..
May 21, 2010 | HP Compaq Presario SR1300NX (PP195AA) PC...
I was given an L500. It powers but fails to POST, this happened after a recommended BIOS update. Any kind of debug ports or something to sort this out?
After a BIOS update, if it fails to post, the BIOS update got corrupted. This happens (rarely) and when it does, the only thing that can be done is to remove the BIOS chip and have it burned at a local repair shop (or sent into Toshiba for a replacement). Without the BIOS functioning properly, the computer can do nothing at all. If your BIOS is not on a removable chip, then the computer will have to be sent to Toshiba to have the BIOS replaced.
May 12, 2010 | Toshiba Satellite L500 Series Notebook
Will not power up after failed bios update
If the BIOS update failed it could have damaged the CMOS chip & may not be repairable without a new CMOS chip.
Oct 21, 2009 | Computers & Internet
I can't update my Travelmate 8104WLMi. Every time
it is not flashable then you dont ever update your bios unless it has a problem.
Oct 19, 2009 | Acer TravelMate 8104WLMi Notebook
Update bios systemsoft mobilepro bios ver1.01 for sis - the laptop can't boot from cd xp
your bios is not updated properly. try again. make sure there is no power problem while updating. update bios from sis official site only.
but i dint understand wheather u already updated n the after updating its not working or u r planning to update. if u r planning to update then see that the ata cable is connected to motherboard. set first boot device as cd rom. then check if it fails go for bios update.
Apr 29, 2009 | Asrock K7S8XE+ SIS748 (K7S8XE+RAID)...
Bios update failed, computer will not start
the bios of your motherboard has gone , replace it,
Oct 25, 2008 | Toshiba Satellite M115-S3094 Notebook
Blank sreen after bios update
Update BIOS with Boot Block Error Code/Beep:
Definitions Error Beeps Error Code (Port 80H)
BIOS updated successfully. 2L-1S-1L F1h
The BIOS file size is not equal to the BIOS ROM size; wrong BIOS file. 1L-1S F1h
The BIOS file can't be read; it is defective. 1L-2S F2h
The model ID is mismatched; wrong BIOS file. 3S F3h
The BIOS ROM has failed to be erased. Try to flash again. 2L-1S E1h
The BIOS ROM has failed to be programmed. Try to flash again. 2L-2S E2h
No diskette, or cannot locate the BIOS file.
Try to use a new formatted diskette and copy the BIOS file again. 2S D1h
Mar 27, 2008 | Acer Aspire 1640Z Notebook
HP Compaq 2510p Notebook Logo
816 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
