Question about Maytag SkyBox MBV1976A Beverage Dispenser
Skybox Our skybox is very hot on both sides. I am afraid it is going to start a fire. Never noticed the heat it was giving off until now. Anyone had this problem?
  • Scott R Jul 27, 2008
    I had the -compressor kicking off after 10 seconds- problem and replaced the starter cap. Now the compressor stays on but it also gets extremely hot on the sides. too hot to even touch. Could it be low on freon if the fan is ok or is the compressor shot. I don't remeber it being close to this hot before.
  • Anonymous Jul 31, 2008
    inside is not cold anymore
  • 770 Answers
This is normal this is how it releases the heat it removed from the inside the Condenser coil is embedded in the liner
Posted on May 19, 2008
Skybox f3
Im having same trouble mate, bit of a novice on this only had it few days any luck doing it??
Mar 30, 2013 | DBPOWER Skybox F3 Digital HD PVR Satellite...
Skybox sides are hot
Yes this unit has a static condenser coil built into the walls,the warmer it is in your house the warmer the outside will be.
Aug 23, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Sky Box by Maytag panels
I have some panels for sale $25 new in the box. Please see my posting on Craigslist Des Moines Iowa or give me a call 515-707-3551.
Michelle bailey
May 26, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox start relay is bad
you need to change the overload relay ---- there is a company called appliancezone.com
they sell the overload relay unit with all the parts for $26.00
email me back if you cant find it---- put in the model # for the skybox unit and you will see the item
item # 4387835
this is the problem -- if this relay goes bad the compressor will stay on and not supply cold air to the unit ----
Dec 16, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox
Check the compressor to see if it is running. Is it too hot to touch. If so make sure the condensor has proper air circulation to cool it. If the compressor is cool to touch and running. There is a leak in the refrigerant sealed system.The compressor isn`t doing any work because there isn`t any refrigerant in it, therefore will not creat much heat. A humming and clicking sound is typical of an overheated or damaged compressor. If the compressor isn`t running and connot start. It could be a bad start relay on the side of the compressor or a bad compressor. If you can remove the start relay, shake it and listen for a rattle sound. If it rattles, it is bad.If not. then it is time consider the cost of a repairman verses the value of the appliance. Check the cost of repair to the sealed system or maybe even replacing the compressor.I hope I have been of some help to you.
Nov 12, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox Broken Door Hinge
go to www.apdepot.com enter your model number and a parts breakdown will come up you can order parts and they will ship to you
Sep 20, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Bogus Skybox
Sorry, I don't have this problem.
My skybox flashed all lights and did not deliver.
I cleaned mildew off the photo eye on the left side of the tray flap
(very small) and my skybox continues to work to this day.
Aug 06, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox
For the soda name tags, I pulled logos off the internet and printed them the correct size on 20-pound paper. Different paper gives different translucence, so you might have to experiment to get the right amount of light coming through.
PS: thanks for the part no. on the relay
Apr 21, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Replacement for Skybox compressor
The solution is too change refrigertants, Enbraco makes the PW4.5hk11. its a little over sized and you'll need to switch to hot shot.
Mar 11, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox Beverage Dispenser/Refrigerator
TroJo, Try PartSelect.com for Skybox parts. I ordered a part on Monday night and installed it on Wednesday night. The parts are not that hard to find. Appliance repair services can replace your compressor or add freon. Be sure you have plenty of ventilation behind your machine. Jonmon
Mar 23, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
93 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
