Question about Proform XP 580 Trainer Treadmill
I have a pro form xp 580 treadmill and the incline will not lower. Is there a way to lower it manually?
  • 43 Answers
SOURCE: treadmill not working properly. Incline keeps slipping.
there is a plastic spacer at the rack area on the incline mtr- this white plastic spacer has broken, only recourse u have is to unplug the white wire on incline mtr, and never have a incline, or replace incline mtr when you find out how much the mtr is you might want to walk with out incline- if you was in my area, I have them cheaper
Posted on Jan 08, 2010
SOURCE: Pro Form 745cs Treadmill does not incline
My jack screw needed to be adjusted. It is a long screw about 1" in diameter. If you take the cover off, you should clearly see the jack screw. If you adjust the incline with the cover off, you should see the jack screw rotate. One end of the jack screw may have come out allowing the screw to rotate freely and not raise the incline. If you can reengage the screw, it may work. I don't know if this will help, but I needed to do it.
Posted on Jan 11, 2009
SOURCE: I have a pro-form 550 XL treadmill its in #10 deg.
i ran into the same problem today with another proform model. i shut the machine off and lifted the platform to the stow position and brought it back down, turned it on. it worked fine during a workout. i was using an ifit sd card when it got stuck. were you? just wondering.
Posted on Feb 06, 2010
maxtreadmill
  • 832 Answers
SOURCE: describe how to unfold a treadmill, pro form ex
Hold the upper end of the treadmill with your right hand on the back end of the unit. Using your left hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock knob. Note: You may need to push the handrail to the side slightly. 2. Move in front of the back end and hold the treadmill firmly with both hands, and lower the treadmill to the floor. CAUTION: To decrease the possibility of injury, bend your legs and keep your back straight
Posted on May 31, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have a proform xp 580. when I turn it on,
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
After completing calibration of incline, press the Stop key and then remove the safety key.
Posted on Jun 14, 2010
Can't get my proform xp 580 trainer treadmill out the door
sony ericession text pro ck 15i i want incoming sound incrise (or)...how to sending blooth with video
Nov 20, 2012 | Proform XP 580 Trainer Treadmill
I have a proform xp 580 and my treadmill makes a clicking noise as if it is trying to incline what should i do?
1)Please lube the gear and shaft, very well from elevation motor
2) Test the motor, and replace if necessary.,see for ball bearing and lube
3) Lube the deck belt, and guide for instruction manuals.
4) Test the main switch, and reset button with VOM, for open, test and replace see the diagram how to do it.
God bless you
Jun 08, 2012 | Proform XP 580 Trainer Treadmill
I have the Pro Form 580 Lt Treadmill. I have never been able to program it to play music or much else either.
Dear Sir:
I recomend you to read careully you user manual, and follow the steps.
If you do no have u. instruction download free: www.fitness.manualsonline. com
sincerely. God bless you
Apr 10, 2012 | Proform 580 LT Treadmill
My pro form 580 si won't reach max speed. Why is
Dear Sir:
Adjust the speed sensor very weel see the diagram attached, tigh the connector wires very well, and clean the s. sensor very well.
2) Run the software calibration for easy diagnose , fix it, and trouble.according with your manual instructions.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua.
Apr 03, 2012 | Proform Exercise & Fitness
Pro form 580 SI, power incline runs up as soon as it is plugged in and wont go down using console buttons.
possible it could be in incline senser but most likely the console needs replacing. you should always use a power surge protecter on a treadmill. power surges can blow out 1 resister on those circuit boards and there no good.
Sep 12, 2011 | Proform Exercise & Fitness
Does not turn on. When I press the re-set button, it lights up and then goes off again.
Hello. This happened to me when I bought a Pro-form XP 550, and the solution was very simple - There is a magnectic thingy on the front attached by a string to the treadmill. The thingy needs to be stuck to front of the treadmill for it to work. It's some sort of safety device which cuts out the treadmill if you fall off. Is that it? Stephen.
Oct 31, 2010 | Proform XP 580 Trainer Treadmill
Jun 12, 2010 | Proform XP 580 Trainer Treadmill
Describe how to unfold a treadmill, pro form ex
May 31, 2010 | Proform Exercise & Fitness
Treadmill not working properly. Incline keeps slipping.
Jan 07, 2010 | Proform Quick Burn Pro Treadmill with 12...
Proform XP 580 Trainer Treadmill Logo
98 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
