Question about Venturer Televison & Video
Everytime I start the TV I get a no signal, also can't get the DVD to play? Model #PLV7122 TV/DVD, 22"
  • 21 Answers
Make sure you are on the correct input. Usually there is a input or source button on the TV remote. Put a DVD in and hit the play button on the front of the DVD player so you can see the movie when you know you got it right.
Posted on Sep 13, 2010
Hi, What is the procedure[using remote]to go between TV signal and DVD signal on a Konka model KL22ES62Q TV set cheers John.
Your TV does not appear to be with in inbuilt DVD.
So you must use
(1) TV remote to select input as DVD
(2) Operate your DVD using the DVD remote for eject, play, FF or rw etc.
If you have a universal remote and the codes for the brand of TV and DVD are programmed, you can control using one remote.
Oct 13, 2016 | Konka Televison & Video
Dvd connection
Check the connection wire for any internal conductor break. Check it with a multimeter.
Aug 13, 2012 | Sceptre X400BV-FHD 40 in. LCD TV
I recently bought some dvds from the UK. JVC XV-S65 dvd player will not play them. It reads 'region error' everytime I try to play the discs. HELP!
The dvds discs u bought from the UK is play on only the DVD player that play PAL signal format. Where u live Canada,US or Mexico?DVD players in these countries.It play only NTSC signal format.U can't change DVD players regions format,only can a DVD players that have regions free to play all DVDs discs of the world.
Feb 02, 2011 | Televison & Video
I have a Panasonic DMR-EZ48V and have had many problems with it from day one. It sometimes records a tv program sometimes not. Sometimes plays dvd movies sometimes not. It often freezes up and has to be...
Not having Cable TV would not stop it playing back a DVD. A good TV aerial, with new cable will cure any bad TV signals, but the fact that it is not playing back a DVD everytime tells me that there is something wrong with the unit's mechanism.
The Panasonic engineer in this case doesn't know what he is talking about.
Jun 16, 2017 | Panasonic DMR-EZ48VK DVD Recorder
DVD input channel reads "no signal" when I try to play a DVD
First I would run a dvd cleaner in unit! Second you could take tv apart and look to see if signal cable is loose. the power wire seem fine as it powers up, and accepts an eject dvd.
Feb 28, 2009 | Proscan 32LB30QD 32 in. LCD TV
I have sound but no video when I play DVD's
The picture signal cable should be attached to the TV or maybe the channel is set wrong...Try channel 3 - 4 or channel 90 on TV
Jan 31, 2009 | Bose 3 2 1 GSX System
Panasonic 50? Plazma TV TH 50PZ 800A + Sony Model DAV ? SB 500W
that is possible
the home theater has so many in puts on your dvd and out puts.
there is a way
1 you can buy a vedio/audio converted to rf signals, this will mean both signals entering tv using rf.
2 get your vedio out from dvd and audio out, feed that to a converter, vedio in and audio in okey
Jan 07, 2009 | Sony DAV-SB500W System
Unusable signal
A brand and model would be helpful. However if you have some knowledge on TV's you could try replacing the Jungle IC first. This usually controls the AV inputs on a standard CRT. Probable cause, Static on the Video line. Good Luck. Jus004
Dec 07, 2007 | Televison & Video
Jumping Picture
Does the Sony surround upscale the signal from normal RCA to Component video? If so I have found that sometimes there can be signal sync issue. Meaning the signal that the component video convertor (inside the surround sound unit) sometimes struggles to give a clean component video signal. The TV then struggles to filter the signal correctly resulting in a jumping picture. Try plugging the DVD video only (yellow RCA lead) straight into the plasma and see what happens. You can also try playing with the signal frequency of the plasma, from 50 - 60hz. This will found in the menu of the plasma. Hope this helps. ST
Oct 29, 2007 | Sony DVP-NS530 DVD Player
Televison & Video Logo
179 people viewed this question
Top Venturer Televison & Video Experts
john milligan
Are you a Venturer Televison and Video Expert? Answer questions, earn points and help others
