Question about LG WM-2277HW Front Load Washer
Model #WM 2077CW came up with an LE error display, what is the problem?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the Hall Effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in US). It only takes around half hour to replace it with a new one. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 13, 2010
Le error sensor WM 2277 HS problem and solution please
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Jun 20, 2011 | LG Washing Machines
LG WM 1485FHD with LE error code. Stope washing after 5 or 10 mins and can't get it to complete cycle
Kevin
Jun 14, 2011 | LG WM-1485FHD Front Load Washer
Water still in machine says LE on display
LE error code means Locked Motor Error.
Sometimes this can be cleared by unplugging then plugging back in the machine. If this does not clear it you have a faulty component.
This usually failure of a component called the Hall Effect Sensor which may need to be replaced.
Dec 16, 2010 | LG WM-2277HW Front Load Washer
My LG Intellowasher WM-1280FHD is refusing to spin, even when empty, making strange noises and displaying the code LE. I cannot find the manual to know what this means. Can anyone help?
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 14, 2010 | LG WM-2277HW Front Load Washer
Drum wont rotate
Code LE is a locked motor Error and it is caused by:
• The connector (3-pin, male, white) in the MOTOR
HARNESS is not connected to the connector
(3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors
(3-pin, male, white) in the MOTOR HARNESS
and 4-pin, female, white connector in the MAIN PWB
ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR
ASSEMBLY and MAIN PWB ASSEMBLY is cut (open
circuited).
• The hall sensor is out of order/defective.
If you need a service manual for that you can find on Here.
Lg WM-2277HW
I hope this helps.
Randy
FixYa Support Team
Jun 08, 2010 | LG WM-2277HW Front Load Washer
Washer does not spin and displays an LE error
LE is lock error..This most commonly means that the interlock is faulty...This is component which stops the door from opening during wash, and allows power to the machine when the door is shut..Replacement probably needed..Not a big job...Good luck....Nomess
May 22, 2010 | LG WM-2277HW Front Load Washer
LG Tromm WM2077CW error code LE
No all you have to do is watch how much and what kind of soap you put in that washer...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Apr 15, 2010 | LG WM-2277HW Front Load Washer
LG WM2277HW - ERROR CODE "LE"
Hello remrama,
Please use this link to access the service manual on your display code message ( page 18 ) elaborates on the cause of that message. You should be able to determine which of the few causes may be the culpret,... http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Hope this helps you..
Regards,
Rick
Feb 22, 2009 | LG WM-2277HW Front Load Washer
LG TROMM WM 2077CW LE Error
An LE error is a locked rotor. The hall sensor on the stator part of the motor is not sensing the rotor part of the motor is turning. So the short version is you need a new stator(which has the sensor on it or just the sensor) replaced which should have a 5 year warranty on it so call LG for your nearest authorized service center
Nov 17, 2007 | LG WM1814CW Front Load Washer
LG WM-2277HW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
