Question about Maytag SkyBox MBV1976A Beverage Dispenser
Another Dispensing Problem
I bought a used Skybox three weeks ago. Everything was great. Cold drinks and no jams. Tonight it stopped dispensing. Unit is running and cans are still cold. I press any of the four dispensing buttons and nothing. No light, no jam, etc. I did notice a smell that appears to be coming from the door. I'm guessing a bad board. I found one on-line for $34. Do you think this is my problem? Any other suggestions? Thanks!
  • 2 more comments
  • Harryhead May 17, 2008
    I found that the flapper door sensor had burned out. I actually left a burn mark which was the burning smell I noticed. I replace the sensor and still no luck. Could this be a transformer problem?
  • Harryhead May 19, 2008
    Thanks! My e-mail is udregistrar@yahoo.com
    Thanks! My e-mail is twestend@udayton.edu
  • snookyjen May 30, 2008
    I have pretty much the same problem,  except all my lights work except one, but when you push to dispense nothing happens.  Only one buttons makes a noise like something is going to happen.  Nothing is jammed or anything, it just does nothing.  Can anyone help fix this problem or offer any suggestions?
    Thanks
    Jennifer
    candjsides@hughes.net
I have a similar problem the lights all light up on mine but there is no action what so ever when you hit any of the buttons i have no idea any help would be much abliged
muleboy04@yahoo.com
Posted on Jun 04, 2008
  • 770 Answers
What is your email i will send you the manual so you can troubleshoot it better
Posted on May 19, 2008
  • Gary Davd
    Gary Davd May 19, 2008
    check your email
Maytag Skybox - Dispense Problem/Lights Flashing
I returned the machine to where I bought it. It not only didn't dispense, it also didn't refrigerate. sorry I don't have an answer for you.
Sep 06, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
CAN A SKYBOX 'MAYTAG' BE PERMENENTLY INSTALLED OUTSIDE
The Maytag SkyBox is not a commercial vending machine. It is designed for INDOOR use only. The possibility of electric shock is likely from a unit that has gotten wet. In addition, the electronics are not designed to withstand the outdoor elements.
Aug 10, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox will nat cool below 40 degrees
The likely cause is a heavy frost and ice buildup on the internal evaporator plate behind the dispensing unit. Unplug the unit and open the door for 24 hours. Plug the unit back in, reset the thermostat to the 11:00 position.
Jun 26, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox
For the soda name tags, I pulled logos off the internet and printed them the correct size on 20-pound paper. Different paper gives different translucence, so you might have to experiment to get the right amount of light coming through.
PS: thanks for the part no. on the relay
Apr 21, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox
Looks like I found the answer to the problem of Skybox not dispensing. I replaced the sensor in the dispensing door and my Skybox now works great!
Part is available from partselect.com just look up your Skybox model number, mine was Skybox model MBV1976AAB. The diagram on the website should show you the exploded view of the door section of your Skybox. You are looking for partselect.com part number 901892 or on the exploded view it will be number 21. The Maytag part number is 11001182, board flipper sensor. My Skybox had been down for two years and now works again!
Mar 27, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Lights flashing
The flashing lights usually indicate a jam or the flapper door not met which means a drink already dispensed. Just guessing here, but you may have a board problem. I have removed one dispensing drive motor and if I press that button all lights blink until I open the door and close it. Any chance you have a lot of ice buildup in the back? That could be causing a short or even caused connectors to loosen. A new connector board is $22 on partselect.com but that would again only be a guess. Check some of the other problems listed for other possibilities.
Jan 13, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox Beverage Dispenser/Refrigerator
TroJo, Try PartSelect.com for Skybox parts. I ordered a part on Monday night and installed it on Wednesday night. The parts are not that hard to find. Appliance repair services can replace your compressor or add freon. Be sure you have plenty of ventilation behind your machine. Jonmon
Mar 23, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox won't dispense anything
check the door where the cans come out. there is a sensor or the left side. if it is too far away from the door or if it's broken, it will do exactly what you said. i read somewhere that you can adjust the sensor closer to the door. i just bought one of the last one of these on the shelves 2 days ago and mine won't cool at all. stupid maytag..
Mar 01, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Sky Box Won't dispence
Since it's only one dispensor unit you should be able to eliminate "common" items and find out what controls just that one dispensor. The faint click may be from a bad relay (relay coil works but doesn't pass voltage on contacts). You will likely have to take the thing apart to check the control board. Here's a diagram of the unit so you can see where everything is at. I'd suspect the control board relay that controls that particular dispensor is bad or a loose wire, etc. http://www.partselect.com/Schematics/Maytag/VM10-1.gif
Jan 14, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
147 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
