Question about GE GSS25JEM Side by Side Refrigerator
Gss25jemc defroster not working - GE GSS25JEM Side by Side Refrigerator
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 13, 2010
Why doesn't automatic defrosting work?
There is a defrost timer that starts the defrost cycle. If the timer is not working you will have your situation.
Mar 11, 2016 | Refrigerators
Kenmore sidebyside 53552200 stoped cooling and defrosted completly light still works both frezer and refrigerator not getting cold
It could be stuck in defrost. Check your defrost heater, and see, if it is still hot. If it is, then the defrost timer is stuck. When it goes into defrost, everything, stops working, but the defrost heater and light. As long, as the defrost timer is on, nothing else will work, as far as the compressor, freezer fan, and any cooling/freezing.
Sep 07, 2014 | Kenmore Refrigerators
Freezer works but fridge does not
Lets see if the defrost timer being turned clockwise slowly will force defrost and cause things to get colder. On page 5 of the (click HERE=>ET4WSKXKQ02 Parts Manual ) you will see location 4? That is the 2188371 Defrost Timer
inside the fresh food com[partment at the top and behind the control panel will be the 2188371 Defrost Timer If forcing defrost solves the cooling problem then just replace the 2188371 Defrost Timer and if not we will need to check the 2176942 Defrost Heater Assembly and the 2192096 Defrost Thermostat Don't buy ba defrost thermostat until we discuss a different way of getting one to work should you need one (last resort because of cost) My focus is defrost timer and defrost heater at this point you will not need all the wires on the defrost thermostat should you need one just splice a simple defrost thermostat into the wiring harness. Below is a short movie on testing the defrost heater or click HERE Talk with me and we will get this refrigerator working, Sea Breeze
Refrigerator Defrost Heater Test
Refrigerator Defrost Thermostat Test
Apr 01, 2013 | Whirlpool Refrigerators
What is the difference between self defrost and cyclic defrost.
Hi, Self defrosting is auto defrost with out cycle. It work on controller leads. Cycle defrost timed defrost. It work after certain time The defrost work on evaporator
Jan 23, 2011 | Refrigerators
I INSTALL A DEFROST THERMOSTAT,THAT WERE BAD THE UNIT WORK FOUR DAYS AND STARTED FREEZING UP AGAIN,BY THE WAY THERMOSTAT IS GOOD. JIMMIE
is the fan motor working in freezer ? is the defrost element getting hot to defrost coil completley ?if they are working then the defrost thermostat may not be working correctly .its connected to the coil and has 2 wires, its round, clips on the coil..good luck this t-stat shuts off the defrost element; if coil is defrosted; before the timer finishes its defrost cycle
Aug 24, 2010 | Maytag Refrigerators
How much freon does a GE GSS25JEMC BB refrigerator hold? Part of the service sticker came off.
Good day,
There should be an embossed placard usually inside the fresh food compartment. It is never on a door, since doors can be changed.
It has all the data as to model, serial number and refrigerant charge and type of refrigerant.
Dec 15, 2009 | GE Refrigerators
GSS25JEMC won't get cold
If the compressor doesn't run , but the fan next to it does , then the board is the problem . If you can remove the board , and turn it over , look under the small black boxes , but on the soldered side , and you should see a spot where the solder has heated and moved away from the small terminal . "Resolder" this spot , and reinstall the board and the compressor should come on .
Sep 10, 2009 | Refrigerators
Ge gss25jemc ice in door keeps freezzing up
Flapper door diagram is here, you can see how the spring, etc. work to hold the door closed. http://www.partselect.com/Schematics/GE/00113173i04.gif As for the crushed ice, (item 384) on the next diagram shows the little lever that lifts the side rod on the bin (item 329) to decide if cubes or crushed comes out. The solenoid (item 383) can get frozen up and not move. Take a look where screw (item 371) is, that little square window is where the device that lifts the rod is. Take a hair dryer and heat that area REAL good to melt the frozen solenoid mechanism. Test it every now and then by holding the door light switch off and pressing the cubed selection & lever. You should hear a very loud "clank" as the solenoid pull in to lift the rod on the bin.
Jan 11, 2007 | GE GSS25JEMCC Side by Side
Freezer works, fan works, fridge side not getting cold
Whip, make sure the condensor fan is running in back. It should be running anytime the compressor is running. Check to see if you have a buildup of frost on the back of the freezer panel, this could indicate a defrost issue. This refer is controlled by one main mother board in back. Check these things first and post back. You may have to do some tests on the board...Catriver..post back.
Nov 24, 2006 | GE GSS25JEM Side by Side Refrigerator
GE GSS25JEM Side by Side Refrigerator Logo
133 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
