Question about True GDM-7 Beverage Cooler
My drinks keep exploding - True GDM-7 Beverage Cooler
  • True Master
  • 43,501 Answers
You need to turn the thermostat up ....the drinks are frezzing and that explodes them...
heatman101
Posted on Sep 13, 2010
Get Slim Drinking Coffee!?
Yes, coffee can help you loose weight.
There are many other benefits also like:
a. Reduce cancer risk.
b. Reduce liver cancer.
c. Refreshes mind.
d. Makes you feel light.
e. Helps in reducing weight.
Oct 28, 2016 | Coffee Makers & Espresso Machines
What are the benefits of drinking water in the Morning??
drinking water in the morning has a number of benefits for your overall health of body and mind.
  • It helps you to re hydrate your dehydrated body.
  • It helps your body to flush out toxins.
  • It fires up your metabolism.
  • It fuels your brain.
  • Keeps you regular and relieves constipation.
  • Prevents and cures many disease.
  • It is completely refreshing.
Feb 08, 2016 | Water Dispensing & Filtration
5 houses, 5 different colors, 5 nationalities, 5 beverages, 5 pets, 5 cigars
Get a life, get a blog.
Mar 20, 2014 | Creative Teaching Press Math Logic and...
I have a lemair RS250S fridge only have had it for awhile lost manual need to know which way to turn dial to turn it colder.Please
Hi, From what I can see from my manual, 6 is the coldest temp and 0 is off. We have just had ours on 4.5 and the diet drinks have exploded. So I suggest that you keep it under 4.
HTH
Dec 30, 2010 | Refrigerators
Need to see where thermostate is located have an idea but am not sure where it is the year is 1996 corsica 2.2liter v4
GM Corsica/Beretta 1988-1996 Repair Guide
The thermostat is located inside a housing on the back of the cylinder head. It is not necessary to remove the radiator hose from the thermostat housing when removing the thermostat.
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
Fig. 1: Exploded view of the thermostat and housing assemblies - 2.0L and 2.2L engines
Fig. 3: On 1994 2.3L engines, the thermostat is located in the radiator outlet pipe
Fig. 4: Exploded view of the thermostat and water outlet - 2.2L and 3.1L (VIN T) engines
Fig. 5: Thermostat and coolant outlet mounting - 3.1L (VIN M) engine
I hope help you (remember rated this) Good luck.
Fig. 2: Exploded view of the thermostat, housing and related components -1990-93 2.3L engines
Sep 22, 2010 | 1996 Chevrolet Corsica
Setting are set on 9 and my drinks are still exploding.
Possible that the thermostat control is not reacting to the setting.
so you must check if there is any break or replace the unit.
Sep 13, 2010 | True GDM-7 Beverage Cooler
Drinks in fridge keep exploding
are you sure that they are not filled with dry ice?
Oct 21, 2009 | Haier Refrigerators
How to get to the thermostat on a ford aerostar 93 awd van?? where is it located??
1993 Ford Aerostar 4WD 4.0L MFI 6 Cyl Repair Guide
1. Drain the cooling system with the engine cold.
CAUTION When draining coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
2. Remove the retaining bolts for the thermostat housing. Lift the housing clear and remove the thermostat. It may be easier to clean the gasket mating surfaces with the heater and radiator hoses removed from the thermostat housing.
Exploded view of the thermostat housing on the 2.3L engine
Exploded view of the water outlet housing and thermostat-make sure that the thermostat is correctly positioned as shown
Exploded view of the thermostat housing and thermostat-3.0L engine
Exploded view of the water outlet housing and thermostat-4.0L engines
I hope help you whit this (rated this help) Good luck.
Sep 15, 2009 | 1993 Ford Aerostar Extended
True GDM-7 Beverage Cooler Logo
101 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
