Question about LG WM-2277HW Front Load Washer
Mordel #WM2077CW just got an LE error message, what is the problem
  • 15,935 Answers
LE indicates a fault with the motor on the appliance.
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
LG suggest you switch off, wait for a minute, unplug the appliance.
Wait 15 minutes then plug it back in again.
Try the machine again.
If it's still faulty, you can try changing the Hall Sensor in the motor, this can sometimes cure the problem.
Unplug the machine and remove the rear cover. There are 4 Philips head screws. Take them out and remove the rear cover.
You should now see the rear of the motor, which is mounted to the back of the drum.
In the middle is a large bolt which holds the stator cover.
You'll need a 17mm socket and a ratchet to remove this bolt.
Remove the stator cover and place aside.
Toward the bottom-left, you will see a couple of wire bunches held to the motor by three screws. One holds a metal bracket, one actually holds a ground wire, and the last is through a plastic bracket toward the bottom. Remove these three screws and don't lose them.
Through the motor there are 6 bolts holding it onto the back of the drum assembly.
You'll need a 10mm socket and ratchet to remove them.
You will now have the motor off the back of the drum.
Disconnect the two wire harnesses from the motor.
Looking at the surface of this motor that was facing the DRUM (not the outside), you'll see two small pieces clipped onto it, toward the bottom.
The sensor you are looking to replace is the one that looks like a kitchen magnet.
It is attached by small clips. You'll see how it goes on. It's easy to remove.
Go to google and search for part number 6501KW2002A.
This will bring up an LG sensor assembly.
Double check with the supplier that this is the sensor for your appliance.
When you receive the sensor, simply reverse steps 1 through 5.
Once re assembled, try the machine again.
If still the same after this you'll need to replace the motor and/or control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Lg tromm wm2077cw le code
Replace "hall" sensor. Motor sensor is an easy fix and a known problem. Try appliancepartspros.com. They have video to show you how. And part.
Feb 27, 2015 | LG Washing Machines
Lg washer wm2077cw had le error and did not work, blew in to tubing connecting tub to a sensor at top and now my reading went from 230 to 256. washer wont stop filling , leaks out front door. what is wrong...
When you blew into the tubing, you destroyed the water level sensor. You will need to change the water level sensor to stop the unit from over filling. That part number is 6601ER1006E. As for the LE error code, you one of 2 things go bad. Either the motor sensor has failed or the control board has failed. Chances are the motor sensor has failed and is the cheaper part to replace. The part number for that is 6501KW2002A
Good luck
Aug 03, 2011 | LG WM-2277HW Front Load Washer
ERROR CODE LE ON LG FRONT LOAD WASHER
LE is a locked motor error. Not to worry as 95% of the time it is just a bad hall sensor (the motor position sensor). For your model the part number is 6501KW2002A.
May 28, 2010 | Washing Machines
LG Tromm WM2077CW error code LE
No all you have to do is watch how much and what kind of soap you put in that washer...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Apr 15, 2010 | LG WM-2277HW Front Load Washer
LE CODE AND A BURNING SMELL
The LE code represent a failed or locked motor. the replacement of the electrical motor will be needed in this situation.
Jul 19, 2009 | LG WM2077CW XL Front Load Stackable Washer...
LE error message - how to finish the wash cycle?
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
If not, you need to call tech.
Thanks.
Jun 17, 2009 | Washing Machines
LG washing machine Model # wm2077cw
LE is a locked motor error. If this happens often then 95% of the time this is just a bad hall sensor (motor position sensor). A technician should be able to ohm out the hall sensor to make sure. The part is relatively inexpensive and easy to replace.
This can also happen if the motor is overheating slightly from being overfilled (too many clothes) or if you do one load after the other and do not allow at least 10-15 minutes between loads for the motor to cool down. In this case the LE error will only happen occasionally.
Hope this helps, please rate my solution.
Jan 11, 2009 | Washing Machines
LG WM2077CW LE Error, won't spin
It sounds like the motor sensor has failed and needs to be replaced.  Yes a DYI can do it.  The sensor is in the back.
Remove the back cover.
Use a 17mm socket to remove the center bolt holding the rotor.  Remove the rotor by pulling it straight out.  It will be hard but keep pulling.
Now use a 10mm socket to remove the 6 bolts holding the stator assembly.  Carefully remove the stator and turn it around to locate two connectors.  The 5 wire connector is the motor sensor.  Replace it and reinstall and it should work fine.
Apr 27, 2008 | LG WM2077CW XL Front Load Stackable Washer...
Wm2077cw
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Use powders for 'front loading machines'. And pl rate me if helped.
Jan 10, 2008 | LG WM-2277HW Front Load Washer
Error code LE
Suggestion: Your wash could be overloaded; put in clothes within machine's capacity. What is written in your manual's max clothes capacity. If your heater is on; switch off machine and wall plug. Reset the machine with the heater on minimum & resume your normal cycle.
May 27, 2007 | LG WM2077CW Laundry XL Front Load...
LG WM-2277HW Front Load Washer Logo
765 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
