Question about Maytag Kitchen Ranges
When oven was 1-year old, the lower oven started making a noise that sounded like a blow torch, usually after being on for a little while. It was (after many service calls) repaired by replacing the valve in back of the oven that feeds both the upper and lower ovens. At 2-years old, the blow-torch sounds started when I had the broiler on for a while. Starting the process over again with a serviceman not having any idea what's wrong. When the oven was brand new, it had a gas leak in the stove top. Any idea what is causing this blow-torch issue? It doesn't seem to have any effect on the flame although the serviceman said the flame was too yellow. Maytag is offering no help and starting to back away from supporting this issue.
  • 28 Answers
Hi Nancy
I have to ask you a couple of questions. Is the range set up for LP or Natural gas? Blow-tourch sounds are normally caused by to much air going into the burner. If you can look at the burner safely the flames should burn just out of the burner. If the flames are way off the burner the air adjustment is way off or you range is set for the wrong gas. Are your top burners OK?
Posted on Sep 13, 2010
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
My oven makes a gasping for air noise
does it sound like a blow torch? if so yuo have a delayed burner iginition and flame is actually burning inside your burner, I like to know more info to help you, is it propane? natural gas? what is the air shutter on burner set at, this will depend on gas used..
Feb 06, 2010 | Kitchen Ranges
It is making a lound noise and no longer heats
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dgh
Oct 24, 2009 | GE Profile Spacemaker II PEM31 Microwave...
The oven sounds like blow torch
It could be the FSD(flame supervisery divice)not opening correctly starving the burner of gas.
Mar 03, 2009 | Tappan TGFS_63 Gas Kitchen Range
Makes a loud buzzing noise and does not get hot
Have seen this many times.
Sounds like a bad CAP since a bad diode would blow the fuse and a bad mag would likely do the same thing.
Since yours is making the loud 60hz buzz you need to replace the capacator that will likely fix the problem. A $10 fix
Jan 06, 2009 | Kenmore 62622 Microwave Oven
Deep humming sound
This usually means the magnetron is failing.
Just be sure the internal cooling fan is working by making sure you feel air flow. If not, call for service right away.
The magnetron part cost is covered beyond the normal 1-year warranty, so when it gets worse or stops heating, you'll have to call for service.
To find an authorized Samsung servicer, look here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 04, 2008 | Samsung SMH7178STD Microwave Oven
Gas stove burner/oven noises
too much air on top burner ,delayed ignition on oven ,ignitor not lined up properly or check gas presure may need regulator adjustment or replaced. gas 784
May 12, 2008 | Ovens
Ice Maker Making Noise
sounds like your icemaker is jammed.
first ofall just feel around the icemaker and see if you can find a peice of ice jamming it that you can remove. if that doesnt work heat it up with a blow dryer until any ice that is there will melt away and it will free up..
there is one other possibility: the stripper could be jammed against the side of the icemaker in which case you'll have to remove the icemaker from the refrig and unjam it..
hope that helps and good luck
Dec 15, 2007 | Jenn-Air JBL2086HES Bottom Freezer...
Mwave made loud buzzing noise then didn't heat up anymore
When there's a loud buzz like that, it does not heat, and does not blow the fuse, it is usually a defective magnetron. Did it sound something like someone making a "gurgling" sound into a coffee cup? I think this has a a one-year warranty, with n five-year warranty covering the magnetron. You can find a local Amana-authorized servicer here: http://amana.com/amana/jsp/portalhttp.do?cs=0&BV_UseBVCookie=Yes&NextPage=7
Mar 03, 2007 | Amana AMV1162 Microwave Oven
Kitchen Ranges Logo
436 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
