Question about Yamaha MX-D1 2-Channel Amplifier
I recently bought mx-d1 amplifier. it gets warm when even it is idling -no music being played. Is it normal to get warm?
    Genius:
  • 1,175 Answers
Yes...It's a 1000 watt amp..Idle current will produce some warmth
PLease rate my help if it helps
Posted on Sep 14, 2010
I recently bought some bluetooth Ihip headphones.They won't work
take them back where you bought them and get a refund or another pair
Dec 28, 2015 | iHip Audio Players & Recorders
Tip
Connecting your computer to an amplifier to play music
Do you want to connect your computer to a amplifier or surround sound, and play music from your computer through the amplifier? If that is the case, you will need to get yourself a cable from your local sound shop. Ask for a "Stereo to RCA" cable. Plug the stereo jack into the back of your computer (where you would normally plug in your desktop speakers) and plug the RCA cables into one of your open channels on your amp. Select "CD" on your amp if you pluged it into the CD channel, and there you go
on Dec 02, 2009 | Audio Players & Recorders
I noticed it was 2 red lights inside the amplifier, what does it mean?
The amp has 7 LED's in total 4 whiteLED's provide back lighting
the bi-colour LED white/ amber is the power/standby indicator (amber when amp is in standby mode)
The two red LED's are on the Phono Board and form part of the phono amplification circuit.( D1 & D2)They are NOT fault indicators and should be lit during normal operation.
Mar 01, 2014 | Harman Kardon Harman HK 990 Amplifier
My NAD C326BEE amp goes into protection mode at moderate volume
The protection only should come on, when the power amplifier has to give more current than it can deliver. (electronic fuse)
If in the music is a lot of subsonic, sound, so low you can't hear and your speakers can't produce, this could cause the problem. Normal CD players will cut of all frequencies beneath 20 Hz, but it could be your PC is giving everything from 1 Hz and above.
I would certainly try to play some music over a CD player and check if that would solve your problem. Not sure if that works, what you could do to suppress the sub sonic in the computer music.
Aug 22, 2012 | NAD C326BEE Amplifier
I have a SONY amplifier, TA-F410R. When I turn it on I hear nothing. Only after I boost te volume (generally per speaker) does the amplifier burst open. If I choose not to pump up the volume, I can also...
My 1st thought would be the main power supply capacitors.
If they are dried out or "leaky" they WILL take a long time b4 the power supply gets up to where it will run the amp
Get the main capacitors replaced
Nov 02, 2010 | Sony Audio Players & Recorders
Idle out of control.
check all your vacuum hoses and the throttle body itself for a vacuum leaks if the hoses replace as nessasary if to check for throttle body get can of carb cleaner and spray around base of throttle body and sides not in it if idle raises you have a vacuum leak goto a good parts store and ask for a rebuild kit don't goto auto zone or advance they don't carry them
Apr 22, 2009 | Chevrolet Sportvan Cars & Trucks
Yamaha rx-797 w/Yamaha ge-60 eq utilizing prein/main out ..and ad
It sounds like you want to use the external amp rather than the internal one. If that is the case, just connect the output of the EQ to the input of the external amp. All you are doing is inserting the EQ between the amp stages now. Using the mx-1 rather than the internal amp is no different.
Dan
Feb 25, 2009 | Yamaha MX-D1 2-Channel Amplifier
Eratic idle
adjust it to 16 degrees then, this should compensate the wear on your timing belt, but also then I recommend to replace your timing belt soon.
Dec 29, 2008 | 1994 Mazda MX-6
Yamaha MX-D1 2-Channel Amplifier Logo
80 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
