Question about Sunbeam Microwave Ovens
How to use the self-clean button on my Sunbeam iron model 4268-126
I need a glass top for the lid of a Sunbeam perculator ap-20 deluxe
I believe AP Wagner is the only source for Sunbeam replacement parts. Give them a call at 1-888-APWAGNER (1-888-279-2463)or find them on the web at http://www.apwagner.com/. You can also contact Sunbeam directly at Appliances - Kitchen and Irons (800) 458-8407.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 02, 2011 | Sunbeam Microwave Ovens
My Sunbeam coffee machine model EM900 twin thermolock cafe series.Was leaking water around group head . Have replaced the grouphead seal but still leaks infact worse My machine is 7yrs old but in good...
I have a Sunbeam twin thermoblock Im having trouble with my steam wand I im not getting much steam out for the milk to warm up try to clean it with a pipe cleaner can you give me an advise how to get it woking
Feb 01, 2011 | Sunbeam Microwave Ovens
Have a Sunbeam-Oster Bread Maker Model 4810, Style BB-100. I haven't used it in awhile and when I plugged it in there is nothing showing in the display. Pressing the "Start" button also yields...
open the unit and check for an internal glass fuse on the control board,sometimes when they sit for a period of time the fuse wire deteriorates and breaks or by the initial current surge it can burn thru too
Jan 07, 2011 | Sunbeam Microwave Ovens
I have SUNBEAM microwave, model SM0701A7E--how do I set the power to MEDIUM? Thank you.
After a long search and reading I finally got it. To adjust power level follow these instructions:
1. Set timer for amount of minutes you want.
2. Hit "power" button"
3. Change the power from 100% to another percentage by hitting numbers 1-9
4. Press Start
Dec 22, 2010 | Sunbeam Microwave Ovens
Iron cord twisted and my husband says dangerous. Can this be fixed as iron is otherwise OK?
If there are bare As in the copper is showing wires then it IS dangerous. If it is just the wires twisted then just straighten it out the best possible and you will be okay.If the wires are frayed to the point of the copper showing then you need to have the cord replaced. However, unless this is a fancy iron you will be better off throwing it out and then buying a new one rather then paying the bucks you will need to to have the cord replaced...
heatman101
Oct 04, 2010 | Sunbeam Microwave Ovens
My brand new Sunbeam microwave model SGG5701 will not heat. it appears to be working but wont heat food or defrost
Can not find a fuse for a Sunbeam microwave model SGG5701. Where can I find one? My microwave went out after only 3 months of having it.
Aug 15, 2010 | Sunbeam SBM1000 Microwave Oven
My Sunbeam Over the range microvawe will self start!
You need to get it looked at professionally. Faulty microwaves are not really the thing that you should be repairing at home. They can be lethal. Find a local repair shop and get a quote for repair.
Mar 11, 2010 | Sunbeam Microwave Ovens
Door not opening
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
To order parts, refer to the Sunbeam number in your manual.
Aug 19, 2008 | Sunbeam SBM6500W Microwave Oven
Sunbeam microwave doesnt work
i just brought my sunbeam microwave like two days ago. and it will not heat up
Jan 22, 2008 | Sunbeam SMW777 Microwave Oven
Microwave Ovens Logo
117 people viewed this question
Top Sunbeam Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sunbeam Microwave Oven Expert? Answer questions, earn points and help others
