Question about Visonik V217SX Amplifier Car Audio Amplifier
Amp is cutting out
I have a V217SX and it cuts out when I tern up the bass or volume. I have briged it and it still cuts out, what shoud I do?
Check for bad solder joints on the underside of the PCB. These have a small jumper that connects the two layers of the double layer PCB together near the 12V input terminal. Mine had bad solder joints - resoldering it fixed the amp. You'll need a powerful iron... the PCB traces in this area are massive.
Posted on May 29, 2008
Dualxdvd210 when volume is up it cuts out the bass. Can I stop this?
Most probably you need thicker wires for power supply to your amplifier.
Apr 10, 2014 | Dual Electronics Car Audio & Video
No sub woofer output or very little
Your sub amplifier is detecting an overdrive condition and reducing volume to prevent the output stage from burning up. When reduced volume doesn't work, output is cut completely for 10 minutes until things have cooled down.
Mar 27, 2017 | JVC KD-R740BT
My DB Drive pd 1200.1 amp shuts off when the volume is raised. What is happening and what should I do?
The vibration from the bass is cutting off the amp. it is a loose wire causing this issue. you can also get a stabilizer that will stop the vibrations from causing this issue.
Feb 27, 2013 | DB Drive Platinum PD1200 Car Audio...
Bass cut off when volume is too high
When an amplifier shuts the Bass off that means its going into protection mode otherwise it will burn out the outputs. One way is to turn your gains down, Pioneer amps are not the best amps for bass out there, they are more for car speakers, I personally wont use a pioneer amp to run my subwoofers especially if they are hard driven subs like JL , Kicker Solo's and MTX subs. But for now just turn the gains down to 3/4 and that should help u, you can also install a fan to keep your amp cooler, if this never happened before in 5 yrs and now it does then that means your amp is just tired and the inside components are overheating easily, thats common with Pioneer and Sony amps.
Good luck buddy.
Lex...
Jun 12, 2010 | Pioneer Car Amplifier GM-5100T - 2CH 760...
When i turned the bass up to high on my head unit my amp cuts out on overprotection, just for a second and them comes back on. why?
go into your settings in the deck by holding down the volume on most models for 10 seconds then change your hpf settings and your lpf settings your bass will sound much better and not cut out. hpf recommended 160......lpf recommended 140.... good luck
Jun 03, 2010 | Car Audio & Video
Old peavey amp cutting out
time to resolder everything, got a good 10 power eye loupe?
Mar 09, 2009 | Peavey EQ215FX Home Equalizer
Problem
you need to get a bigger ground wire and the cut in and out will stop the cutting in and out is the protection mode starting if it cant hold the thump a capacitor 2farad will hold the bass
hope this helped
Feb 15, 2009 | Eclipse Premium 34230 Car Audio Amplifier
Why does my KAC-8404 cut off at high volume bass?
amp 101
1/0 wire to the amp or the amps will loose power
check the connections mainly the negative
wiggle the wires see if you get a cut out or not
a cap will help you give constant power to the amp and not allow them to drain on long bass notes
hope this helps
Dec 26, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Crate BT50 Bass amp cutting out with high input.
Sometimes an amplifier's preamp can't handle certain signals/frequencies at a high gain, so they cut out. Bass guitars are especially prone to giving such a strong signal.
I bought an older, nonworking bass amp recently and fixed it just to find it had the same problem. Best solution is to put a low ohm resistor at the amps input, but if you turn your guitar down to half volume it'll have the same effect: should prevent it from cutting out.
Nov 01, 2007 | Crate SPA1600 Power Amplifier - SPA Series...
Car Audio & Video Logo
32 people viewed this question
Top Visonik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Joe Alexander
Joe Alexander
Jerry Umali
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
