Question about Troy Garden
Troybuilt riding mower won't pickup grass - Troy Garden
  • 252 Answers
Can you tell me if unit has timmed blades and is the unit a rear catching unit ?
be sure engine speed is correct most applications this between 3400-3600 rpm
if unit has timmed blades - be sure that the blades are timmed correctly , and the correct blade is on correct side
if not timmed be sure blades are sharp and balanced , make sure the wing turn up is ok ( blade speed and turn up creates air velocity)
make mandrell vents are clear if unit has them , make deck belt is not slipping, and is not damaged
make sure deck belt tension is correct
make sure pulley splines are ok and are fixed tightly to spindle shafts and keys are in place
make sure the catcher vents or bag are clear and air can flow through,
lastly be sure that the deck is set level side to side and the deck has between 5 - 10 mm rake that is the height of front of the deck is 5- 10 mm lower than the rear of the deck
and the deck lifts up evenly
note let me know model and spec number of ride on mower
will try and help further if this info does not help
cheers paul46
Posted on Sep 13, 2010
Craftsman riding mower will not pick up grass why?
could be blades up side down or clogged shoot or not enough power try these let me no
Aug 28, 2014 | Craftsman Garden
Troy bilt ride lawn mower
troybuilt.com will have a diagram. just type in the model number, they will have parts schematics and diagrams.
Mar 02, 2014 | Mustang Rzt 50" Zero Turn Riding Lawn...
Craftsman riding lawnmower won't bag grass
A very common problem since mowers were made noise compliant, to collect grass you need draught, this is produced by putting a large wing on the ends of the blades and having a high engine speed, unfortunatly large wings and high engine speeds mean high noise, so today the wings are very small and the engine revs low, this leads to low draught and grass blockage, you need to keep the under side of the deck clean and free from old grass clippings, make sure the machine is fitted with collection blades, not mulch blades, i cannot tell you to increase the engine revs, however if for some unknow reason the engine were to start reving higher it would help.
Oct 13, 2012 | Craftsman Garden
Craftsman riding lawn mower won t cut grass
Does it die when you attempt to engage the cutting deck? If so the you might have a clogged fuel filter, bad gas, dirty air filter, bad spark plug.
Or the mower engage switch may be faulty. They are located in different places on different mowers. But should be attached somewhere along the main pivot of the engage lever. Let me know if you need more assistance. Good Luck!!
Jun 05, 2012 | Craftsman Garden
Looking for owners manual for troybuilt juniortomahawk woodchipper model#4534T serial # JTB015104
I would google search troybuilt, find their company website and poke around in their customer support downloads, or I would see if anyone has them for sale on eBay.
Jun 09, 2011 | Garden
How do i change the lower drive belt on a troybuilt front engine riding mower
On most units you have to drop the deck to change belts, get down there and check it out!! Good Luck..
Mar 23, 2011 | Garden
My troybuilt riders wants to choke off and back fire while mowing in high grass. it does not increase rpm during higher torque requirements
This sounds like a problem with the throttle governor, but I would also check the valve lash if its an OHV machine.
Sep 14, 2010 | Troy Garden
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
142 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
