Question about Hitachi 1 - 3/4" Coil Roofing Nailer
The nailer piston on my hitachi roof gun stays out and will only fire 1 out of 15 times. i've tried oiling it, and hear no gasket leaks. what could it be ? dan.......
  • Hitachi Master
  • 885 Answers
There are o-rings in the gun that route air around the cylinder to push the driver back up. One or more of these o-rings are worn or broken. You can get it fixed at a service center or you can go to sites like www.ereplacementparts.com to find a breakdown of your gun and order the parts. Unfortunately Hitachi doesn't make all in one repair kits and if you replace one, replace all of the o-rings.
Posted on Sep 13, 2010
My hitachi roofing nailer isnt working properly no leaks but whenever I shoot the nail it just spits out as if it had no pressure to it.
You might have bad seals on the piston, if the seals leak you lose power but it won't leak externally. Hitachi guns are nice but like oil, daily oiling or twice daily under heavy use will keep the seals fresh for years.
Oct 29, 2014 | Tools & Hardware - Others
Miss fires and wont sink nails depth set deep and pressure over 120 psi
If no air is leaking from gun, miss-fire is usually caused by worn or too tight piston oring or lack of lubrication. Easy test. Disconnect airline, remove nails, point nose of gun up then down. Driver should stay in uppermost position. If driver moves up then down within gun replace piston oring and retest. Set pressure to about 100psi. Good luck with repair.
Oct 14, 2012 | Porter Cable Coil Roofing Nailer
My hitachi nail gun just fire one time and the piston stay out
This is most likely caused by the band (or o-rings) on the outside of the cylinder. It could be a trigger valve problem, but the fact that it doesn't come out until the trigger is pressed points to the cylinder rings.
Apr 22, 2012 | Hitachi 3 - 1/4" Framing Strip Nailer
My new (used once) hitachi roofing nailer wont feed.when I hand feed it,it has no power.Like theres no air pressure.....Yes the compressor is on. any ideas?
Remove nails and disconnect airline. Open door latch and check for back and forth movement of the feed piston. It should move with little force and should have spring tension when you push on the leading edge of the feeder. If very hard to move then most likely orings are swollen or stuck from lack of lubrication or water entering gun. Remove head being carefull not to tear gasket and check piston/ oring for tight fit( the piston will not come all the way out, just enough to repalce oring). If very tight then all orings should be replaced. If just dry, lube with silicone paste or proper oil. Check that the cylinder retracts into body of gun and rather easily pulls back up. Do not use pliers on the the cylinder; it is spring loaded and shuld move with finger pressure. Parts are available at www.toolpartsdirect.com. Good holidays
Dec 28, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
Hitachi roofing nailer leaks air out the back after falling off roof, I have 5 of them all with the same problem. any ideas?
SOLVED! I replaced all the o rings put it together and air jus blew out the exhaust port. I made the mistake of pushing Piston plunger cylinder into the gun till it seated. this left a gap between the head and cylinder. I took the gun apart, removed the cylinder, an reinstalled it only far enough to seat past the o ring gasket. I then installed the head and let the head seat the cylinder as I tightened the screws. this worked on two guns with the same problem. Jn 3:17
Dec 11, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
I have Bostitch RN45 coil nailer. It sometimes does not feed nails. When I open the magazine the driver blade has not retracted. Gun does not leak, o-rings in drive section look to be in good shape and...
Causes of piston not retracting are as follows. Cracked /worn bumper, if cracked air will leak between piston and bumper. Try test, remove nails and dry fire gun against rubber or soft wood; depress trigger push gun against wood/rubber and hold in this position. Piston should stay down and no air should leak past nose. Worn piston oring, piston should not slide down cylinder under its own weight. Loose or missing check seal, remove cylinder and look for black rubber band around series of holes. Band should be in place and fit snuggly. Good luck
Oct 20, 2010 | Stanley Bostitch Rn45b1 Industrial Coil...
Hi, i got a hitachi nv45ab and My nailer leaks air out the back
Hitachi nv45 series is the most popular line of nailers amoung professional roofers. There are three areas that develop leakes. Leak out head vent indicates cylinder stuck in lower position or headvalve worn. With air connected, gently rap head of gun against rubber mat to move cylinder to position. (Use caution not to damage head). If this action works, gun needs cleaning internally or lack of oil. If air still leaks out vent remove head and examine valve in head and replace as needed. Check that cylinder moves freely up/down (travel aprox 1/4"). If cylinder is hard to move pull cylinder and clean replacing orings as needed. If leaking around trigger, remove rollpin and trigger and check nylon ball for pits and replace as needed. If leaking around base of gun check for loose bolts and/or worn gaskets. Remove nail canaster to check feed piston gasket and screws. Good luck with your repair and post again if you have other question.
Aug 04, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
Hitachi NV45AB coil nail gun is leaking air from top of gun
the top!! o-ring inside of thr top plate is bad you need to remove the plate /dissasemble and replace the o-ring
Jan 21, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
My brand new hitachi NV45AB2 roofing nailer leaks air through the trigger when it is half depressed. I purchased one and returned it only to find the new one I recieved to replace it does the same thing....
Take off the back cover and make sure it's not too dry inside. Spray the inside with some WD40. You can take off the top cover. Pop the piston, cylinder, and head valve out, making sure all the seals and rings are seated correctly.Sounds like the piston is momentarily sticking. Does it shoot at all? Lemme know. Please rate me
Jun 03, 2009 | Hitachi NV45AB2 Roofing Coil Nailer
Hitachi 1 - 3/4" Coil Roofing Nailer Logo
114 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
bwbconstruct
Level 1 Expert
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
