Question about Reliance Water Heater #6-40-GBRS 40GAL NatGas Water Heater
PILOT LIGHT KEEPS GOING OUT. - Reliance Water Heater #6-40-GBRS 40GAL NatGas Water Heater
  • 494 Answers
If you still have your owner's manual, you will need to call the manufacturer. They will need the model # & serial #. This particular brand has a fine mesh filter screen on the bottom (below the burner) that gets clogged and causes irregular pilot outages. They have a recall in which they will send you a new burner assembly with a reset switch built-in to it. They will send it to you for free, but you will need to hire your local gas co (at your expense) to install it and also clean the filter while they have the burner assembly out. Good luck. Douglas
Posted on Jan 06, 2011
  • 377 Answers
Most likely an indication that the thermocouple has gone bad. Not unusual. The thermocouple is the short brass rod that sits in or close to the pilot light when it is lit. The heat from the pilot light will cause the thermocouple to activate and keep gas flowing to the pilot light. When the thermocouple goes bad the gas will not flow and the pilot light will not stay lit. First, be sure you are following the proper procedure to light the pilot light, resetting the valve and holding it down until the pilot light burns for about 20-30 seconds before turning the gas on. If you are going through the correct lighting procedure and the pilot light will not stay on, the next logical thing is to replace the thermocouple.
Posted on Sep 13, 2010
  • 395 Answers
If the pilot flame is weak, when the main burner is ignited, there can be enough 'whoosh' of air and gas to blow out the pilot. There may be a little of grit in the pilot valve jet hole restricting the flow, hence the weak flame. Try using a piece of fine wire to clear the obstruction. If that does not help the pilot jet will have to be unscrewed and cleaned with compressed air. Ensure the gas is turned off before attempting any maintenance.
Remeha boilers - pilot light keeps going out
You Need to replace the Thermocouple. You can get them at most hardware stores take the old on with you
images?q=tbn:and9gcs197mmasu0-olkj-42wttmbnfimgyu0r1wy_jdi-wq-_xsajtbwq
Nov 22, 2012 | Water Heaters
Pilot light keeps going out
pilot light keeps going out! more then likely its the thermal coupling doing this. if bad it shut all gas to heater for a safety measure. just shut power off, then turn gas off and replace it. then you should be ready to go. to relight heater hold down on gas vavle knob in the pilot position, hold down and light it at the coupling where gas comes out. when it is lit, continue to hold down for 60 seconds. release knob very slow. then if its lit, turn to the run position. if flme goes out, wait at least 5 minutes to expel the gas fumes and turn to pilot and try again. good-day !
Mar 31, 2012 | Water Heaters
I have a Kenmore Power Miser 12 gas water heater that the pilot light keeps going out. The water heater has been in service for 45 months. The pilot light has a blue flame with some orange flame flares...
check and or replace the thermal coupling. the coupling goes into the main gas control, if the coupling is bad it will shut off gas supply. as a safety measure.
Mar 09, 2011 | Water Heaters
Our pilot light does not stay on...sometimes when temperature changes out side
The pilot light has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. It seems that your thermocouple is faulty and needs to be replaced if pilot light keeps going out as the outside air cools.
Sep 21, 2010 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Pilot keeps going out after it cycles a few times
Hot water heaters that have problems with pilot lights going out are usually fixed by adjusting or replacing the thermocouple. The thermocouple is the brass tube that is in or near the flame of the pilot light. The thermocouple acts as a valve to allow the gas to flow to the pilot light. If the thermocouple begins to go bad, it may shut the gas flow off to the pilot light. There could be other gas supply issues, but this is about the least expensive first step for the home owner. REMEMBER, you are working with gas. Take your time and be safe or have a professional replace the thermocouple.
Sep 15, 2010 | Reliance & Pilot Assembly for Natural Gas...
Either the pilot light orfice is dirty, and you will need to pull it out and clean it, or the thermocouple is bad. If the pilot goes out as soon as you let the button go then it is most likely the thermocouple. If the pilot stays lit for a few days or hours then you will need to clean the pilot orfice, heres how:
1 turn off the gas supply
2 unhook the main burner gas line from the thermostat, this is the line that goes to the burner
3 unhook the pilot supply line it is usually next to the main burner line
4 unhook the thermocouple from the thermostat
5 remove the burner assembly
6 take the orfice out of the pilot line and clean it out by blowing thru it, use an air compressor if needed.
7 reassemble and light pilot
Apr 08, 2010 | Reliance & 30 Gal LP Gas Water Heater
probably need to clean the pilot orfice out. You will have to pull the entire burner assembly to get it out. Pull the tube going to the pilot light out and the orfice will be in the end closest to the pilot light. Once you get it out there might be a white fuzzy substance on it, clean it off, the hole in the orfice is very small, DO NOT make it any bigger, find something to push thru it like a single strand off a wire brush. After cleaning re assemble and re light, this should cure your pilot problems.
Mar 14, 2010 | Reliance & 30 Gal Mobile Home Water Heater...
Water wizard 10P pilot light keeps going out
If the thermocoupler is defective the gas to everything is shut off. The coupler is the bulb that sits ib the pilot flame If it doesn't heat up it will sense no pilot and shut the gas off. They don't cost much and are easy to change. Good Luck, Ned
Sep 17, 2009 | Bosch & Tankless LP Hot Water Heater
My bosh water wizard 10P pilot light keeps going out.
Very possible the thermocoupler is no good. The thermo coupler is that bulb that is in the pilot flame. It controls the main valve It's not expensive and fairly easy to change out.. Make sure you get no dirt in the cspillary tube hole.brass screw end. The bulb must be just in the flame tip when adjusting. Good Luck, Ned-
Reliance Water Heater #6-40-GBRS 40GAL NatGas Water Heater Logo
383 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
