Question about Maxtor (L01F500) 500 GB Hard Drive
My 500GB Hard Drive only reads a 2GBs partition. How can I format the entire hard?
    Sergeant:
  • 286 Answers
Do the hard disk is internal or external??if internal format the same using disk management?
Posted on Sep 13, 2010
22KAF547SRE8
Format it with EASEUS Partition Manager. It's totally FREE and an awesome Program for formatting and manipulating hard drives. It's very easy to use.
You can get it here: www.partition-tool.com/
Aug 18, 2012 | Toshiba Canvio 500 GB USB 3.0 Portable...
I bought today a lacie hard disk 500GB and instead of 500GB has only 9.99 MB space.What's the problem?
Sounds like your have a 9.99mb partition on your drive with the rest being free space.
If you are running windows goto the Computer Management program and check under storage> disk management to see if your 500gb drive is there. if it is delete the existing partitions and reformat the entire disk to NTFS
May 21, 2011 | LaCie Big Disk 500 GB Hard Drive
Not able to detect the disk
We're going to need more information to troubleshoot, but if it's a new drive that's never been set up follow the instructions below. If these instructions aren't helpful, then please post back with more info and I'll help you further.
Your external hard drive likely has no partitions so Windows has no drive to mount. Follow these steps to create and format a partition for your external hard drive.
1. Press Win+R to open the Run command.
2. Type "Control" into the dialog box.
3. Double-click "Administrative Tools."
4. Double-click "Computer Management."
5. Select "Disk Management" under Storage.
6. Find the 250 GB External Hard drive in the right pane.
7. Right click on the drive and select "Create new partition".
8. After the partition is created you will need to format the partition.
9. Format the partition as NTFS unless you plan on booting off the hard drive, in which case format the partition as FAT32. You can also create multiple partitions if you want.
10. Enter My Computer and you will now see your external hard drive.
Good luck and thanks for using FixYa.
Apr 04, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How do I format my new Seagate 500GB FreeAgent GoFlex Hard Drive to Fat32 for use with Xbox 360? I am using Windows 7 and when I open up the formatting options only NTFS and exFAT are available.
Windows Disk Management can only format a hard drive less than 32 GB to FAT32. If you want to format your 500GB drive to Fat 32, you need to use third party program like AOMEI Partition Assistant. http://www.disk-partition.com/free-partition-manager.html
Dec 25, 2010 | Seagate 500GB FreeAgent GoFlex Hard Drive
Hi, When ever I try and copy files to my Hard Drive Model SF320, the disk keeps skipping and the entire copying of files have to be done again. It gets very annoying most of the times. Please let...
If your usb hard drive is upto 500gb thenit don't require external power but if it is more than 500gb then it require external power.
And try to format the whole drive and recreate the partition on the hard drive. This will solve your problem.
For further help or to thank me . Mail me on my email Ejaz89@live.com
Aug 06, 2010 | Verbatim Computers & Internet
Humax pvr can not read my maxtor 500gb harddrive why is that?
NTFS
1)allows access local to w2k w2k3 XP win NT4 with SP4 & later may get access for somefile.
2)Maximum size of partition is 2 Terabytes & more.
3)Maximum File size is upto 16TB.
4)File & folder Encryption is possible only in NTFS.
FAT 32
1)Fat 32 Allows access to win 95 98 win millenium win2k xp on local partition.
2)Maximum size of partition is upto 2 TB.
3)Maximum File size is upto 4 GB.
4)File & folder Encryption is not possible.
I hope this clears things up for you
Mar 08, 2010 | Maxtor Hard Drive
How can I format an external lacie drive to mount on both a PC and a MAC without partitioning
You can not use the drive on both systems. It has to be formatted for one or the other. To transfer your files, I would either backup your files to CD's/DVD's or try to network your Mac and PC, then just dump your files to a share folder of some sort.
Jan 09, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
I want to partition a 500gb on a format for speed
The speed is limited by the USB port rate transfer and hard drive specifications. You will not get a difference with a specific format or partition choice.
Oct 05, 2009 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
I can not see the other items on my hard drive and it only shows 83gb on my 500gb hard drive help
It could be that the other 400gb is unformatted space. Use a utility such as Partition magic to extend the formatted partition, or create a partition in the unformatted space.
Hope it helps.
Aug 29, 2009 | Maxtor OneTouch II external hard drive...
LaCie 500GB external will not show up on mac desktop. Blue light on, whirrs as if working but no icon on desktop (not mounted)
Did you format the drive using Disk Utility? Open "disk utility" from the dock icon or applications/utilities folder. Click the drive name on the left side of the disk utility window. click the "partition" tab in the window, next click the "options" tab and select GUID Partition scheme, or any Mac compatible scheme, read each explanation of the schemes. Name and resize your partitions, click apply. This is how it works running Leopard, not positive if the same applies to Tiger. I hope this helps you
Dec 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Maxtor (L01F500) 500 GB Hard Drive Logo
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
