Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Kitchenaid Stand Mixer won't start at "Stir" speed, starts at speed 2 then if I am very careful I can nudge it down to stir speed without it stopping, but if I just move lever normally to that position it shuts off.
3 Suggested Answers
  • 130 Answers
SOURCE: Kitchenaid stand mixer will not stay in the off position.
There is a spring, item #4, which hooks on to the bottom of the control plate, item # 25, and pulls it back when you move the lever to off. Remove the rear cover and see if that spring is still connected to the control plate and to the lever arm, Item # 3. Here is the diagram:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
Posted on Apr 01, 2010
Have the same problem. The spring is attatched but it still wont stay on the off position. It looks like the spring is causing it from stayin in off. Im thinking its the spring washer on the lever wearing down or maybe that screw is too loose so its not giving enough tension to hold the lever in place. Or maybe the off position groove and spike on the lever are worn smooth so it wont catch. Temporary solution I used is to use a rubber band from speed lever to lock lever. Wrap it going around the top so it holds an upward tension that the lever needs. What im doing til the prob is resolved...
Posted on Oct 03, 2013
Kitchenaid mixer motor quit , I dont really see any thing wrong with the brushes.
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
First, you may want to adjust the mixer's speeds:
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Second, if the mixer won't run:
Remove the Control Plate Assembly (36), the Phase Control Board (39)
and the motor Governor Assembly (35). Inspect for loose connections,
burnt or damaged components. If they seem to look OK, re-assemble
them and test the mixer. If the motor still won't run, then I might suspect
a defective Phase Control Board (39).
Aug 01, 2011 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid stand mixer KSM90EM turns off when going to the left on speeds 4 - 6. Makes a bit of noise at stir speed, but runs in time. Also noticed white dust powder in small amounts on the speed...
Get a Copy of the Repair Part List from Kitchenaid.com.
You need to adjust the mixer speeds:
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted. Make sure that the Control
Plate is not damaged in any way, contacts are not charred or burnt,etc...
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 30, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
I have just purchased an ice cream freezer for my mixer. It is an older model and does not have a "stir speed" delineated. What is the equivalent of stir speed on the older models? -- 1 or 2?
On models with the "STIR" speed, the RPM (Rounds Per Minute) is 60.
Set your mixer speed to "1" or "2" and do the following:
60 seconds. In your case, the correct STIR speed is 60.
Jul 29, 2011 | KitchenAid KSM50PR Professional Series...
Kitchenaid speed controller (don,t work
You need to adjust the mixer speeds.
Obtain a copy of the KSM150PS Repair Part List from Kitchenaid.com.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 20, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I was grinding some meat and my mixer got very hot. I let it cool down and now it only operates at one speed.
I am not sure what has happened to your mixer but, select
different speeds from Stir to 10. If it runs OK, then there is
nothing to worry about, otherwise do the following to re-adjust the mixer's speeds:
Get a copy of the Repair Part List of your model from Kitchenaid.com
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 18, 2011 | KitchenAid KSM150PS Artisan Series Stand...
The mixer goes real fast on all the settings. Whats wrong?
The K45SS is very similar to the 5-qt. tilt-head Artisan Stand Mixer.
You need to adjust the mixer speeds. Obtain a copy of the K45SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must
be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned anymore. Leave the bottom screw alone for now.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 14, 2011 | KitchenAid K45SS Classic Stand Mixer
I could not regulate the speed as usual. Hubby removed the phase control board and a new one was purchased #9706595. It arrived and was installed and now the mixer won't even turn on. HELP please.
The K5SS is very similar to the 5-QT Artisan KSM150.
You need to adjust the mixer speeds. Obtain a copy of the K5SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jun 28, 2011 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid Artisan KSM150 Stir problem - Stir speed is the same as setting 2, but all others (4, 6, 8, 10) work fine. Tried adjusting the control board but "stir" and "2" still spin...
You are not adjusting the screws correctly. All three screws (2 top left and right, and 1 bottom)
must all be adjusted. Here is how:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jun 20, 2011 | KitchenAid KSM150PS Artisan Series Stand...
After putting flower into mixing bowl large quanity of flower is ejected when mixer is turnon at low speed. Once it starts to mix then it's ok.
Firstly, I think you mean "flour".
Put in your ingredients. Cover the mixer, head and bowl, with a dishtowel. Turn on mixer to "stir" (or lowest speed). But! Mix only for 1 or 2 seconds. Repeat this, with bowl covered, until flour is mixed in enough not to fly out.
Happy baking!
Dec 11, 2010 | KitchenAid Classic Stand Mixer
KitchenAid 2671 onmly run Stir and Second at high speed
Hi. Goto kitchenaid.com and download the parts catalog for your mixer model, these drawings will assist you in the disassembly and reassembly of your mixer.
You'll need to replace the speed control in your mixer. This is a common problem. Be prepared to wait at least a month for your parts to arrive. Unplug your mixer before you open it up.
If you're still under warranty call kitchenaid!
If this solution has assisted you, please rate it. Good luck! ricardok45
Jan 28, 2009 | KitchenAid KP26M1X Stand Mixer
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
455 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
