Question about Rancilio Rocky SD Grinder without Doser - ROCKYSD
What is the correct setting for grinding coffee for expresso
    Novelist:
  • 137 Answers
Grinding setting is one simple operation but requires bit patience:
  1. Turn on your grinder and continue setting to fine while burrs are spinning, you stop when you hear metal to metal touch sound(burrs maximally closed finest grinding)
  2. From that point go back quarter of revolution and mark the spot where you stopped with marker to body of grinder and setting plate with one line
  3. Grind little amount of coffee only to fill one sector of dosser than test it at your machine (if it leaks too fast and with yellow color of cream you should go to more fine>><< if it does not leak from the filter holder or it leaks very slow you go to in opposite way.
  4. You test grinding few times bit after each reset of plate grind little amount and take that in one other pot (that will provide to have pure new granulation)
  5. After setting measure the grounded coffee that comes out from dosser it should be about 7 grams, better measurement you can get if you measure 10 doses in one place because you don't get never same amount from 6 sectors of dosser.
PS: the pump pressure of coffee machine should be from 8 to 10 bar and steam pressure should be from 1.1 to 1.5 bar> depends on type of coffees you use.
Posted on Feb 12, 2011
Set grinding and extraction on ambiente
Grinder setting will not just affect extraction time, it will also affect taste. A fine grind will be slower but have a creamier look, a coarse grind will speed up delivery. From whatever setting you are on look at the result, you are after the good creamy top of a good expresso. only adjust one step at a time, and check a few cups before any more adjustment. You do not want it so slow that you have to wait ages, So go for coarsest grind with a creamy head. Overtime you might have to readjust due to wear, Select only one hopper at a time to adjust, Do not try and adjust when blending, one side at a time until both give same result and speed for same coffee, Then you can go onto blending.
Mar 05, 2013 | Schaerer Ambiente PS Espresso Machine w/...
I have a saeco magic comfort +. It is, all of a sudden, not going thru the rinse upon set up. Then, it is not putting water thru the grinds, and, thus, pushing all grinds dry to waste, not generating...
Hi
Don't really like the rinse cycle because it waste water. If you want to rinse the brew unit just push the "scoop button" and not put any coffee in, then push the large coffee. Does the same thing but doesn't use as much water.
Dry grounds is one of my tips.
http://www.fixya.com/support/r4084157-dumping_dry_grounds_not_making_coffee
Jul 23, 2011 | Saeco Magic Comfort Plus Espresso Machine
When I just have water in the portafilter it runs through fine. When I put the expresso in it clogs and expresso will not flow through.
No solution here. Utopia directions say to only use MEDIUM (drip) grind. Ain't it awful? I prefer ultra fine grind, frankly muddy coffee.Deb
Jul 10, 2011 | Starbucks Barista Utopia
I set the grind control know on the lowest number to try to get a fine grind, but I still get a coarse grind which does not give me a good expresso, and the water runs fast. What else can I do it is a...
Hi
More than likley you grinder has become seperated internally. You either need to disassemble the grinder completely, clean it and then try to reconnect the pieces or just replace the grinder. I have some. Just let me know, new or used reconditioned.
Jan 02, 2011 | Starbucks Saeco Italia Digital Barista...
Krups K2 XP402040 Expresso maker. This makes the
Would you like to try not put too much coffee powder, and not make the coffee powder too firm ( I mean not press them too heavy.)
Or, not grind the coffee powder too thin....
Hope it helps you.
Oct 30, 2009 | Krups Coffee Makers & Espresso Machines
Vev Vigano Carioca Nero Espresso Maker..what kind of grind to use
Use fine grind for espresso, darker roasted bean blend on Italian roast style are better, they are stronger and oily, perfect for expresso machines like this.
One of the best available here is this: Lavazza Qualita Rossa Ground Coffee, great brew on Moka style espresso machines.
Feb 16, 2009 | Vev Vigano Carioca Nero Espresso Maker...
Water on top of the filter after brewing
my experience with this machine is that this varies greatly with the type of beans you use. I would experiment with a few types of beans, roasts, and you might get lucky.
Nov 28, 2008 | Breville ESP8XL Espresso Machine
Cafe Roma Expresso/Cappucino machine
My understanding is that this is normal with units like the ESP8XL which use a pressurized portafilter. Non-pressurized units will leave a dry puck of used grounds.
Saeco Vienna Delux Expresso Maker
Try to descale the machine, also try to set the grinding to little more coarse.
Aug 22, 2008 | Saeco Vienna De Luxe Espresso Machine
Rancilio Rocky SD Grinder without Doser - ROCKYSD Logo
242 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
andy just round the...
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
