Alpine CDA-105Ri CD Players Logo
Posted on Sep 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just purchased a cda105, the radio works fine and sounds great. Although when using the cd player or my iPhone it produces no sound. The display shows that the iPod and cd player is working correctly, the song name shows. I returned the first one cause of the same problem.
Anonymous
Level 2:
New Friend:
  • Expert 141 Answers
  • Posted on Sep 13, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
141
Questions
0
Helped
66629
Points
282
The problem is that you are not turning on the amplifiers,
pull the radio out there are 2 blue wires, you are using the wrong one
just switch them and the cd and ipod will work
good luck
  • icollazosanc Nov 29, 2010
    Wiz. I have the same problem on mine, I bought an Alpine CDA-105, do not have external Amp, just using the built-in one, when I turn the source button, the Radio works fine and I can hear it perfect, but then I turn to my CD or iPod I hear no sound coming out of the speakers, it shows that its playing but no sound. I also when to the settings and turned the "Power IC" setting to "ON" and nothing. What could be the problem in this case?
2002 acura tl type s cd player works but sounds distorted, everything else plays and sounds fine?
thats a lazer problem in the cd usually a cd cleaning disk will sort that problem if not a its the lazer head thats distorted best this to do it put a conversion tape to ipod or iphone and play your tunes off those devices via your tape, there only cheap to buy.
Bmw x5 cd changer no disc
absolutely no idea ,do you have anything else plugged in that could cause the sound cut off although you say the radio works?or has a plug come loose in the back of the radio ,you could try one of them radio fitting centres as you never know some young lad comes out presses a button and it all works as you had the mute on or something but the radio works ,is it a built in cd player or a remote unit ? in my time a 8 track was the in thing these modern things are welll beyond your ancient dinasaur here .
CD will not play. The CDs goes in and out fine and looks like it is playing according to the display. I can change songs, fast forward and reverse through the songs according to the display but nothing...
Do you have the radio hooked up to an amplifier? If so, it sounds like you are using the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn the amp on. The antenna remote wire turns off when leaving tuner mode.
2001 Chevy Impala Radio - No Sound
Sound like you have loose connections. Start at the rear of the radio and inspect the connections. Then move to each speaker in turn and do the same. When you find any disconnected or loose connections make them good.
1helpful
2answers
Eclipse CD2000 has no sound from a cd or sirius... radio works
If you have an amplifier hooked up make sure that the correct blue wire on the harness is connected. One of the wires is the remote amp turn-on, the other is for a power antenna. That would be why your radio plays through your speakers, the power antenna wire' when the source is set to radio, sends a 12 volt signal. That would turn on your amp if thats the way that its hooked up.
No sound
I have a nessin maxima. Im trying to find a car kit for my car
Alpine 9885 - no sound with cd's or ipod
have you fixed it yet? if not try this. your car probably has factory amplified speakers. hook up the remote wire AND the power antenna wire to the blue factory amp wire and it should work just fine
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
