Question about GE Profile Harmony DPGT750EC Electric Dryer
Dryer intermitantly drys.
The unit drys on and off. One day it drys the next it runs but no heat. Troubleshoot says it may be a fuse?? Cant locate.
  • Anonymous May 15, 2008
    Same here, been tested by tech, electronic board has been replaced twice.
    Some say it is the blower motor.
  • Anonymous May 20, 2008
    DRYER DOESNT DRY CLOTHE
  • 145 Answers
I have replaced several blower motors on these units for that problem. If the board doesn't read the blower motor speed it won't turn the heater on.
Posted on May 15, 2008
Dryer heats and drys but shuts off intermitantly..sometimes can be started right up, other times turning dial does nothing.. is it the timer dial?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 17, 2011 | Amana ALE643RB Electric Dryer
Dried a load fine, next load tumbles wont dry. still cant get heat
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 02, 2010 | Kenmore 63942 Dryer
Won't heat. and i cant locate the fuse
my dryer doesn't heat up to dry the clothes. The drum is running but there is no heat - the clothes remain wet. Any ideas?
Apr 17, 2010 | Whirlpool LER4634J Electric Dryer
No heat in dryer
along with a possible heating element gone bad there are several thermal fuses locate inside the dryer cabinet or sometime on the back behind the rear panel.
If you have a volt meter you need to check the continuity on each of the thermal fuses.Replace any of the ones that do not have continuity.
Mar 12, 2010 | Dryers
No heat in dryer
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 21, 2009 | Dryers
Heats & drys fine but stops running after a long period of use and won't start back up right away. I assume it is cooling down then will run again.
Your dryer vent needs to be cleaned. Also, pull out the dryer and clean the part of the vent entering into the dryer from the back. This will cause the unit to cut out on thermal lockout.
Apr 16, 2009 | Dryers
GE DPGT750 Gas Dryer runs but no heat
if your blower motor isn't getting up to speed it won't heat.check troubleshoot mode by holding my cycles and help at the same time for three seconds.may need a new blower motor
Mar 09, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
My Kenmore series 80 dryer quit heating. It was intermitent for a few days then quit. I checked the inspection window and didn't see any light. The gas it on and it seems like there is a "click" after I...
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse.6aed02c.jpg If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
a%20igniter.jpg Igniter and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these: dryer%20coil%20kit.jpg Gas operator coils The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks.
Dec 22, 2008 | Kenmore 659 Electric Dryer
Changing gas whirlpool dryer heating ailment
Before you do that try this pull the unit out from the wall remove the venting from the back run a load and let the hot air go intop the house if it drys fine you have a plugged vent going to the outside and it will need to be cleaned out (This is the most common problem for long dry time)
Apr 13, 2008 | Whirlpool LER5636P Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
91 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
