Question about Bosch Axxis WFL 2060 Front Load Washer
Where can I get a repair manual/schematic for the bosch axxis model wfr2460uc.? The door lock (machine side not the door latch) was broken when someone forced the door open when locked. I found the part, but need some guidelines to access the inside of the machine to install this part.
SOURCE: Door locked open
Tool: We cut a piece a wire about 10 inches long from a wire clothes hanger. On one end we bent 1/2 inch of the wire in a 90 degree angle with needle nose pliers. On the other end of wire we put another bend at least three inches.(this end will be your handle end) Process of using homemade tool to release latch: Make sure washing machine is on a wash cycle. Use flash light to locate latch in the locking catch. Insert the small bend of the tool into the locking catch. Then hook onto the latch and pull out --apply a small amount of pressure -- about three lbs of pressure) Then at the same time you are pulling, press in on the door release button (the little white button above the latch hole where you now have the wire inserted). As your are pulling with little pressure on the latch, hold the little white button in and press the start /stop button. You should hear the door lock. Let machine start working. (about ten seconds) Now push start/stop button again and you should hear door lock release. Your lock catch should give away. This worked for us.
Posted on Feb 19, 2007
  • 1294 Answers
SOURCE: Can't deactivate child lock on washer
Try: Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Posted on Jan 05, 2008
SOURCE: bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
Posted on May 18, 2008
localwonder
  • 6784 Answers
SOURCE: My Bosch Axxis WFL pump drain blocked. I had a
Hi there, i have prepared two links. The first one is the original manual you requested and the second link refers to the quick reference guide.
Click here for the first link to your original manual.
Click here for the quick reference guide.
Posted on Feb 25, 2009
uniman9310
  • 189 Answers
SOURCE: remove bosch axxis 2060 washer motor
Remove the back panel to get to the motor which is at the bottom at the back. Notice two bolts holding the motor into the mount. Remove these two bolts. Notice the back part of the motor is sitting in the mount with black rubber washers. Carefully, pull the motor forward, and this will be abit hard. You can take a flat head screw driver and tap down (in between) on each front plastic washer and the motor will slowly come forward. Becarefull because there is a wire harness still attached to the motor. You have to take wire cutters and clip the placstic band holding the wire harness to the motor. Then grip the harness and wiggle it free. Then remove the single wire also. Putting the belt back is a bit tricky too. Make sure you put back the two black rubber washers and the two front plastic washers.
Posted on Jun 03, 2009
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
I have a 3-year old WFL 2090 Axxis Washing Machine. The door will latch initially, but unlatches during wash cycles and blinking lights come on. It was working fine until the machine was moved. ...
There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor becoming apparent with the extra movement of washing requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 15, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Door latch is broken. Door wont close. Is it possible to buy replacement door?
you can purchase a door latch:
Repair Clinic:
http://www.repairclinic.com/Bosch-Dryer-Latch-Parts
eBay:
http://shop.ebay.com/i.html?_nkw=+dryer+door+latch&_sacat=0&_odkw=bosch+dryer+door+latch&_osacat=0&_trksid=p3286.c0.m270.l1313
Jan 10, 2011 | Bosch Axxis WTL 5400 Dryer
New front load washer but door is locked. owners
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is for the WFMC6400, but it could help.
To manually unlock the door lock system, perform the following steps:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and
locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch
assembly is a teardrop shaped tab.
Gently pull the tab down approximately 1/4 inch,
or until a click is heard.
5. The door may now be manually opened.
Pl give me a ‘very helpful’ rating for the free help, thanks!
May 17, 2010 | Bosch Axxis WFL 2060 Front Load Washer
When I start my Bosch Axxis machine - I purchased it used - I do not hear the water start and the cycle isn't starting.
When you close door properly and press start does the door latch? If not possibly the latch is the problem. If it doesnt give a normally closed condition, the micro processor wont continue.
Sep 21, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washer will not start
Your wahing drum is broken. It is very complicated to fix it by yourself, so I reccomend hiring a professional to do it. Also,
  • The belt may have broken. The drum may be jammed by an item of clothing.
  • The main motor may be faulty.
  • There may be a broken wire to the motor.
Apr 22, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Door latch broken- disassemble door ??
yes if its plastic just pop it out to replace
Feb 09, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis WFL 2060 Front Load Washer Logo
206 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
