Question about Car Audio & Video
Replaced drive belt, now it needs a new code.
  • Janice Calhoun-Tucker Sep 13, 2010
    this is for radio/cassette for 1997 gmc pickup which lost code upon removal of unit.
  • 5,081 Answers
You must have removed the battery connections when you worked with the belt. Am i right?
Radio code is specific for each and every car. It is specific like anti theft code.
When you removed the battery due to safety precautions the stereo shut off and asks for the code..
You can get it by providing your VIN# and registration details in authorized dealership.
Nobody else can provide you. If anybody can provide you that , then there is no meaning of security for your car.
Posted on Sep 13, 2010
  • INDIRA KUMAR
    INDIRA KUMAR Sep 13, 2010
    Ok you can get the code as i have specified from an authorized dealer and i have also explained why anybody cannot give the code...
    President:
  • 1,932 Answers
The manufactures usually sets these codes to something simple. Look in the glove box ,Centre console ,or the side of the unit for the manufactures code, If you cannot find it try 0000 or 1111
or open the bonet and check the right/ left side you will see some number and look for the one with four digit.
Thank You
HAVE NEW ALTERNATOR,NEW WATER PUMP,NEW RADIATOR,NEW THERMOSTAT HOUSING ! YOU HAVE TO DRIVE IT TO 30-40mph THEN NOISE STARTS BUT WHEN COME TO A COMPLETE STOP THE NOISE SLOWLY QUITS BEFORE I CAN OPEN THE...
If the noise sounds like a whistle or squeal, it may be the accessory drive belt slipping. You stated you replaced the alternator and the water pump, but did you replace the belt? Belts may look good even as they age, but they dry out and will get a glazed appearance and this acts like ice on the pulleys. The different accessories (alternator, power steering, A/C. possibly water pump) all provide resistance to the belt as it attempts to turn them. The faster the car runs, the more resistance. Thus, at idle, there may be no noise, but at 40mph, the resistance on one of the pulleys may get so great that the glazed belt starts slipping, causing a noise. This slippage could also be due to a belt that is not properly tight. If your vehicle has an automatic belt tensioner, it could be in need of replacement. If it is manually adjusted, it may need to be readjusted. Be advised, though, re-tightening a glazed belt may make the noise go away, but over-tensioning a drive belt can cause belt breakage or bearing damage to the drive accessories. It is worth the cost of a new belt to not have to replace all the drive accessories.
Mar 16, 2015 | Cars & Trucks
Where can I get replacement drive belt
I have some replacement bread machine belts. Is the number code on the side of the belt still visible? It should look something like this: STS 60 S3M 471 I need the code off the belt to see if I have one in stock.
May 01, 2013 | Morphy Richards 48280 FastBake Bread...
Precor error 20
Precor Error Code 20 Error Code: 20 Manufacturer: Precor
Model: All Models
Error Description: Error 20, Too many Maximum Power Requests in 1 Second - The error 20 observes a treadmill's power bit reading when the treadmill was operating at speeds of 1 mph or less. Power bits indicate the relative time that the motor controller drive circuit is turned on. Power bits is an indication of the amount of power the load is demanding from the motor controller. Error 20 indicates that at a speed of 1 mile per hour or less, an excessive amount of power is being demanded from the motor controller for an excessive length of time. Possible Reason:
  1. Starting the running belt under a very heavy load can cause the error 20 to appear.
    1. The user (especially a heavier user) is standing on the running belt as they start the belt into motion.
  2. A badly worn deck and/or running belt can cause the error to appear when the user steps onto the belt.
  3. Badly worn drive motor brushes may not be making proper contact with the drive motor commutator causing the error to occur when the user steps onto the running belt. The unit may also slow down or become sluggish when the user steps onto the running belt.
  4. A leaky or shorted drive motor filter capacitor (on units equipped with SCR motor controller) could increase the current demand enough to cause the error.
  5. A leaky or shorted drive motor inductor (on units equipped with SCR motor controller) could increase the current demand enough to cause the error.
  6. The high power demand is caused by a shorted or de-magnetized drive motor.
Recommended Action:
  1. Instruct the user to straddle the running belt while starting the treadmill at a low speed, such as 1mph or less, and then step onto the running belt.
  2. Determine the amount of AC input current being drawn by the unit under no load and loaded conditions using a clamp on AC ammeter. The current displayed can be used to determine the condition of the deck and/or running belt. These same readings should be taken on a like unit, in good operating condition with a known good deck and running belt. The readings from the unit in good operationg condition can be used as the benchmark. Compare readings and replace* the deck and/or running belt if necessary. *Some units have a reversible deck. Be sure if the deck is being flipped or replaced, a new belt is installed on the new deck surface.*
  3. Inspect and repalce both drive motor brushes if necessary.
  4. Measure the AC input current without a load using a clamp on AC ammeter. Electrically isolate the filter capacitor from the drive motor circuit. The drive motor leads need be kept intact so the drive motor will operate with the filter capacitor removed from the circuit. Re-measure the no load AC input. If the AC input current is significantly lower, replace the filter capacitor.
  5. Measure the AC input current without a load using a clamp on AC ammeter. Electrically isolate the inductor from the drive motor circuit. The drive motor leads need be kept intact so the drive motor will operate with the inductor removed from the circuit. Re-measure the no load AC input. If the AC input current is significantly lower, replace the inductor.
  6. Swap the existing drive motor with a known good drive motor.
Precor Error Code 20 20 Too Many Maximum Power Request in 1 Sec
Mar 18, 2013 | Precor C962i Treadmill 220V
Precor c966i error 20
Model: All Models
Recommended Action:
Mar 18, 2013 | Precor C966i Treadmill C 966i
I need a replacement drive belt for my Betty Crocker Bread Machine 1690
Some bread machine belts have number codes on them. If you still have your old belt email me the code off of it. The code will look something like this: STS S3M 523 My email is daryl441@msn.com I sell replacement belts.
Mar 08, 2013 | Betty Crocker BCF1690 Bread Maker
Rockworth 1.5 hp 6ltr oil free compressor drive belt replacement
You could try this link.
This is for megadyne tb2 310 belt (nlh6ltCOM)
http://www.solenttools.co.uk/performance-power-drive-belts/performance-power-compressor-drive-belt-nlh6ltcom-2051157-331171-.php
Feb 19, 2013 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Need a replacement drive belt for Red Man brand bread maker
I need the parts code off the belt to see if I have it in stock. You can reach me through my website breadmachineshelp.com The part # on the belt will look something like this: 60 S3M471 I will need that number to get the right belt for you.
Dec 30, 2012 | Kitchen Appliances - Others
Replace drive belt Bosch pbs7a
NEED A AUTO REPAIR SHOP TO RESET IT ONLY THERE COMPUTER CAN DO IT OK
Nov 14, 2012 | Bosch Belt Sander Drive Belt For Pbs 7a,...
2002 XG350 - Do I need new timing and drive belts?
timing belt and most drive belts are good for 70,000miles, i think the mechanic trying to take you for a ride, as for the drive belts inspect them if there is any cracking ware marks etc replace them but seriously if they look like new which they should with only that many miles would not need replacing.
May 14, 2009 | 2004 Hyundai XG350
Car Audio & Video Logo
13 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
