Question about Logitech PREMIUM STEREO USB HEADSET 350
I just purchased a Logitech USB 350 headset and it works ok except I hear a clicking noise when I have plugged in but not speaking to anyone?
jerryg50
  • 1689 Answers
SOURCE: logitech usb headset a-0356a trouble hearing
I don't have these headsets here and the setup to troubleshoot for your fault. But, I have an opinion.
It seems that the driver for the headset is not routing the sound from the net or other applications to the USB ports, as like with the sound from the media player.
For IE, look in the advanced settings for media and see if there is a setting for this. Also, check out all the media settings in the system for this.
I would search out the properties of the headset to see if there is a setting for this. Also search out the properties of the sound card where it allows for USB and regular sound sharing or routing.
I would also get in touch with the manufacture of this headset to find out if they know something or have a solution.
Jerry G.
Posted on Apr 13, 2008
SOURCE: Logitech 350 Headset Casing
Had the same problem, no headphone speakers would work.
First use a flat head screwdriver and insert in between leather padding
and plastic case and pry apart. Best to start at one area, insert a wedge
and pry further along. It will take a bit of force before it pops apart.
Take out 4 small philips screws
I found that the wire had broke right at the entry grommet. I pulled the
wire through and wiggled it and the speakers went on and off.
In my case I felt it was best to redo all the wiring. I first took these pictures
to have a map and pulled through an extra 4" of wire through and cut/desoldered
the wires.
Here are the original wiring connections at the speaker
4017e98.jpg and what must be the common. This was the wire that was broken
inside.
I re-soldered all the connections and separated them as best I could with
electrical tape (no shrink). Put everything back together and so far
seems to work fine.
Posted on Dec 23, 2008
praky16
  • 744 Answers
SOURCE: logitech headset not working
did u connect both the output wires from ur headset to ur system audio port.?
Posted on Feb 08, 2009
  • 5 Answers
SOURCE: Logitech ClearChat USB Headset Model: A-00006
You can buy replacement dongles from Logitech. Don't listen to lawrenceguo
Posted on Apr 02, 2010
Crenshow
  • 250 Answers
SOURCE: i can't hear anything from my logitech headset
Hi Itsyen, go to start menu, control panel, sound. Then here go into the Tabs and select the Headset as Mic and Speakers. Apply, Done !
Thanks and have a nice day Julien
Posted on Aug 02, 2010
I have windows 7 lop top i want to use Logitech usb headset 200. don't hear any thing after insert to the USB. What do have to do?
Please go to control panel and click on Sound
In theSound properties / settings window you must be seeing 2 options right click on the Logitech option and set it to default. Post this your logitech USB headset will be set to default sound playback device
I hope if you disconnect / connect the logitech USB headphones you are hearing sound from the regular speakers.
Jan 09, 2011 | Logitech Stereo USB Headset 200 Consumer...
Doesn't work with Skype
Fixed it: the microphone on the headphone was switched off - it's a bit of a design weakness in the Logitech headset: it's easy to unintentionally turn the microphone off while putting the headset on. The lower half of the right headphone's central medallion is a button - indicated by a crossed out microphone icon.
Dec 25, 2009 | Logitech ClearChat Pro USB Headset
Today purchased a Logitech USB headset #350, and the only sound that I get is when I re-adjust the volume from the laptop control.....otherwise there is no audio. I also searched online to see if there was...
In xp go to control panel>sounds and audio devices>audio (tab) then change the default and check use only default or uncheck it and it should allow both to work, I'm unsure exactly how to do it on vista because i don't have a copy of vista to tinker with right now.
Sep 27, 2009 | Logitech Audio Players & Recorders
My computer won't recognize my logitech USB headset
Okay, I've had the same problem with their keyboards and mice, first you uninstall and reinstall the driver, if that doesn't help go to start>run then open MSCONFIG. Then find the services and re-enable all of them, along with all the startup entries.
May 07, 2009 | Computers & Internet
I cant hear anyone on ps3
call logitech  3464543200 tell them the problem then he will help u when he ask to go to settings then he will ask u to test it then say it doesnt work then he  will ask for ur billing information such as adress phone number and zip code then he will send u a new one for free in 7 to ten days
my problem was that i could hear people but they couldnt hear me
Feb 18, 2009 | Logitech 250 Headset
Logitech premium usb headset 350 help me pretty please
If when you talk into your mic you hear yourself from speakers...open your volume control(windows) and check the box to mute mic. Not for sure this is a fix to your problem but from what you wrote is similar to problem seen with voice chat software.
Feb 16, 2009 | Video Game Consoles & Games
Plantronics Explorer 350 speaker problem
Delete the plantronics from your phone, take out the battery from your phone for 10secs then replace the battery and search for your headset again. worked for me.
Jul 02, 2008 | Plantronics Explorer 350 Wireless Headset
Logitech headset, new vista operating system
either the headset is not supported by Vista, or you need to right click on both speaker icons, normally coloured red and black and in the properties you need to see if your headset is listed as one of the microphone input devices, if you need to make the Logitech headset the default mic and not the windows generic mic. If you do not see it in the properties then it may not be recognised by Vista.
Aug 13, 2007 | Logitech Internet Chat Consumer Headset
Logitech PREMIUM STEREO USB HEADSET 350 Logo
49 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
