Question about kawasaki Sport & Outdoor - Others
How to adjust the rear shock on a 2002 kawasaki prairie 650 ATV. i need to make it stiffer. i'm a big guy and when i sit on it the body goes down against the brake cables. thank you..
onyeredson
  • 404 Answers
SOURCE: LT 500 ATV clutch adjustment
Hi!
I havn't come across your Machine before but hopefully a little Q 'n' A will solve/FiXya problem.
O.K. 1st is the clutch cable operated? if so can the cable should be adjustable from the handle bars?(Then take up the slack to leave a slight gap when lever is pulled) Do this by loosening the locking screw on the end of the cable and turning the adjuster anti clockwise so tension is put on the cable Not the lever.
If the cable isn't adjustable from lever go down to the engine and do the same as above on the cable there.
2nd Is the clutch fluid operated (Master Cylinder on clutch lever) If so look for clutch pushrod and adjust it by loosening again the locking nut and winding it out to create less gap between pushrod and clutch arm. You may need to bleed the system if after adjusting still the same.(Come back to me on that if needed)
3rd If when carried out the clutch starts slipping i.e. in top gear Engine Rev's and doesn't move forward well? then release the tension on either cable/pushrod until happy medium.
Good Luck!
Paul 'W'
Posted on Jan 02, 2009
  • 53 Answers
SOURCE: Any way to adjust the rear shocks on a 1996 vulcan 1500-a10 ?
dear susan shock adjustment for the rear shock are done with c wrench. you will notice at the top of the shocks there is a ring with 3 adjustment cams. the wrench is placed in the two holes you see on the shock opposite each other this is where the wrench fits you simply turn either direction for softer or harder ride. this adjustment puts more or less tension on the spring. i own a 96 vulcan as well hope this will help you jim
Posted on Mar 26, 2009
lilmikew99
  • 122 Answers
SOURCE: I have a 2006 kawasaki 650 brute force ATV the belt light is on
if its belt driven, they work off a type of clutch that just puts pressure on the sides of the belt. not usaully adustable, but there are mods, and after market clutches for faster respose and more aggressive take off, if this is what your after.
Posted on May 11, 2009
  • 434 Answers
SOURCE: 2002 Kawasaki Prairie 650
Either the switch on the handlebars isn't making contact. Or the shift motor on the front differential is broke.
Posted on Jul 07, 2009
  • 51 Answers
SOURCE: kawasaki 650 pariri atv oil light will not stop blinking
starter solenoid could be bad. i know it is in the other direction but it was the case on mine.
Posted on Aug 01, 2009
Adjust rear shocks, 1 - 5, which is stiffer?
Hi, Kevin if you're talking about the shocks on your dune buggy I can't help you, however if you are talking about your motorcycle shocks you're in luck, the setting that compresses the spring the most will be the stiffest. For more information about your issue please click on the links below. Good luck and have a nice day.
https://forum.motorcyclenews.com/topic/50159/how-do-i-know-if-my-rear-shock-is-set-properly/3
How to Measure and Adjust Rear Preload Adjust Motorcycle Suspension
How to adjust rear suspension on motorcycle preload settings Kawasaki...
Motorcycle Maintenance Adjusting your Suspension
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 27, 2016 | Motorcycles
1999 Kawasaki 300 Prairie. Where can I get a diagram showing fuel line routing?
Hi, Gary sorry you can't find the first and best tool you ever bought for your Kawasaki despair not for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
1999 Kawasaki 300 Prairie fuel line routing Google Search
ATV Connection
Where do connect the fuel line that goes from the carburetor to the engine
https://www.tradebit.com/filedetail.php/276766770-kawasaki-prairie-300-service-manual-repair-1999-2002
Apr 02, 2016 | kawasaki Motorcycles
Will idle & run at slow speeds, bogs down at higher speed.
Prairie 360 revs high but goes slow (45mph) - Kawasaki ATV Forum
www.kawieriders.com > ... > Kawasaki Brute Force/Prairie/Bayou
Oct 27, 2008 - 2006 Prairie 360, wife's ride, polar white, with 26" Swamp Lites on SS108's. ... that it has a low top-speed...45mph is about as fast as they seem to go. ....air cooled motor theres no real performance there, the P360 wts are light ... Can't put 2005 Kawasaki KVF 360 into gear
Jun 30, 2013
Prairie 360 speed/power issue?
Aug 28, 2012
06 Prairie 360, too many rpms???
Nov 30, 2011
2004 Prairie 360: WOT miss
Nov 9, 2011
More results from www.kawieriders.com
Oct 08, 2015 | kawasaki 2005 Prairie 360
Kawasaki forum, I have a 2002 kawasaki prairie 650 4x4 that will not switch into 4 wheel drive. It stays in 2 wheel only. Help please
Honda FourTrax & Kawasaki Prairie 650 ' Outdoor Life
www.outdoorlife.com/articles/gear/.../honda-fourtrax-kawasaki-prairie-6...
Honda decided not only to get into the 500cc-class automatic 4x4 camp, but to do ...by three electronic shifting programs: one for high-speed driving on easy trails; ... this innovation: Kawasaki made the Prairie 650 capable of starting in gear.
Sep 12, 2015 | ATVs
Where is the idler screw on a Kawaski 360 prairie atv
To ajust the idle there is a nob that you turn that come from the carb,
Jun 10, 2013 | kawasaki 2007 Prairie 360 4x4 Camo
Adjusting rear suspension
the rear shock is adjustable, the ring below the spring turns and locks onto a kind of peg on the body of the shock. being that your bike is an 86 it may even be time for new shocks or an upgrade to stiffer. if you do adjust then make sure both sides are on the same setting. as far as tools needed some shocks can be done by hand with help from someone lifting the weight up on the back end. i dont know what kind of tools as i cant find a good pic online of your bike but maybe a C spanner / wrench
Mar 30, 2009 | 1986 Suzuki LS 650 Savage
Sport & Outdoor - Others Logo
195 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
