Question about Vacuums
I have a hoover steam vac deluxe and the brushes rotate very slowly and have little power. i have cleaned the indicator screen.
  • george985 May 15, 2008
    Steamvac f7425-900 brushes will not rotate. have cleaned the filter.
    President:
  • 1,673 Answers
Check to make sure that the foam filter inside the recovery tank lid has at least a 1/4 inch gap from the top. Other then that, the turbine is what turns the brushes, either the shaft on the top of he brush block broke off, or the turbine is stuck. Sometimes you can take th turbine apart and clean out the components, must times it is better to just replace it rather then mess with it.
Posted on May 15, 2008
Hoover carpet cleaner f5915905 the handle release won't lock. what should I do ?
Repairing the Hoover Steam Vac Deluxe - YouTube
? 6:01
https://www.youtube.com/watch?v=QBtWcC4gqjY
Apr 21, 2009 - Uploaded by general0ne
I think Ill make one for the Dual V steam cleaner and provide some tips on maintenance. Good job ... The ...Missing: lock
Dismantling the Hoover Steam Vac Deluxe - YouTube
? 6:16
https://www.youtube.com/watch?v=sul52ULCR90
Jan 12, 2010 - Uploaded by general0ne
Dismantling the Hoover Steam Vac Deluxe. general0ne .... Aftercleaning the screen as shown on the video ...Missing: f5915905 ‎lock
Nov 29, 2015 | Hoover Vacuums
How to remove brushes on a hoover f5887-900 steam vac
Take off both tanks, then turn the steam vac over. Using both hands, pull evenly on each end of the brush block. They will pull straight out. But usually it isn't necessary to remove the brushes. Usually the problem is a blocked screen.If you look at the vac from the front of it with it turned right side up, there is a little window. Pull that off and using your fingernail, clean off the lint. If your model doesn't have a window that you can access, look underneath, near the brushes for a red plastic frame, pull down and it will expose the screen. Hope this helps.
Aug 18, 2014 | Vacuums
Brushes won't rotate on hoover steam vac. I have removed them and cleaned.
The brushes turn by the airflow from the vacuum suction turning a turbine motor to spin the brushes. First try to spin the brushes by hand. If they won't turn it usually means the brushes are clogged with hair and debris or need replaced or the turbine could be seized up. If the brushes won't spin reach under the brushes and push the little tabs and remove the brush block asssembly from the machine. If the brushes spin freely after you remove them from the machine then that means that most likely the turbine is seized and will need to be repaced. If the turbine is not seized you may simply just have a clogged filter screen. Most steam vacs have a red screen filter either on top or underneath the machine. On the top it is under a little clear plastic cover that you have to pry off before you can pull the screen out to clean it. If it's underneath you can pull it out and clean it.
Jul 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
My rotating brushes stopped rotating and my steam vac smells hot...is it a belt?
the hot smell makes me thing the motor is stuck
do not attempt to use it unless you can rotate the motor by hand. If the motor spins freely then it could be a belt. check if the belt turns
Feb 02, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Brushes on hoover deluxe steam vac cvarpet cleaner are not rotating. Took out the brush assy and drive spins slowly but with little torque. Cannot seem to open the bottom to see if belt or direct...
(1) Assure the brush shut off lever on the hood is not set to the off position.
(2) Is there still a square pin standing up from the one drive brush? It should be 1/4 square, and about two inches tall. That pin is the drive from the transmission to the brushes.
There are no belts. The transmission is air and gear drive mechanism.
Oct 02, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac, brushes won't rotate, have cleaned filter by brushes, removed brushes and they rotate okay when off steam vac, tried to ajust level for carpet cleaning and brushes still don't move
Check to see if the shaft on the brush block hasn't broken off. Otherwise it is the turbine that drives the brushes and is either clogged up inside or needs to be replaced.
Jun 07, 2008 | Vacuums
Spin brushes spin freely on steam vac when not attached to cleaner indicator screen not dirty speed selector is in high position brushes are clean spin brush indicator when brushes attached to machine...
If this is a Hoover Steam vac, the turbine which drives the brushes is bad. If not a Hoover, then what is it, they are different, need brand and model number.
May 14, 2008 | Vacuums
Hoover brushes stopped spinning
THE TURBINE WHICH DRIVES THE BRUSHES RUNS OFF SUCTION, A POOR DESIGN IN MY OPINOIN THEY GO BAD ON A REGULAR BASES. PROBABLY HAVE TO REPLACE TURBINE ASSEMBLY
Mar 27, 2008 | Vacuums
Vacuums Logo
106 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
