Kyocera KM1530 photocopier. What does C610 mean? It is comin gup on the display when we turn our machine on.
  • 1,110 Answers
C610 = Fusing Unit Heat failure. The fusing unit is the part that gets hot and "fuses" the toner onto the paper. The C610 code means that the fuser is not heating up as it should. The 2 most common causes are thermal fuse failure or thermister failure. The thermal fuse will keep the heater lamp from coming on while the thermister failure would cause the machine to not "see" the temperature rising as thus shut down the machine. Either way you will need a service company to come out and diagnose/repair the machine. You must also use the factory service mode to reset the fuser failure code.
Good Luck and Thnak You for using Fixya.
Posted on Sep 13, 2010
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
C-6 400 what does it mean on kyocera KM-2020 photocopier machine
Hi my Kyocera KM2020 is showing an error code C-6 400, what does it mean and how do I fix it? Thanks
Jan 29, 2013 | Copystar CS-1650 All-In-One Laser Printer
I am Thomas from South Sudan my Kyocera Photocopier 1635 Series error code : C6000.What to do sir?
Mr Thomas, this code means Fixing error, firsf switch on your Photocopier Machine then press 1,0,8,7 again 1,0,8,7 display will change will show u000. then press 1,6,3 press start key two times. machine will go off and on again. try that ,if will not work i will give you onather way.
Jan 20, 2013 | Kyocera Copystar CS-1635 Copier
Km 1530 displaying ap on screen
Please click here to download the technical guide and user manual.
http://www.kyoceramita.eu/index/service/dlc.false.driver.KM1530._.EN.html#
Sep 06, 2012 | Kyocera Mita Office Equipment & Supplies
My photocopier has been displaying this error code message C-7990 a photocopier kyocera KM-1500
C7990 is
Waste toner reservoir overflow problem (when the total number of copies is 100 thousand sheets or more)
• After E31 is displayed, 1,000 sheets are copied. Or waste toner exceeds 5 g.
Defective waste toner sensor or engine board (KP-5061).
Shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be solved, replace the process unit. After replacing the process unit, turn the power switch off and then on. If the problem
cannot be solved, replace the waste toner sensor or the engine board (KP-5061).
I hope this is helpful,
Shawn
Mar 05, 2011 | Kyocera Copystar CS-1820 Black and White...
MITA copier DC-2360, error code C610, fuser replaced. How to reset the error ?
IF you have corrected the problem that caused the C610 (broken fixing heater wire), then the error is cleared by turning the machine power switch off then back on.
Jan 07, 2011 | Kyocera Mita Office Equipment & Supplies
Mita Kyocera KM1535 with an error code. C710
C170-Toner sensor/Developer Error
check usual suspects Sensor, Wiring, Developer material, connectors.......
Feb 05, 2009 | ASUS P5GZ-MX Motherboard
159 people viewed this question
k24674
jasbo
jasbo
