Question about Canon PIXMA iP90 InkJet Printer
Not printing. looking for the self cleaning function.
    Sergeant:
    Champion:
  • 251 Answers
Manuals are here:
http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp830#ServiceAndSupport
Posted on Sep 13, 2010
Pixma iP4000 - reddish tint prints
Run the self cleaning head function, to clean ink jets(heads).
May 13, 2014 | Canon PIXMA iP4000 InkJet Photo Printer
Problem with printhead please consult user guide
Use the printer's utility program to self-clean the printer. This process may need to be repeated as many as 5 to 10 times. Often this will resolve the problem.
Turn the printer off, preferably overnight, if the self-cleaning utility has not worked. The ink may need to soften before the self-cleaning utility will be successful. Turn the printer on and try the self-cleaning utility again several times.
Determine from the owner's manual where the print head is located. Epson printers, for example, are usually in the printer. Many other brands place the print head in the cartridge.
Remove the cartridge. For models where the print head is in the printer, drop seven to 10 drops of isopropyl alcohol (rubbing alcohol) down the ink receptacle area. This is the hole where the ink flows into the head from the cartridge. Run a few self-cleaning utilities. If necessary, allow to sit a few hours or overnight and repeat the self-cleaning utility.
Soak the cartridge print head in hot water if the print head is in the cartridge. Allow to soak overnight. Dry the print head area with a paper towel. Repeat the self-cleaning utility.
Place the cartridge print head in isopropyl alcohol if the hot water soak did not unclog the print head. Leave the print head covered in alcohol overnight. Use a damp paper towel to wipe off the print head area. Dry carefully. Try the self-cleaning utility again.
Purchase a new cartridge if the alcohol soak did not unclog the print head in the cartridge. This will provide new print heads that won't be clogged. Contact a service technician for repair of print heads in the printer if the alcohol did not unclog the print head.
Mar 01, 2011 | Office Equipment & Supplies
Printer won't print; pending documents stay in queue.
Possibly, the printer driver is corrupt or wrong version, printer cable is bad or not plugged, printer on standby (not online), or defective printer.
Do a self-test print on your printer. Most printer has self-test print function, look into your model's documentation. If the self-test prints, then more likely your driver issue. Uninstall the printer driver and reinstalling should resolve it. Goto Start->Control Panel->Printers. You can remove and install printers from there.
May 30, 2010 | Dell 926 All-In-One InkJet Printer
Printer says unable to clean and therefor wont print until fixed
If you look at the Brother website you will find a trouble shooting guide for your machine.
In the guide, for the error you quote Brothers guidance is to check for a stuck piece paper, however it also states that if the print head is hard over to one side (righthand side if memory serves me correct), then to contact Brother. If you do so, Brother will tell you it needs to be serviced by a Brother agent, which will likely cost you more than a new one !
If it isnt a stuck peice of paper, the problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code soemwhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Dec 29, 2009 | Brother Multi-Function Center® MFC-215C...
When i run a test pattern on my mfc 420 it will not print the yel
Clean the yellow printer head with the self cleaning function. Try printing yellow from a computer, etc. Check ink level, make sure it is not telling you low ink.
Jan 12, 2009 | Brother MFC 420CN All-In-One InkJet...
Not printing black
Verification of color out – happens only after keeping the unit idle for quite some time.
1. Print self-test report
2. Are the cartridges out of ink – check ink levels
3. check self-test report patterns (missing lines or streaked bars)
4. Look for missing colors or ink smears.
5. Was this issue showing up because of any one single color?
6. Was it stored in a warm environment (Stored under direct sunlight?)
7. Manual Cleaning & Cleaning from Driver
Print a extended self-test report,
On the HP All-in-One control panel, press and hold the OK and Cancel buttons simultaneously and then release. An extended self-test report prints. You will get all the information of your cartridges. Good Luck
Aug 18, 2008 | HP Photosmart 3310 Printer
Slow Printing
Hi, The slow printing issue can occure even if the cartridges are out or low in ink try to check the print function by the stand alone unit by printing a self test page Here are the steps to print a self test page: On the front panel of the product, press Menu (or Setup) . Press the Right Arrow until Print Reports displays, and then press Enter, Start, or OK . Press the Right Arrow until Self-Test Report displays, and then press Enter, Start, or OK . If the self test page takes less time to print and if all the color blocks and black block print fine the ink level are fine. if the time for self test is also more try to clean the cartridge contacts and replace the cartridges if needed this will fix the issue. If the printer works fine as stand alone self test and copy try to performe the steps in the below webpage: ========== http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00093466&lc=en&cc=us&dlc=en&product=2512010&rule=10185&lang=en ========== If the issue is still un fixed try to set the print directly settings in the printer properties Click on start >> control panel >> printer and faxes >> there look for the HP printer icon with the check mark and right click on it and select properties and then click on advance tab and under it select the print directly to printer and click on apply and ok to save the settings. Once done try to print and check with the issue. Hope this will fix the issue. Regards, Barret.
Sep 03, 2007 | HP PSC 2175 All-In-One InkJet Printer
After self cleaning, Range trips circuit breaker when using convection
self cleaning ovens use super hot seting to bake the oven clean and it sounds like it melted a wire and it is shorting out the oven on that setting. look at the wires you can see or easy to remove panels
Dec 22, 2006 | GE Profile JGS968 Gas Kitchen Range
Self Clean does not work
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 30, 2006 | KitchenAid KEBS177 Electric Single Oven
Canon PIXMA iP90 InkJet Printer Logo
48 people viewed this question
old marine
old marine
