Question about Frigidaire Microwave Ovens
Lost MANUAL for... Model# FEF366ECC...Frigidaire Electric Stove
  • 8,197 Answers
You can get the manual on the link below.
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316417003en.pdf
Good Luck and please rate 4 thumbs up for the free answer
Posted on Sep 13, 2010
Electric frigidaire stove model:RE-38S serial :61CD4495 oven wont heat. checked;continuity,cord,wiring and outlet all was good. how do i fix this problem?
can not say as do not know if it is a conventional stove oven or a microwave oven . I would call a local repair service
Sep 13, 2017 | Frigidaire Microwave Ovens
FPBM189KFC MANUAL
Most Frigidaire manuals are available through their support site: http://www.frigidaire.com/Owner-Center/Product-Support-FAQs/ . Enter the model number in the search box and press enter.
The direct link to the owner's manual in English for the FPCM189KFC is http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316902454en.pdf . An installation manual and wiring diagram are also available from Frigidaire.
I hope this helps.
Aug 09, 2017 | Frigidaire Microwave Ovens
Unlock frigidaire tove
Thank you for your inquiry, friend!
From the information you have provided your Frigidaire stove is not unlocking and you have shut it off at the breaker and pressed clear. You have performed the proper troubleshooting regarding your stove and it appears that you could have a possible problem with the door latch or control panel. I would recommend having a professional technician come out and complete a diagnosis and repair on your stove. I hope this information is helpful. -Matt
Feb 11, 2015 | Frigidaire Microwave Ovens
How to work oven. just got stove from freind
First thing I would do is talk to the friend ... you don't mention the model #, BTW. Don't expect much of an answer based on your question. Frigidaire probably has made millions of ovens in thousands of models for sale hundreds of markets.
Thank you for your interest in FixYa.com
Sep 18, 2011 | Frigidaire Microwave Ovens
Hotpoint bd35 electric oven instruction manual
Here is a link for you to download a PDF instructional manual for your Hotpoint cooker or Hotpoint oven.
how to use this service
1 click on Link,
2 click manufacturer (Hotpoint)
3 enter your model number and download the PDF file .
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
Jan 28, 2011 | Microwave Ovens
Manual for Frigidaire 95CC-2689 stove top oven
Frigidaire has a page dedicated to getting you in touch with a manual
http://www.frigidaire.com/manuals
but check to plate on your microwave to make sure you have the right model number or you will get a null answer
Dec 03, 2010 | Microwave Ovens
About 1 hour into the 4 hour clean cycle an alarm started gong off. Code is F3. Frigidaire smooth top electric slide in stove.
The F3 code means
The oven temperature sensor is open Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem. Check oven temperature sensor, 1100 ohms Good Luck
Nov 27, 2010 | Microwave Ovens
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
My Frigidaire over the stove microwave not heating food
Hi,It is most likely the magnetron and diode that has to be replaced. This job should be done by a tech, High voltage. Magnetron's normally have a five year warranty, check your owners manual.
Mar 20, 2009 | Frigidaire FMT148GP Microwave Oven
Microwave Ovens Logo
337 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
