Question about Philips 50P8341 50" Rear Projection Television
Blue print do you have or can you send to Me the blue print or drawing for the main boards in the lower portion of 50P8341
  • Philips Master
  • 3,459 Answers
Cheaper at www.magnavoxhelp.com
Posted on Jun 26, 2008
  • Philips Master
  • 8,617 Answers
You can get the service manual for your model emailed to you from the following link and they provide free tech support when you purchase the service manual.
http://servicemanuals.vstore.ca/
Posted on May 15, 2008
Machine is displaying technical fault code f54 what is wrong?
I am guessing your machine is a whirlpool
If so, then;
The motor control portion of the main electronic control board is drawing high current. This can be caused by excessive friction in the drive system. Check to see if the basket spins freely. If not, examine and repair the cause of the excessive friction. If the basket spins freely, then the drive motor and/or the main electronic control board may need to be replaced.
Mar 07, 2015 | Washing Machines
I have a NOKIA 9500 Communicator. Its strip connecting the key-board portion and the display portion is possibly damages and therefore it now does not work. It is not available with anyone. Can I get a...
I have a NOKIA 9500 Communicator. Its strip connecting the key-board portion and the display portion is possibly damages and therefore it now does not work. It is not available with anyone. Can I get a replacemnt of that strip, which is full of printed wires giving several connections betwen the two portions -= the key-board portion and the display portion.
Dec 25, 2010 | Cell Phones
Sharp AQUOS LC-26SH10U 26 inch LCD Television. Video input problems? No audio. I get a picture using RCA cables but nothing using coax cable. Also I have no audio. When I get a picture using the RCA cables...
You need to replace Main Board of TV to fix its issues, click Shop Jimmy to see an image of that board, call Shop Jimmy on 952-881-6492 or 877-881-6492 for main board availability as currently its out of stock.
Thanks.
Jan 17, 2010 | Televison & Video
My Philips model 50p8341a 50" rear projection tv turns on, has sound but has no picture. Any ideas? Heard something about a convergence chip? Please advise.
you need ssb board is bad and you can,t git that part you can send to pts to have it rebuld. yes the stk 392-120 can drag the pix down but if you open it up you see a fouc blook go to the screen red or green or blue
turn it up just a litte the pix will come back. this is a know fact about this with this set i see a lot in my days of sevice ,at quaker tv
Dec 07, 2009 | Philips 50P8341 50" Rear Projection...
My phillips 50p8341 tv has had several problems over the years 1st being the remote quit working now the tv is turning of and the light is flashing and won't stay on.
Chances are you will the small signal board. Donot confuse it with the small signal module. You will be replacing a board the size of a playing card. Part# PH3912725871. Follow the instructions that accompany this part. Mainly you will have to adjust the geomtry.
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
The upstairs portion of my cetral vac works fine. the downstairs portion never has worked.
There are two components involved here, wiring and pipe.
Have someone go to the vac and turn on manually, briefly while you go to an inlet on the lower portion downstairs and open the door. Then shut the vac off.
If you have suction downstairs at this point with the vac turned on manually , your pipes are all connected and the issue is the wiring for the lower level of the house. It will need to be connected to the wiring from the upper level. A good installer will have roughed in the system with the necessary wiring running along the pipe from each inlet. You should find a piece of wire hanging beside the pipe at each of the lower inlets. This low voltage wiring will need to connect to the main line by colored sequence. Your problem may be as simple as a bad splice where the wiring connects to the main line , or a second wire hanging inside the wall behind an inlet which has either come loose or been omitted. Do not unscrew the connection screws at the back of the inlet screws fully where the wires connect as they contain a spring loaded terminal which may fall apart.
If you have no suction, the piping has either not been connected to the pipe from upstairs or your lower piping is clogged. You will need to trace back and find your main floor "drops" in proximity from below , then connect them into the balance of piping for the system, being certain to connect the wiring at the same time. Post back with what you find and if you need more help.
Last of all if you actually have moderate suction on the lower level, but not enough , you may have blockage in the lower line or a leaking valve door upstairs. If clogged you will need to use another vacuum a ad draw the blockage out at a lower floor inlet, generally the one closest to the vac.
Please post to confirm what you have found.
Oct 13, 2009 | Vacuums
Gsl25jfpa bs fridge is warm on top and frozen on bottom and freezer is warm
It sounds like the fan in the freezer is not working , to circulate air , and the coldness is just dropping . This will cause the icemaker to stop working first , then the top portion of the refrig next . As this coldness drops , the lower portion of the fridge ( crispers ) , will freeze . The main control board , causes the fan , not to run . Part Number WR55X10656 . The main control board , is located , behind the refrig , behind an 8 " X 10 " , small panel . There is usually a burnt resistor on the board , which is connected to the fan . Unfortunantly , the whole board will need to be replaced . It is easily replaceable . Doesn't take any special knowledge . All the plugs 6 or 7 , each fit the pin plug designed for it .
Oct 03, 2009 | GE GSL25JFPBS Side by Side Refrigerator
How would you replace the coolant for a philips 50p8341 50 in rear projection television
you have to remove the picture tube, drain the fluis through the drain plug, then take the lens cap off, clean out all the crud, then fill it up with new fluid, don't try to do it while it's still in the set, you could spill fluid on the board and cuse major damage, also, if you remove the tube, usually you will need to re-adjust the convergence of the tubes, usually only the blue and green tubes need this, pretty major repair, i don't recommencd doing it yourself, but getting a qualified repairman to do it.
Sep 08, 2009 | Philips 50P8341 50" Rear Projection...
Board repair
Hello sportylakey,
I would suggest first that you have a technician come over and troubleshoot your problem to determine which stage of the TV is malfunctioning. Then If you want you can have the technician repair the problem or swap out the board. This believe it or not is the cheaper option. I know that today a lot of people think that board swapping is the best thing, but in reality it's just a time consuming object lesson in futility, because you never know if you have fixed the problem or just bought more time. In any event try the option above, and if that is not to your liking try to send the boards to http://www.ptscorp.com/. Contact them to discuss your options on sending them the boards.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 09, 2008 | Philips 50P8341 50" Rear Projection...
Problem with philips 50p8341 big screen tv
if in 20 seconds maybe you have lost contact at the main board hot side section!
Oct 03, 2007 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
