Question about Canon Rebel XT / EOS 350D Digital Camera
No Power To Canon Digital Rebel XT
I cant get my Digital Rebel XT to power up. The CF pins all look good, the battery shows it has power before it went dead I took the CF card out to read it in my computer card slot. Charged the battery installed the card turned it on, nothing? could the little disk looking battery being dead cause this? Can I diagnose the problem some how before sending it to canon? Similar problem, Have three different batteries, but cannot get the camera to power up at all. Have not replaced anything, checked CF card in a different card reader - no problem there. Cleaned battery contacts with eraser. No juice
    Genius:
  • 2,035 Answers
    Genius:
  • 3,422 Answers
I believe this post will help you out..
Please CLICK HERE
Posted on May 15, 2008
  • 1 more comment
  • Priya darshan May 15, 2008
    Try a few things first.
    Camera power 'off'' - remove battery and clean the contacts (shiney metal strips) on the battery.
    Now remove lens and clean the lens contacts also.
    put a cap on the camera (no lens)
    Reinstall the charged battery and turn on the camera.
    It should start up. If so, turn it back off and reinstall the lens.
    Many of the problems related to Canon seem to be related to
    electrical contacts or connections. It kind of gives them quirky
    personalities.
    Could also be the interlock switch on the CF door - Check the little tab
    near the door hinge (Top side of the camera) hasn't been damaged. If
    the tab doesn't operate the little switch then your camera won't turn
    on.
    If you would like to accept my solution as fixya then only rate or accept the sol.no. 2 as fixya.
    Or you can just leave both the solutions unrated.
My canon xt rebel says err cf and wont do anything i bought a new one an the same thing whats wrong
One of more of the CF pins inside your camera are bent over. This is very common. The solution is to remove the main circuit and replace the bent/broken pins. Most repair shops will charge between $150-$200 to fix this.
Wes
Sep 05, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon rebel xt eos shows ERR CF. What do I do now?I tried a new flash card but still got the same error message. When I try to preview pictures I have already taken the screen says ¨no image¨. My...
Check that the pins in the camera that connect to the CF card are clean and not bent. You will probably need a good light and a magnifying glass to see into the card slot. If you can see a pin that is bent you could try straigtening it. BEWARE- turn off camera and use a non conducting "stick" ie cocktail or toothpick. Not sure for a Canon but a colleague paid £40 for a new pin assembly for a Nikon with similar problem.
Hope this helps.
Steve A.
May 06, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS/Rebel XT won't power up
Joe, this happened to me, just tonight... I got a new CF card and stuck it in, turned it on and one CF card flash. Completely dead from there. I found one of the CF card pins bent over, shorted out the socket and blew the mainboard fuse. I took the camera apart, found the fuse (labelled K) about under the set button area) I bridged the fuse with a bit of solder, straightened out the pin in the socket, put it all back together and it's working fine. The fuse is under the right side shield cover, it's labelled with a letter K. There is another fuse on the power inlet board (below the shutter button) and it's labelled 'P'...
Aug 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel xt does not accept CF cards for no apparent reason
It sounds like a bent pin in the CF slot. This is not a do it yourself fix. Take it to a repair shop.
Jun 22, 2009 | Canon Rebel XT / EOS 350D Digital Camera
CF Card not found
Ok here is the issues with the Canon 300D digital Rebel XT model of camera. First issue bent pins or broken pins the CF card reader on this camera is Surface mounted soildered onto the bottom half of the mainboard a large ammount of disasimboly is required. After removing the mainboard next you need is a desolder rework station. to carefully remove the CF card reader from the mainboard one messup and it might be easier to replace the mainboard. Sometimes. next issue is the power issue if you have no bent pins or missing pins, and the battery door is pushing on the door closure switch and the memory card door is pusting on its door closure switch then most likely you issue is 1 of 3 fuses underneath the power switch. these switches are the size of a few grains of salt very very small.I charge 150.00 to change the fuses and 225.00 to replace the CF card reader as long as none of the traces are damaged. if they are damaged the main board would need to be replaced and it is around 250.00 + depending on the parts cost at the time. If your good at soldering go for it. if not then let the experts do it.
Dec 22, 2008 | Canon Digital Rebel / EOS-300D Digital...
I am getting a ERR CF with my Rebel XT
You've probably gotten bent pins in the camera. Has to go to the shop.
Oct 17, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Err CF
the only possible for this error is. where the cf plugs into. the pins at the bottom of the CF chamber are bent. A close inspection with a good light should confirm this
Jun 19, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Problem with canon
Check the CF connector in the camera. One of the pins might be bent...
Dec 08, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Change out the CR2016 3V battery. You have to remove the rechargeable battery to get to the CR2016. Refer to the manual for proper instructions.
Had the same issue with a two year old camera. This solved my problem.
Nov 29, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon ds6041
The error 02 can come up when there is CF card problem : card not seated properly , card takes too long to come on line from the cameras point of view or if one of the the pins inside CF card chamber is faulty.
Sep 12, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
216 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
