Question about Jenn-Air Microwave Ovens
Need cutout dimensions for Jenn air cooktop cvg 4280b
2 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: I don't know how to
Check the outside breakers, usually at the meter.
--Best regards, --W/D--
Posted on Jan 24, 2011
Jenn air microwave model jmv820aas shut down completely, what do i do?
I'm guessing you might mean JMV8208AAS?
If so, then the service manual is at our site here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgdee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can order Jenn Air parts here.
Your problem will be either the line fuse, or one of the thermal cutouts / TCOs in the unit.
In case it needs circuit board repair, see this link.
Nov 27, 2012 | Jenn-Air JMV8208AAS Microwave Oven
I purchased a house w/ a Jenn-air elect. drop-in range. The Model # is 87946 or 87847. I believe the range was originally purchased in 1975. I am in need of an instruction manual .
Neither of these are a typical Jenn-Air model number. http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US suggests that the model number is on the back wall under the burner on the right side of a drop-in cooktop. For a range the model number is often on the frame inside the oven door, below the vent or on the back of the top of the range.
87946 or 87847 are the part numbers for the cartridges (the elements or the surrounding housing).
Look at the model number locations at the "Help me find my model number" link and try to locate a model number on your range. Then enter that model into the search box. The manual is probably available with the correct part number. Most Jenn-air electric cooktops start with JEC in their model number.
I hope this helps you locate the manual.
(I did try JEC87847 just in case you left off the leading alphabetical characters.)
May 08, 2011 | Jenn-Air Microwave Ovens
Gas cooktop is sparking by itself
one of the switches that are mounted on each valve of the cooktop is shorted and this will bypass all off switch positions,replace them all,its easy and only about $15.00 per switch
Mar 05, 2011 | Jenn-Air Microwave Ovens
Dimensions of Jenn-Air Microwave Model M166?
The approximate dimensions are 22" W x 15" H & 15" D.
Jan 27, 2011 | Jenn-Air Microwave Ovens
Jenn Air Microwave builtin oven has no display and will not turn on. Had the power to the oven checked and it's ok. The oven stop working when it was on. The oven is 17 years old.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You should check the internal fuse as well as the oven cavity thermostat / thermal cutout and the magnetron's thermostat / thermal cutout.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Aug 23, 2010 | Jenn-Air JMC7000 Microwave Oven
I have an older kitchenaid 30-inch cooktop - Model number KGCS100S. I want to replace it and need to know the size of the existing cut-out. I can't get a measurement without a lot of extra work and...
Hello
Unfortunately, the cooktop you have is no longer in production, and even if i give you the dimensions of the cooktop, the cut - out is not a standard size, some people like to make a more spacious cut - out, where others give it a tight fit.
Best way of knowing is to unscrew the screws and lift out the top and measure the dimensions yourself.
I really hope this can be of help, please do not hesitate to let me know if you have any further questions.
Kind regards
Andrea
Jun 17, 2010 | Microwave Ovens
My father's old Jenn-Aire microwave, Model # M170, has a rusted bottom and we need to replace it. Is there a model that is of the same dimensions so that we can replace the unit inside the cabinet above...
You can contact Jenn-Air customer service and they should be able to tell you if there is a "drop-in" replacement for your model.
Aug 19, 2009 | Jenn-Air Microwave Ovens
How do i remove a built-in jenn-air microwave?
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If not, try here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If the fuse is good, it may be the magnetron thermal cutout (TCO or thermostat) or the oven cavity thermal cutout (TCO or thermostat).
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 05, 2009 | Jenn-Air Microwave Ovens
Need Replacement Plate
Look on the internet auction sites (ebay etc)
There is quite a trade in them. Make sure match the dimensions of yours before purchase.
Jun 11, 2008 | Jenn-Air JMC9158AAS Convection/Microwave...
Microwave Ovens Logo
54 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Dennis Boxerman
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
