Question about Kenmore 33169 Gas Single Oven
The oven is turned off and it is still very hot, seems to be onstill so I unplugged. Does this mean its broken,
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
I have a Hot Point Gas Stove my burners all turn on but when I turn on oven nothing seems to happen
If you have a pilotless model it is very likely that your oven igniter is bad. This is fairly easy to replace. A contunuity check will show if the igniter is bad.
Nov 25, 2013 | Stoves Ovens
My oven wont turn off, it seems to turn itself on. It stays hot. Can I just unplug it?
Yes you can do that safely, turn OFF FIRST before withdrawing the plug.
When this happens, it is usually some sort of control fault, either switch, or electronic.
Mar 22, 2010 | Ovens
F2 Failure Code after cleaning cycle on GE Double
f-2 is usually a runaway oven temp which most of the time means a bad oven sensor.try replacing this first.
Jan 16, 2010 | GE Ovens
My oven will not heat up the ignitor does not glow, everything else works model# jgbp26bea1wh xl44 series
the hot surface igniter can be tested for continuity
using a mutitester normally will have a reading somewhere around ten ohms can be visually examined for an area with white and a thin line where it is broken make sure oven is not set on timed bake voltage to igniter can also be tested will be around 120volts use caution whenever testing
cab unplug stove attach lamp to wiring and plup back in turn stove to back verify power to igniter to verify problem is igniter
Dec 10, 2009 | GE Ovens
Oven staying hot a long time after it was turned off
Thanks for your reply. I contacted an appliance repair person I have used before and he told me about turning off the breaker, which I did. He suggested using an oven thermostat to see if it was heating to the correct temperature as a first step. It may be the thermostat, I do not know what the controller is as presented by one of the responders. At any rate I learned that my breaker for the oven is by itself and is not attached to the stovetop which is good. I will have to weigh the cost of replacing a part on a 20 year old builder quality oven with microwave on top to a new one. Any ideas on a new problem free model are appreciated!!
Feb 12, 2008 | Ovens
Oven will work for about half an hour and then turns itself off.
it sounds like the thermal cut out is broken can be replaced quiet easy need to disconnect oven from mains remove outer cover and has four wires two blue two white all with spade connectors can be bought from e spares on the web
Nov 04, 2007 | AEG B4101-4 Electric Single Oven
Exterior surface of oven gets hot when turned off
What do you mean by very hot? Is it too hot to touch? Hot enough to sizzle when a drop of water is put on it?
Oct 06, 2007 | Dacor MCS130 Millennia Electric Single...
Faulty bake or broil element
The solution to this problem depends on whether the oven is electric or gas. Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken. 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Call an appliance repairperson or replace the element yourself as follows. 4) Unplug the oven and let any hot parts cool. 5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires). 6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part). 7) Reverse the process to reinstall. Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out. NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges. Here's how to troubleshoot your range: 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on). 4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual. 5) Adjust the pilot flame (older stoves only). 6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel). 7) Clean out the oven burner ports, using a stiff wire. 8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one). 9) If the oven still doesn't work, call an appliance repairperson.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Kenmore 33169 Gas Single Oven Logo
105 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
