Question about HP Pavilion dv1000 Notebook
Hp pavilion notebook
I have plugged in my new laptop battery and was going through the setup process when i unplugged my charger when my laptop died right after doing so so i plugged it back in and it restarted i noticed that it said my battery wasnt connected i would like some information about the reoccuring problem
    Problem Solver:
Try reinstalling the driver or contact HP there very good at helping you. They are located in the US
Posted on May 15, 2008
Battery drivers to fix plugged in not charging
I get this situation, occasionally. If I unplug the laptop and let the battery drain for a while, then plug the charger back in, it will then show as charging normally. Good luck.
Apr 06, 2014 | HP Pavilion dv7-1240us Notebook
My Pavilion g6-1b79dx notebook will not charge even with a new battery and charger. The light indicating the charger is plugged in is blinking white
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/replacement-hp-pavilion-g6-ac-adapter-19v-90w.html
Dec 09, 2012 | Plantronics Hp - Pavilion G6-1B79Dx Laptop...
My laptop will not charge when the charger is plugged in. I tried removing the battery and turning it on while it was plugged in. Is my computer messed up or is it just the charger. Also my warranty has...
Your laptop still not charge even with the battery removed?
I guess you need a new adapter. Or you can test with a known working adapter first.
Specification of HP pavilion DV7 charger:
Output: DC19V 4.74A
DC Connecter (Barrel) size:
Internal Diameter: 5.0mm
External Diameter: 7.4mm
With central smart-pin inside
Reference: http://www.chargerbuy.com/replacement-hp-pavilion-dv7-ac-adapter-19v-4-74a.html
Feb 16, 2011 | HEWLETT-PACKARD Hewlett Packard Pavilion...
Hp pavilion dv-7-1245dx --keep shutting down after a few seconds
If the computer's battery is bad it won't stay on. If the fan is plugged up and over heats quickly, then the computer will shut itself down. I would start with those. Wouldn't be bad to check that your memory chips are in securely as well.
Jan 06, 2011 | HP Pavilion dv6000z Notebook
Hp pavilion dv6000 battery not chargering
First try to reset the battery to see if it helps any by doing the following: Turn off all power saver settings on your laptop, disconnect the laptop for the ac adapter. Then use your laptop and run the battery down ignoring any low battery messages until it dies. Then let it fully charge for a night without turning it on, and see if it has saved any charge. If it still hasn't saved any charge, it seems like the only option is that its a dead battery and needs to be replaced. Best of luck!
Jul 14, 2010 | HP Pavilion dv6000z Notebook
My HP Pavilion dv5215us PC Notebook will not turn on. The screen stays blank. Also it will not turn on when the battery is removed and the charger is still plugged into the PC. What is my problem?
Try removeing the battery, memory and harddrive.
If you can get to the CMOS battery, unplug it as well.
Open the lid and push and hold the start button for 30 seconds.
Re-install the removed items and power up unit.
Nov 30, 2009 | HP Pavilion dv5215us Notebook
Touch pad isstP Pavilion cursor starts drifting uncontrollably
try removing your battery and replace it back. its like resetting it.
May 16, 2009 | HP Pavilion dv4000 Notebook
Laptop turns off intantly, when I unplug the charging cord
For those of you having the problem of a HP laptop shutting off when you unplug the charger and your battery is fully charged, I can help you. There is nothing wrong with the laptop, battery, or computer, it is a power management setting. If you go to display properties, select the screen saver tab, then click the "power" button, in the power schemes field is a drop down window, click on it and select "Rixane Power Scheme", it is a power switching utility that quickly switches between AC and Battery when the power cable/charger is plugged in or unplugged while the laptop is on. If you have it set to "always on" it will shut off when you pull the power cord, even if the battery is charged. This will also happen on many non-HP laptops, if you don't have a HP laptop or there is not a "Rixane" option available, select the "Portable/Laptop" power scheme. Hope this helps!
Dec 27, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv1000 Notebook Logo
46 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
