Question about Garden
Need new pressure washer hose for stock no. PW2200/03435
    Problem Solver:
  • 23 Answers
Go to homier.com/blue-max
Posted on Sep 13, 2010
How do I fix my pressure washer when the high pressure hose keeps blowing off.
If hose fits over a hose barb try using a hose clamp from any auto supply store Or replace the hose barb GL
Oct 08, 2015 | Karcher K 367 M 1750 PSI 15 GPM Electric...
I was changing the fuel filter on my 92 Honda prelude and I bent/cracked the line coming into the filter and I was hoping I could cut off the fittings for my stock filter, buy an in line filter and fuel...
Best to fix it right buy a new fuel line .An inline filter couldnt handle the pressure cause with fuel injection you have alot more fuel pressure and using clamps you are risking your life with a good chance of a fire
Oct 16, 2013 | Honda Prelude Cars & Trucks
Hose on cjc-1001 pressure washer is leaking. Need to buy new one but cant find a distributor
http://www.watercannon.com/c-11-hoses-pressure-washer.aspx here a link to a site that sells high-pressure hoses. almost all hoses are similar when it comes to pressure washers, just by the right attachments and you'll be good to go.
Apr 05, 2011 | Garden
Need the connection for the wand hose to the pump for Blue Max Gasoline High Presssure Washer stock No: PW2200/03435
Your pressure washer is sold under various brand names, however I believe that it is made by campbell hausfeld. Parts are here:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/campbell-hausfeld/PW2200
Take a close look at the pump diagram to make sure it looks like yours. Good luck
Nov 10, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Water does not come out of the lance when I squeeze the trigger
HI it sounds like you may just have a blocked jet on the end of your lance. Please remove and clean.
May 31, 2010 | Northstar Professional Series Pressure...
Hausfield Campbell pressure washer 2300 psi .Water not flowing through hose to gun
hi try statring the machine with no hose on, if ok add the hose to the machine without the gun and lance. then try the gun on its own WITHOUT THE NOZZEL in the lance. just elimate things regards
Jan 23, 2010 | Campbell Hausfeld PW2575 Pressure Washer
Husky power washer no presure?
Found an easy solution to my problem. Was dumping pressure out the bottom when I pushed the trigger. Turned out the line my hose reeler that my hose was running off of was kinked. Only partial pressure was going from the house hose to the pressure washer. I attached my house directly into the house, bypassing the hose reeler, and it worked fine. Apparently, you need a certain amount of pressure going into the washer for it to work.
Mar 20, 2009 | Garden
High pressure hose connection blew up. Fix? or buy new?
Yes take it to napa auto parts and they can cut and attach a new end which are for hydraulics. They are crimped on and meant to hold very very high pressure. I used to use a pressure washer everyday for a living and it was a tractor rental/repair shop and we used the hydraulic fitting machine on the power washer hose all the time so rest assured.
Mar 11, 2009 | Garden
RAT PROBLEMS
you need to reset the switch just blow down the pipe at the opposite end to the switch till it cick again if that doesent work check for air leaks spread washing up liquid on the whole pipe and look for bubbles check wiring also
Nov 30, 2008 | Kenmore 22422 Top Load Washer
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
